Question about Brother HL-4070CDW Printer
Color spots on left margin when printing with my HL-4070CDW
I've done a few printouts with my Brother HL-4070CDW and am noticing color spots on the left. Seems to just be blue. I did a color calibration from the printer's menu, but didn't seem to fix the problem. Any advice?
  • srizvi1 May 05, 2009
    rulds2008, thanks for taking the time for a response but I'm wondering if it could be problems with the cartridges so soon - this printer's pretty much brand new - it was ordered in feb, 2009 from NewEgg.com. Also, since this is a laser color, are there cartridges?
    Here are pictures of the problem:
    http://twitpic.com/4knr7
    http://twitpic.com/4knub
    Also, it seems someone else has a similar problem here:
    http://www.fixya.com/support/t2128778-bl...
  • srizvi1 Jun 09, 2009
    I e-mailed Brother and they replied with the following:
    Printer Customer Service CA
    May 6
    Brother Customer:
    Thank you for taking the time to write us in regards to the colored
    spots print quality issue that you are experiencing with your HL4070CDW.
    Brother strongly recommends that customers do not use generic drum units
    and/or toner cartridges, or refill their Brother toner cartridge. Each
    Brother laser printer is designed to work at pre-set temperatures that
    are matched exactly to each of our individual toner formulations. Each
    individual component is designed to work with the other to ensure
    quality and reliability. Using non-Brother supplies may affect the
    hardware performance, print quality and machine reliability. The
    Brotherlimited warranty does not apply to any problem that is caused by
    the useof unauthorized third party drum units, toner cartridges or
    toner.
    If you are experiencing white or color dots/spots on the printed pages,
    clean the drum unit:
    1. Open the MP (Multipurpose) tray by pulling it toward you and lower
    itgently.
    2. Pull out the MP tray support and unfold the flap.
    3. Place 3 sheets of regular plain 20 lb paper in the MP tray or the
    cleaning sheet sent by Brother.
    4. On the control panel, press the following keys one by one - OK, GO,
    OK. The keys strokes should not have any pauses between them. The
    display should turn an orange color and a zero should appear on the
    leftside of the display.
    5. Press the DOWN arrow key until 31 appears on the display. Press the
    OK key.
    6. Press the GO key. PLEASE WAIT appears on the display. The machine
    will pull one sheet from the manual feed tray.
    7. DRUM CLEANING COMPLETED will appear on the display once the sheet
    hasbeen pulled through the machine.
    8. Press the GO key again to feed the remaining sheets.
    9. When the last sheet has been fed through the machine, press the
    CANCEL key.
    10. From the Ready screen, print a test page by pressing the OK key.
    a. MACHINE INFO will appear on the display. Press the OK key.
    b. Press the DOWN arrow key until TEST PRINT appears on the display.
    Press the OK key.
    c. When the page has printed, press the CANCEL key to return to the
    ready screen.
    11. Check the sample for dots:
    a. If the dots disappeared, the issue has been solved. Please keep in
    mind that the type of media, could introduce paper dust or spec#s that
    could adhere to the drum surface, contaminating it.
    b. If the dots still remain continue with the next steps.
    12. How many dots do you see?
    a. If you see 3 or 4 dots in a vertical line (every 75mm or 3 inches),
    continue to STEP 13.
    b. If you see 7 or 8 dots in a vertical line (every 62.8mm or 2.5
    inches), your toner cartridge has an issue, please replace the proper
    toner cartridge according to the color of the dots, we Brother strongly
    recommends that customers do not use generic toner cartridges, or
    refilltheir Brother toner cartridge. The Brother limited warranty does
    not apply to any problem that is caused by the use of unauthorized third
    party toner cartridges. Go to Warranty Options.
    13. Press down on the front cover release lever and open the front
    cover by pulling it towards you.
    14. Hold the green handle of the drum unit (labeled 1). Lift the drum
    unit up and then pull it out until it stops.
    NOTE: If you cannot pull the drum unit out, make sure that the front
    cover is fully open.
    15. Remove the toner cartridge that is causing the dot, by holding the
    handle of the cartridge and lifting it up and out of the drum unit.
    Note: We recommend you place the toner cartridge(s) on a clean, flat
    surface with a piece of disposable paper underneath it in case you
    accidentally spill or scatter toner.
    16. Once you have removed the toner cartridge, check in the open slot
    where the toner was installed for dots, smudges or paper spec#s on the
    drum surface cylinder.
    17. If you see something out of the ordinary, please try to gently (do
    not scrub or use wiping motion, because this may damage the drum),
    cleanthe drum surface with a cotton swab until the dust or paper powder
    comesoff. You can spin the Drum in question by rotating it, with the
    gear located on the bottom left side of the drum.
    Note: The Drum is photosensitive, DO NOT touch it with your finger, and
    do not clean the drum with any sharp objects, because this may damage
    the drum.
    18. After gently cleaning the Drum surface, reinstall the toner
    cartridge you removed.
