Question about Zanussi TC7114W Electric Dryer
Frigidaire Dryer Model FLGB43RG
My dryer starting burning and cutting my clothes across a life that is about an inch and a half. It started a number of weeks ago with just leaving small brown marks where it burned the clothes, now I'm finding "slash marks" on my clothes. Is there something wrong with a part? Will this require me getting someone to come and fix the machine or does it require a part replacement? Thanks!
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
Those "burn" marks if they have an arking shape to them are smudges from the felt that goes on the drum support above and bellow the door inside the drier. the felts wear out every five to seven years or so. easy repair. send me a model number and i could go into more detail. part numbers ect.
Posted on Sep 26, 2007
SOURCE:
Frigidaire dryer dryer will not run starts for 5sec then stops
frigidaire dryers have alot of problems with the control board,if it starts then fuses are good or it wouldn't run,does it start right up again?if so you have a bad board,if it doesn't start right up again the motor most likely is bad,any error codes?you could have a bad or broken wire somewhere in the dryer but like i said,they have alot of board issues,next time send the model number,if you know where the board is open up the dryer,unplug it first,then when you find the board plug the dryer back in and start it,when it stalls try tapping on the board,it might start again,if not unplug the dryer and look at the board to see if there's any burn marks on it or a bad soldier joint,also it might have a burnt smell to it.
Dec 31, 2017 | Frigidaire Dryers
My Frigidaire Gallery dryer squeaks and leaves brown crescent burn marks on our laundry items.
If you live in Pasadena, CA and you need a Dryer repair service our professional technicians will perfectly repair your dryer as fast as possible. All you need to do is to call at (626) 460-0903 or visit our website http://www.appliancerepairspasadena.com .
Dryer repair Pasadena CA Bosch LG Electronics Amana Beko
Sep 02, 2017 | Frigidaire Gallery Series GLHS269ZDB 36"...
My dryer has started to not dry my clothes completely and when it cuts off the back of it is burning hot. What is causing this??
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 28, 2010 | Frigidaire Electric Dryer
I have a stackable washer and dryer the washer works but the dryer when I turn it on it starts and the drum starts to role then it cuts off and I can smell a burning smell I am so tired of washing clothes...
a number of things but first unhook the electricity and take the back off the dryer look for burnt wires ect... it can be plugged with trash lent ect clean out the dryer including the blower wheel housing follow the vent to the housing that is it. Also the next biggest culprit is the elect motor its self if its bad you can order one from the company that made it or a number of companys on line(they will be cheaper) good luck and replace your belt while you are in there.
Aug 08, 2010 | Frigidaire Dryers
I have a stackable Frigidaire Gallery Dryer. It won't turn on...
turn the start and it's like the drum gets stuck. then starts smelling like burning.
Mar 05, 2010 | Frigidaire Dryers
PLEASE HELP! Dryer cuts off and gives an E68 code.
e68 code
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Good luck
Oct 05, 2009 | Frigidaire Dryers
Frigidaire front load dryer. Been getting
The front tub support needs to be replaced. It is a felt seal the tub rides on and is getting worn, and the sheets are getting between the drum and seal. no the dryer does not need to be replaced.
Mar 08, 2009 | Frigidaire FEQ332E Electric Dryer
Dryer to hot
your dryer has 2 thermostats in it more than likely that no1 thermostat has burned out it will need replacing usually when u buy the stats they come in a pack of 2 lower and higher temperature stats
Aug 15, 2007 | Frigidaire FWT449
Zanussi TC7114W Electric Dryer Logo
213 people viewed this question
Top Zanussi Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Craig Butler
Craig Butler
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
