Question about Panasonic AG-1980 S-VHS VCR
Panasonic AG-1980 I have not used this S-VCR for sometime now. However, when I load a tape it rejects it right the way. Nothing I do allows the tape to stay inside. Once a while I receive error code F06. Any help? I thank you Kosmas
  • Mikis Sep 25, 2007
    I love the help I received so far from you.
    I thank you...
I have the same problem on 3 of my AG-1980's, so where is the mode switch?
Posted on Nov 02, 2008
    Champion:
  • 221 Answers
Most likely problem is a dirty or defective mode switch. this switch tells the internal computer what position the mechanism is in. if the switch is bad, the computer is "confused."
Posted on Sep 25, 2007
SOURCE:
AG1980 will not load tape
Load mechanism may have frozen up and gears no longer function. Try 10D contract spray.
Sep 26, 2014 | Panasonic AG-1980 S-VHS VCR
Colour Noise and Dim Display
Did you try cleaning the tape head of the player?
For some reason be sure all the gear or any mechanical inside the player is freely rotating.
Adjust the VCR tracking to get a good picture.
Feb 19, 2008 | Panasonic AG-1980 S-VHS VCR
Panasonic AG 1980, displays d u 10, ejects tapes
It hates what you have put into it. OBB SEEN
Apr 23, 2014 | Panasonic AG-1980 S-VHS VCR
Panasonic Ag-DV1000 mini DV deck shuts down after inserting tape
When there's a problem with the drive mechanism of a VCR it will shut down to prevent damage. All operations of a VCR are controlled by a computer chip. This is told what mode the mechanism is in by a Mode Switch. If this is faulty it can cause the machine to play up. Sometimes a spray of Video 40 on the mode switch can restore operation. However it will not correct the problem if the mechanism has any damage on it.
Feb 25, 2014 | Panasonic AG-DV1000 Mini DV VCR
What is HO2 message is for?
In many Panasonic models that means the tape did not withdraw when unloading. If this is the case then it could be the loading motor or mode switch that's the problem.
Jan 05, 2013 | Panasonic AG-1980 S-VHS VCR
PANASONIC VCR DOES NOT LOADE THE CASSETT TAPE AND GOES OFF AS SOON AS I TRY TO LOAD THE C.TAPE.
VCR's have a thing called a mode switch. This tells the electronics of the machine want position the mechanical section is in. If it gets wrong signals then the VCR electronics power the machine down. These wrong signals are often caused by damage to any part of the VCR mechanical section. Perhaps in this case something to do with the carriage unit. But the switch itself can go wrong. A visual inspection inside might reveal damage to some part of the VCR.
Jan 19, 2011 | Panasonic AG-1980 S-VHS VCR
Was looking to buy one, and before the seller
the tape deck has jumped timing and can cost 40 to 100 dollars depending on how quick it takes the tech
Jan 05, 2010 | Panasonic AG-1980 S-VHS VCR
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
Panasonic AG-1980 Wont load cassette
probably caused by the mechanism being mis-timed. re-timing isn't difficult, but a service manual is absolutely necessary.
Nov 16, 2008 | Panasonic AG-1980 S-VHS VCR
H02 Error Message
H02 error on AG-1980 is a "capstan motor error." most likely problem is a defective capstan motor.
Apr 02, 2008 | Panasonic AG-1980 S-VHS VCR
Panasonic AG-1980 S-VHS VCR Logo
362 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
