Question about Lexmark X83 All-In-One InkJet Printer
Lexmark x83 paper feed problem
When printing, paper feeds down 3 inches then it stops feeding and the feeder starts clicking continuously, until I pull paper up again. I tried to remove the printer casing to look for the problem but when I remove the only two screws visible on the back I still cant remove the casing.
I would also like to clean the underside of the glass.
Question: How do I access the paper feed mechanism to attempt a fix,
and clean the glass?
  • 3,866 Answers
If your not qualified to do this I would not sugges you do it, tho here is a solution for you. See if its snapped in place instead of being bolted down. you can also access underneath the unit hope this helps.
Posted on Apr 22, 2009
"My Mom's 'Lexmark X75' Printer Does Not Load Paper to Printer".
Please follow these steps it may help you , ....Good luck..
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck
Feb 27, 2009 | Lexmark X75 All-In-One InkJet Printer
Lexmark z2300 printer won't pull in paper
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 03, 2009 | Lexmark Color JetPrinter Z23 InkJet
Lexmark z715 problem w/printing
Good luck...
Nov 10, 2008 | Lexmark Z715 InkJet Printer
LEXMARK 2470 PAPER FEEDER PROBLEM
Good luck....
Sep 13, 2008 | Office Equipment & Supplies
Lexmarkx73 Won't feed paper through while printing
Jul 13, 2008 | Lexmark X73 All-In-One InkJet Printer
Won't feed paper while printing
I just obtained a printer with the same problem. When I opened it up I discovered a plastic gear that had cracked and was not turning the main paper roller as it was slipping. It looks like the solution is to replace the roller if you can find one or to repair the gear and epoxy back onto the roller. I am trying the later.
Apr 22, 2008 | Lexmark X83 All-In-One InkJet Printer
Paper will not feed into printer
Oct 17, 2007 | Lexmark X83 All-In-One InkJet Printer
LEXMARK X83 PRINTER 1) A few times papers jammed too far back to pull out from the front so i pulled them out the back. Now when the paper feeds there is a clicking noise and the papers feed only...
Oct 10, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 all-in-one printer
Hi gerby, need to eliminate a few issues to get to the cause. First, check for a jam. Paper jams can be so tiny you can barely notice them. Use a torch and check thoroughly down back of unit in paper feeder, open cover, let cartridge carriage roll left and settle. Now look inside thoroughly too. If no jam, check rollers are even and look same on each side. Post back if no good.
Sep 01, 2007 | Lexmark X83 All-In-One InkJet Printer
Paper Feed
Try turning the printer upside down and shaking it. Sometimes something small like a paper clip or Lego brick gets down inside and will prevent the paper from feeding.
Apr 04, 2007 | Lexmark X75 All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
386 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
