Question about Pioneer AVH-P4000DVD Monitor
Dvd movies I installed the unit and bypassed the parking break with a toggle switch but it wont show picture. it says press ok when i hit the toggle but then i get a black screen and all the audio. what do it do
    Problem Solver:
  • 5 Answers
Maybe you had the same problem as I did... the unit may have been dropped or mishandled during shipping or maybe during installation. If it is still under warranty, return it. If not, try this:
I took mine to a technician that went through the settings, found nothing wrong, except for the fact that it won't play video. What he did afterward was open the unit up and checked out inside. Apparently there was just some little plug that got loose and/or fell off inside. This probably happened during shipping or could have happened if someone dropped the unit I guess. Anyway he re-plugged the little plug inside and it worked fine. I'm still to pick it up and test it myself but this is what I was told today so just thought I'd share it with you guys. Maybe that's what you need to get done.
Please note that if your unit is under warranty (like mine WAS), this would pretty much void it.
Posted on May 27, 2009
I am about to install my boss bv8962 unit into my vehicle but I want the parking break safety feature bypassed. What do I do differently during installation so that my passengers will be able to watch tv...
Yes, you can bypass parking break feature by connecting the corresponding wire of BV8962 to ground, also you could add a 3 pin toggle switch to get a normal and bypass mode switch, this can be wired of this way, the common pin of toggle switch to your video unit, at the other pin, it could be connected the parking break wire (normal mode) and the remaining one to ground (bypass mode).
Feb 26, 2011 | BOSS AUDIO SYSTEMS BV8962 Car Video Player
Tip
Parking break bypass
just run the parkingbrake wire into one side of a toggle switch, and grond the other side of the toggle switch, When the WARNING pops up on the screen, just flip the toggle on then off then hit OK on the screen, Youll be good to go
on Apr 15, 2008 | Pioneer AVH-P5700DVD Car DVD Player
There is no video on my kenwood ddx8017, why? Do i have to bypass the parking break wire? which one is it, the solid green, or red with black, or pink?
If you want to watch videos on your unit it is necessary to bypass the parking brake wire from the Kenwood unit. The parking brake wire is light green and the best possible way to bypass the unit is by installing a toggle switch. The toggle switch should be a two wire device. Connect one wire to ground and the other wire to the parking brake wire from the unit. This will allow you to switch the supply on the wire to ground when needed.
Also, in some older Kenwood units you could just as easily connect the parking brake wire to ground and be done with it but, it does not always work.
Oct 08, 2010 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
No picture after bypass of pioneer AVH-P4000DVD
remove the toggle switch and pray you didnt do damage to your delicate stereo system
Sep 27, 2009 | Pioneer AVH-P4000DVD Monitor
I need to bypass brake for the jensens vm9311 so i can watch movies on drive
ok if you have the old firmware then all you need to do is ground the parking brake wire
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
Jun 29, 2009 | Jensen VM9510 Car DVD Player
Parking brake safety bypass
If you have the old firmware then all you need to do is ground the parking brake wire
Jun 26, 2009 | Jensen VM9510 Car DVD Player
Bypass parking break feature on the Jensen VM9311TS
You can purchase an aftermarket bypass kit from electronics store or off ebay... But hey, be careful, no watching movies while driving... K
Jun 05, 2009 | Jensen's VM9312 Car DVD Player
Navigaiton bypass/hack for Jensen vm9512hd w nav101
buy a 3pin toggle switch
add a wire to the red wire (12v) in back of unit
do the same with the ground (black)
now install theses wires to the toggle switch (toggle switch has pictures of ground and positive pins)
install the brake wire to the pin that is empty on the toggle switch
power everything including the new installed switch and DVD should show
if not just switch the brake wire with the ground wire on the toggle switch
but the navigation should work with the unit while your driving...........this is the real trick to solve your problem
good luck
Feb 27, 2009 | Car Audio & Video
Parking brake bypass
Tie the Parking break sensor to the ground wire, or ground it to a piece of the frame and your done ;)
Feb 11, 2009 | Pioneer AVH-P5000D Car DVD Player
JENSON VM9512 CODES FOR BRAKE BYPASS
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
Pioneer AVH-P4000DVD Monitor Logo
231 people viewed this question
Top Pioneer Computers & Internet Experts
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
