Question about Clarion ARX9270
Clarion ARX9170 I have a Clarion 9170 flip face cassette player and i need to find a wiring chart so i can hook it up in a 95 GEO Tracker.
  • 1 more comment
  • Anonymous Dec 07, 2007
    Very needed wiring diagram to the CLARION ARX 9170!!!!
    Help anywho!!!
  • gtquattro Dec 10, 2008
    I need wiring diagram for the Clarion ARX9170 head unit to identify RCA outputs black, gray and violet and a few of the power connections.
  • Anonymous Mar 15, 2014
    Colour codes please for a Clarion PU 9170 A car radio
    Problem Solver:
  • 10 Answers
Go to the12volt.com you can find it there.
Posted on Sep 24, 2007
Necesitaria el manual de instruccion de este estereo clarion arx 9170 les agradeceria que me lo mandaran a este correo gatogaston666@hotmail.com desde ya muy agradecido los saluda gaston desde argentina mendaza
Posted on Apr 07, 2008
What wires do I touch together to start a 95 Geo Tracker ignition switch going out
well there are 2 wires, like seen on "THE TERMINATOR"
one is ignition, and other is cranking.
its covered here , under how to do the hot wire. tests.
of starter. (we use a tool called a remote button)
http://www.fixkick.com/nocrank.html
the wiring is here.
page 1
see the center switch here, this is IGN
black-blue power feed, must go hot.
http://www.fixkick.com/power-elect/95%20electrics/95powersistra1.pdf
the new switch is here.
you will need new antitheft bolts,(or switch to generic)
http://www.rockauto.com/en/catalog/geo,1995,tracker,1.6l+l4,1142266,electrical-switch+&+relay,ignition+starter+switch,4700
May 21, 2016 | Geo Cars & Trucks
CAN YOU REPLACE A 1995 GEO TRACKER ENGINE WITH A TRACKER ENGINE WITH A CRANK SHAFT SENSOR???
what years? her ill give examples (no 1.8L sports)
in each case keeping original in/exh manifold of origional
this is called, a Long block swap......!
96 to 95 16v ok ( the crank sensor just sets there, doing zip)
96 to 95 8v no go. ( it will run by ECU while have fuel mapping)
95 8v to 96 16v no go ( missing crank sensor and mapping issues)
95v 16v to 96 16v,(missing crank sensor, move it.)
and you can swap any with harness and ecu. and manifolds.
see swaps here
http://www.fixkick.com/SWAPS.html#G16Bswaps
and links to near infintate swap data.
Feb 20, 2014 | 1995 Geo Tracker
Need a diagram for a 1.6 motor for a 93 geo tracker for the starter and alternator
old post
is this an electrical question?
the starter has 3 wires.
the ground wire goes to the starter mount bolt.
the hot wire Plus got the big , starter solenoid lug.
the small push on conn, only goes 1 places, the solenoid.
ALT
the lat has 2 connections.
the big lug ring lug, to the starter big stud
then just plug in the rear connnector
that be it.
from the schematic view and way is here.
Nov 18, 2013 | 1996 Geo Tracker 2 Door
Where is the "control relay" located in the vehicle. It has ignition wire and fuel pump wire hooked to it.
Front seating area, driver side, behind instrument panel, relay mounted on driver side of electronic control unit housing
Jan 29, 2010 | 1993 Geo Tracker
I need the wiring diagram for a 96 Geo Tracker
1996 Geo Tracker Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White
Car Radio Accessory Switched 12v+ Wire: White/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Yellow
Car Stereo Dimmer Wire: Red/Green
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): Blue
Right Front Speaker Negative Wire (-): White/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Light Green/Black
Right Rear Speaker Positive Wire (+): Gray
Right Rear Speaker Negative Wire (-): Gray/Black
Nov 22, 2009 | 1996 Geo Tracker 2 Door
Took over a 95 geo tracker project car. alot of mhands in there before me. haveing problems with the clutch cable linkage under the dash. either somethings missing or has wrong parts on it. do you have a...
the cable just hooks over the top of the clutch pedal.
Google Clutch cable and you will get an automotive site.
Select Tracker and you should pull up a picture.
There is very little to it.
The cable comes through the firewall and hooks on the top of the clutch pedal.
Hope that helps
Jul 17, 2009 | 1995 Geo Tracker
Clarion Model #PN-9881l plug wiring
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
Jan 11, 2009 | Clarion XA-311 Cassette Player
Geo wiring
the takes a motor
a matching harness from doner motor.
and an matching ECU.
we do this all the time on the suzuki forum
Oct 06, 2008 | 1995 Geo Tracker
Car Audio & Video Logo
906 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
