Question about Garden
Carburetor adjustment weed eater fl sst 25,will only run if held 90% to the right.
  • Anonymous May 02, 2009
    Too funny! =) My Sst 25 does the EXACT same thing! The doggone thing has always been "cold blodded", but it's gotten to where I can't keep idle unless it's tilted over.... Time for a carb cleaning, I suspect. =)
My machine didn't run idle either. Took carburator apart of the Sst 25. Cleaned it with gasoline and a brush. But no luck. Figured it must be the nozzle of the idle. There are two more or less hidden black adjustment screws for the nozzles (idle and gas). I used a plastic tube from a ballpoint to take screw out, ran some air through it, reassembled it and now the machine runs smooth again...
Posted on May 21, 2009
Weedeater pe 550 not getting gas
Posted on Apr 25, 2009
How to adjust the carburetor
What type of carburetor are you trying to adjust? two cycle, 4 cycle? Is it on a weed eater or lawn mower? This will be helpful to find the right answer that you want.
Oct 19, 2017 | Garden
My Husqvarna 324LX. Weed eater, Does not run well, Can I Adjust the Carpurettor
If it was previously running well, then the carburetor will not need adjusting, but it may need cleaning. If you have never done this before, take it to repair centre.
Aug 20, 2017 | Husqvarna Garden
Hard to start..will not rev. up
STIHL TRIMMER-WEED EATER REPAIR: stihl carburetor ...
? 6:55
www.youtube.com/watch?v=vK6MsQalprY
Sep 16, 2011 - Uploaded by JEREMY FOUNTAIN Here is what I did for my fussy Stihl FS 250r trimmer....this after sitting all ... STIHL FS80 FS85 FC85 HS80 CARBURETOR ASSY 41371200614 ...
Aug 07, 2015 | Stihl FS 85 Weed Eater
How can I start featherlite weedeater with poulan carburetor sst 25?
Your Poulan should have a green button on the side of it. Push and hold it. While most models have a green button, your may not. In that case, obtain the model number off the weedeater, go to Poulan.com/customer service and download the manual for your machine
Sep 01, 2014 | Poulan Recertified - Weed Eater...
Why does my fl-20 need the choke to run?
the carburetor is clogged. it needs to be cleaned. if it will run on choke that means that it is starving for fuel but if it runs at all it is an easy fix. just take the carburetor apart and clean with carburetor cleaner good and it will run like new. good luck
Aug 11, 2014 | Weed Eater Featherlite Fl20 Lawn Edgers
Where is the air adjustment screw located on a Feather Lite Fl 20C Weed Eater?
The adjustment screw on the feather lite can be flush in the carburetor but i do believe you'll need a special type screw driver to adjust that carburetor. I've seen some screws with splines on them and some with a slot. The air adjustment on that model is very finicky so take your time.
Jul 07, 2014 | Craftsman 25cc Gas Line Trimmer
I have a WEED Eater Model SST 45. I left the switch on all winter and now it won't start. What is wrong?
If it is a pull start, leaving the switch on did no damage to the weed eater.
Gary
Jun 29, 2011 | Garden
Craftsman weed eater wont run
MAKE SURE YOU REPLACE THE CARB GASKETS. ALSO MAKE SURE YOU ARE USING FRESH FUEL WITH THE RIGHT MIXTURE. COMPRESSION SHOULD BE AT LEAST 90LBS
Sep 24, 2009 | Garden
Garden Logo
2,893 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