    19. Push the drum unit back into the machine until it clicks into place
    and close the front door.
    20. Print a sample page. If the issue continues the printer may need
    service.
    If the printer is in warranty, call Brother Customer Service at
    1-877-Brother (1-877-276-8437) for warranty options.
    If the printer is out of warranty, contact a Brother Authorized Service
    Center for repair by clicking on the link below:
    http://www.brother-usa.com/service/defau...
    We apologize for any inconvenience you may have experienced.
    Sincerely,
    Brother International Corporation
    Your opinion matters to us. Click the link below to take a quick survey
    regarding our email response.
    http://www.brother-usa.com/Surveys/Surve...
    Original Message Follows:
    Email from Ask Us Customer:
    Sent: 5/4/2009 11:05:45 PMModel: HL-4070CDW
    Date of purchase = 02/17/2009
    Operating System = Mac OS 10.5
    Computer type = Apple
    Brand & Model = Mac Mini
    Processor speed = 1.83ghz & 2.5gb RAM
    Connection configuration = (Selected) Network
    Print Driver = Brother HL-4070CDW series CIUPS
    Description of issue = My Brother HL-4070CDW is still very new and I've
    done a few printouts with it. I am noticing color spots on the left.
    menu, but didn't seem to fix the problem. I posted on fixya.com over
    here: http://www.fixya.com/support/t2060775-co...
    Seems someone else is having the same problem too, but with black spots
    on the left: http://www.fixya.com/support/t2128778-bl...
    Lastly, here are pictures of the problem: http://twitpic.com/4knub http://twitpic.com/4knr7
    Alarm Lights = My Brother HL-4070CDW is still very new and I've done a
    few printouts with it. I am noticing color spots on the left. Seems to
    didn't seem to fix the problem. I posted on fixya.com over here: http://www.fixya.com/support/t2060775-co...
    Serial number = U61780H8J284391
    from Brother USA site
  • 3,866 Answers
Replace the cartridge if that dont do it its the write head fouled up with ink or just plain died all togeather, dried ink can cause this to happen check and see if you can clean it out with 70 percent isp. alcohal if the issue still does not resolve its new printer time.
Posted on Apr 22, 2009
Some places does not print
you have a printer driver in pc
Aug 08, 2012 | Brother HL-4070CDW Printer
Hi. When we print color pages, on our HL-4070CDW, there are colors on the edges of the paper...usually on the right side of the paper. Sometimes it's yellow or red, etc. How do I resolve this?
You need to clean your corona wires. Go to Brother support website. Look for Problem 100000012419 and follow steps in solution 200000015852.
Sep 16, 2011 | Brother HL-4070CDW Printer
Hi I'm getting pink images from a Brother HL-4070CDW. I've tried recalibration and setting the colors adjustments in printing preferences, but that didn't change anything. Straight black prints fine. The...
It could be a problem with the bias voltages in the High Voltage Power Supply, but a much more common cause is simply a bad magenta toner cartridge. If the cartridge is fairly new, take it and a print sample back to the store where you bought it, and they might exchange it for you.
Mar 11, 2011 | Brother HL-4070CDW Printer
Why is there a hazy back ground to printing on Brother HL 4070CDW?
The DRUM is faulty, you need to replace it, but check first with Brother for warranty, they may replace it for free.
www.brother.ca
Jan 03, 2011 | Brother HL-4070CDW Printer
My brother 4040CDN printer (which I got yesterday), is now printing with spots all over the page. Any suggestions?
Take it back ... dont jeopardize your standing as a new customer with a new machine that may be faulty.
May 02, 2010 | Brother HL-4070CDW Printer
Brother 4070CDW Shadowing Problem
Check your toner if they are properly installed.
Check your drum if they are properly installed.
Clearn your toner and drum.
Print a test page.
If nothing happens please replace your printer drum
Sep 19, 2009 | Brother HL-4070CDW Printer
Black spots are appearing on the left margin of the page. It's only six weeks old, so I don't think it's the cartridge or drum. Is there another solution?
