Question about Adobe Acrobat® 8.0 Professional Full Version Academic License for PC
Lines through the graphics that don't show up until the file is converted to pdf.
There are lines through my graphics that only show up when I conert the file from Publisher to a pdf.
  • 28 Answers
Your pdf prog is not accepting you graphic properly because its in the wrong format try converting yor graphic to jpeg. png or other using the drop down menu when you save you need to save as a jpeg or other untill you find which format
your prog accepts.save it then post it to pdf using import or insert
Posted on Apr 26, 2009
Anybizsoft pdf converter
I would like to recommend you a competent jpeg to word document converter, JPEG Converter, with this converter, you can convert all jpeg contents to word form, including text, table and graphics so on jpeg converter is available at http://www.onlinedocumentconversion.com/
If you don’t want to convert your jpeg file then send your pages at
production@jvinfosol.com
Sep 11, 2010 | AnyBizSoft Studio AnyBizSoft PDF to Word...
Tip
How to Convert PDF to Word Document on a Mac ?
Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
As we all know , PDF is a proprietary format that allows we to read electronic documents, either on or off line. But the problem is that it can not be editable and freezes the content . Facing with such problem, we need to convert pdf files to other formats. While, we always convert it to word , we all familiar with word which is an editable format .As mac user, you must want to know how to convert it perfectly, in this case , PDF Converter Mac is the best choice for you.
To begin with you should know the software which is called PDF Converter Mac, PDF Converter Mac is a comprehensive PDF tool to help Mac users convert PDF to Microsoft Office Word, Excel and PowerPoint for Mac. By converting PDF files to Office documents for Mac, Mac users can flexibly edit or reuse read-only PDF files, or extract PDF tables and data to spreadsheet for easier calculating and editing, or present PDF contents to the public. PDF Converter for Mac offers many amazing features: Good Preservation; High Efficiency; Support encrypted PDF Files Conversion; Flexible Options and more. With quick conversion speed and batch conversion modes, PDF Converter Mac can improve your efficiency to a large extent.
Now download this PDF Converter Mac to convert pdf to word on a Mac and install it to your computer, Following is the details on how to convert pdf to word step by step.
step 1. Import PDF Files
You can add them from the File menu or directly drag files into the panel. By the way, you can remove the file by dragging it out of the panel.
step 2. Customize Output Settings
You can set the files in the panel individually. Choose a file and click setting icon and you can customize the Page Range and Format.
The default option of Page Range is All pages; you can also choose Customize and type on the page number that need to convert.
There are two options of output format. You can choose MS Office Word (.doc) or Rich Text Format (.rtf) as your need. If you choose the option Apply to all, the format of current document setting will apply to all the files in the panel.
step 3. Set Destination Folder
You can set output folder by choosing File-output settings-output folder. There are two options to select. You can save the output file in the same folder as source or click Browse to customize the destination folder.
step 4. Convert PDF Files
Click Convert and all the files will be converted in seconds. There is a processing bar in the process of conversion. And after conversion, there will a notification to show you the conversion result. It will be found that all the original text, layouts, hyperlinks and graphics would be preserved in an editable Word document.
OK! You successfully complete to convet pdf to word in mac OS X with a few steps, you can use the word files easily now.
on Sep 21, 2010 | Cameras
Tip
How to create restriction pdf files without Adobe Acrobat?
It is quite sure that you can create restriction pdf files by using pdf converter.You can edit text in word file,and then convert to pdf file.But seldom pdf converter could create restriction pdf files.
Advanced word to pdf 5.0 is a professional converter for batch converting Word documents to PDF documents.all the original text font, images, graphics, hyperlinks, layout and formatting are kept intact after conversion.its available to add properties to the output PDF file,like the author, user password, owner password, allowed actions, etc.
Additionally, Advanced PDF To Word is a standalone application, so you could run this program independently and needn't extra install Microsoft Word, Adobe Acrobat or Acrobat Reader
Here i will show you how to create restriction pdf files without Adobe Acrobat.
Step 1: Edit text in word files .
Step 2:Convert word document to pdf files
Step 3:Add password,and other option you want.
on Mar 19, 2010 | Computers & Internet
Changing the font size in a pdf file
i didn't get the question correctly....there are two types i don';t know which one will be usefull for you..
1. Change the font size of pdf while reading:
You can use zoom in and zoom out option to do that..or Ctrl+ + and Ctrl + -
2. Change the font size of the acual pdf doccument
For that you need to download pdf to word converter and convert to word doccument and change the font size and again convert to pdf file
These softwares aares freely avaiable in internet...
Hope you will succeed
Nov 23, 2009 | Adobe Acrobat 7.0 Professional
I have a letter in a pdf format and I want to add
you have "word" in parentheses. PDF is not the same as MS Word (if that is what you mean). Unless you have Acrobat Professional you will not be able to edit the PDF directly. You can however copy the text from the document into a word processing program (like MS Word) and edit the letter. And if necessary you should be able to republish to PDF format with the appropriate Word add-on
Oct 02, 2009 | Adobe Acrobat 7.0 for PC
Tip
How to convert PDF to Word using free PDF Tools
PDF is a often used format for digital text and graphics saving. It is easy to generate but hard to edit.Word is easy to edit but not suitable for storing and sharing. Many PDF files are generated from word and if we want to edit some text or graphics, we need to convert PDF to Word.
A nice free PDF to Word Converter is needed. I suggest this PDF to Word Converter and show three steps to convert PDF to Word.
1.Install and Launch the program.
2.Add PDF files. you can import PDF files in batch. And you can choose page range of one imported file.
3Customize the file storage path.
Note: the free APP supports encrypted PDF conversion.Just deal with it as normal PDF files.
on Mar 05, 2010 | Computers & Internet
Missing lines on PDF from a large TurboCad file
Will TurboCAD allow you to export to a .pdf instead of printing to a .pdf? Have you tried printing to a file (.prn) before turning the file to a .pdf? To print to a file, click Print Setup, there should be a box to check to Print To File. Make sure you check that box. Then you should be asked to pick a file format which should be .prn if you are using windows. After you create the .prn file, then open Acrobat and convert the .prn to a .pdf. I hope this helps you with your problem. Printing can be a pain with CAD programs.
May 07, 2009 | Adobe Acrobat 7.0 Professional
PDF files
You may need to check your preferences in Acrobat, and simply change the embedding to include the font you're using; but what Acrobat shows depends upon the type of font that you're using. You might understand the problem better after reading this article:
http://kb.adobe.com/selfservice/viewContent.do?externalId=325165&sliceId=1
Sep 20, 2007 | Adobe Acrobat 6.0 for PC
Adobe Acrobat® 8.0 Professional Full Version Academic License for PC Logo
80 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
