Heating element has blown IRCA Type RL6 1800W Remove back panel unscrew 2 screws remove the 3 conected cables open oven door remove 2 screws at rear of oven that holds faceplate in place remove face plate and take old element out and replace with a new element
SOURCE: Flavel 100 finesse problem
Check the thermal fuse it is located on a bracket at the rear of the fan oven.
SOURCE: Fan works, but Oven stays at 100 degrees. Tried
On my C301 U, I found the brown connector on the right side of the oven control board P3-2 loose. It looked connected but while doing a shake test- Whoop, there it is. It is the sensor for the temp probe. If it's loose all the fans run all the time.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=C301U&productCategoryId=0124100&brandId=1085&brandDescription=THERMADOR&modelName=BUILT-IN-OVENS&diagramPageId=00014&componentDescription=WIRING%20DIAGRAM&documentId=U2500861&blt=06
Hello, you're probably not getting enough air in to keep the flame sustained, check for an outside air tube that might be clogged, if not than try keeping the door a crack open. Hope this helps
