SOURCE: Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
SOURCE: Magnavox DVD recorder...finalizing problem
The manual isn't too helpful either - "Recording error other than below," it says. There are a couple of possibilities. The Philips/Magnavox/Funai recorders automatically record in VR mode when you use +R discs (there are two possible recording modes - V Mode and VR Mode). Is it possible that you have switched disc types lately? If you are currently using -R discs, switch to +R and vice versa. The manual states that +/-RW discs take a while to initialize.
I couldn't find a full factory reset on that one, so you may have to unplug the unit for about 20 minutes to restore all the defaults.
Another possibility: Finalization requires some extra space on the disc. If you accidentally pressed the button that changes the recording format between SP, EP, LP, etc., you may not be able to fit the same amount of video on the disc that you were able to fit before. You can change the format by pressing the Disc Mode button on the remote - LP Mode will fit 3 hours worth of recordings onto a 2-hr disc and is considered a "medium quality" recording. Try changing the Disc Mode to LP and see if it will finalize the next disc that you record. The downside of this possibility is that the discs that you have already made that are giving you errors are not "fixable" - you will will have to re-record the shows to a new disc in LP mode.
-Tha Mp3 Doctor
SOURCE: Funai VCR/DVD recorder DVR 2737. My -R discs
I was advised to try another make of blank discs. I bought Sony discs & they worked ok. I had been using supermarket own brand.
SOURCE: cAN RECORD FROM VCR TO DVD+R, CAN PLAY DVD ON
Usually you finalize the disc after loading it with all the desired content (leaving a bit of space for the finalization). So if you are recording a TV show, depending on the setting (SP, LP, XP), you might finalize the disc after recording 4 1/2 shows. The How may vary by model but on my DVD recorder, I find the finalize command in the same menu area as adding a title and initializing a DVD-RW disc. So I press Setup to enter the OSD menu, then go down to Disc (looks like an optical disc) then right arrow to enter the sub menu. Then press down to Disc Finalize and the right arrow again and press enter. Select OK and Enter again. (RW discs can be unfinalized to add more content.) Then wait until the process is done.
I hope this helps.
SOURCE: I have a SV2000 Vhs/Dvd Recorder. I can't seem to
Do I have to download something to be able to record vhs to dvd on my sv2000 dvd/vhs recorder?