Brother e-mailed me back when I e-mailed them about my similar problem. Here is what was said:Printer Customer Service CAMay 6 Brother Customer: Thank you for taking the time to write us in regards to the colored spots print quality issue that you are experiencing with your HL4070CDW. Brother strongly recommends that customers do not use generic drum units and/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability. The Brotherlimited warranty does not apply to any problem that is caused by the useof unauthorized third party drum units, toner cartridges or toner. If you are experiencing white or color dots/spots on the printed pages, clean the drum unit: 1. Open the MP (Multipurpose) tray by pulling it toward you and lower itgently. 2. Pull out the MP tray support and unfold the flap. 3. Place 3 sheets of regular plain 20 lb paper in the MP tray or the cleaning sheet sent by Brother. 4. On the control panel, press the following keys one by one - OK, GO, OK. The keys strokes should not have any pauses between them. The display should turn an orange color and a zero should appear on the leftside of the display. 5. Press the DOWN arrow key until 31 appears on the display. Press the OK key. 6. Press the GO key. PLEASE WAIT appears on the display. The machine will pull one sheet from the manual feed tray. 7. DRUM CLEANING COMPLETED will appear on the display once the sheet hasbeen pulled through the machine. 8. Press the GO key again to feed the remaining sheets. 9. When the last sheet has been fed through the machine, press the CANCEL key. 10. From the Ready screen, print a test page by pressing the OK key. a. MACHINE INFO will appear on the display. Press the OK key. b. Press the DOWN arrow key until TEST PRINT appears on the display. Press the OK key. c. When the page has printed, press the CANCEL key to return to the ready screen. 11. Check the sample for dots: a. If the dots disappeared, the issue has been solved. Please keep in mind that the type of media, could introduce paper dust or spec#s that could adhere to the drum surface, contaminating it. b. If the dots still remain continue with the next steps. 12. How many dots do you see? a. If you see 3 or 4 dots in a vertical line (every 75mm or 3 inches), continue to STEP 13. b. If you see 7 or 8 dots in a vertical line (every 62.8mm or 2.5 inches), your toner cartridge has an issue, please replace the proper toner cartridge according to the color of the dots, we Brother strongly recommends that customers do not use generic toner cartridges, or refilltheir Brother toner cartridge. The Brother limited warranty does not apply to any problem that is caused by the use of unauthorized third party toner cartridges. Go to Warranty Options. 13. Press down on the front cover release lever and open the front cover by pulling it towards you. 14. Hold the green handle of the drum unit (labeled 1). Lift the drum unit up and then pull it out until it stops. NOTE: If you cannot pull the drum unit out, make sure that the front cover is fully open. 15. Remove the toner cartridge that is causing the dot, by holding the handle of the cartridge and lifting it up and out of the drum unit. Note: We recommend you place the toner cartridge(s) on a clean, flat surface with a piece of disposable paper underneath it in case you accidentally spill or scatter toner. 16. Once you have removed the toner cartridge, check in the open slot where the toner was installed for dots, smudges or paper spec#s on the drum surface cylinder. 17. If you see something out of the ordinary, please try to gently (do not scrub or use wiping motion, because this may damage the drum), cleanthe drum surface with a cotton swab until the dust or paper powder comesoff. You can spin the Drum in question by rotating it, with the gear located on the bottom left side of the drum. Note: The Drum is photosensitive, DO NOT touch it with your finger, and do not clean the drum with any sharp objects, because this may damage the drum. 18. After gently cleaning the Drum surface, reinstall the toner cartridge you removed. 19. Push the drum unit back into the machine until it clicks into place and close the front door. 20. Print a sample page. If the issue continues the printer may need service. If the printer is in warranty, call Brother Customer Service at 1-877-Brother (1-877-276-8437) for warranty options. If the printer is out of warranty, contact a Brother Authorized Service Center for repair by clicking on the link below: http://www.brother-usa.com/service/default.aspx We apologize for any inconvenience you may have experienced. Sincerely, Printer Customer Service Brother International Corporation Your opinion matters to us. Click the link below to take a quick survey regarding our email response. http://www.brother-usa.com/Surveys/Survey.aspx?SID=97 Original Message Follows: ------------------------ Email from Ask Us Customer: ======================================================= Sent: 5/4/2009 11:05:45 PMModel: HL-4070CDW Date of purchase = 02/17/2009 Operating System = Mac OS 10.5 Computer type = Apple Brand & Model = Mac Mini Processor speed = 1.83ghz & 2.5gb RAM Connection configuration = (Selected) Network Print Driver = Brother HL-4070CDW series CIUPS Description of issue = My Brother HL-4070CDW is still very new and I've done a few printouts with it. I am noticing color spots on the left. Seems to just be blue. I did a color calibration from the printer's menu, but didn't seem to fix the problem. I posted on fixya.com over here: http://www.fixya.com/support/t2060775-color_spots_left_margin_when_printing_hl Seems someone else is having the same problem too, but with black spots on the left: http://www.fixya.com/support/t2128778-black_spots_appearing_left_margin_page Lastly, here are pictures of the problem: http://twitpic.com/4knub http://twitpic.com/4knr7 Alarm Lights = My Brother HL-4070CDW is still very new and I've done a few printouts with it. I am noticing color spots on the left. Seems to just be blue. I did a color calibration from the printer's menu, but didn't seem to fix the problem. I posted on fixya.com over here: http://www.fixya.com/support/t2060775-color_spots_left_margin_when_printing_hl Seems someone else is having the same problem too, but with black spots on the left: http://www.fixya.com/support/t2128778-black_spots_appearing_left_margin_page Lastly, here are pictures of the problem: http://twitpic.com/4knub http://twitpic.com/4knr7 Date of purchase = 02/17/2009 from Brother USA site
May 01, 2009 | Brother HL-4070CDW Printer
Brother HL-4070CDW Printer Logo
1,844 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
