1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer. We will replace the printer, only if it is under warranty.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
Is a DELL 1700 LASER PRINTER a decent printer, and how much should I be willing to pay, is this a...
(More)
Is a DELL 1700 LASER PRINTER a decent printer, and how much should I be willing to pay, is this a very old printer ?
Thanks
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not...
(More)
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not necessary)for my home that at least does decent photos for my personal use. Any suggestions?
how do I get my printer to start again. I was printing with 3 pages to go and it just stopped.I...
(More)
how do I get my printer to start again. I was printing with 3 pages to go and it just stopped.I removed 1 page stuck but cant turn back on.Can u help?. Thanx Bel
put new cartridge in officejet j6410 and overnight it now says cartridge on left needs replacing....
(More)
put new cartridge in officejet j6410 and overnight it now says cartridge on left needs replacing. put old cartridge back in and it still says the same thing
