Need to remove finisher
I have a savin 9032 that needs a broken (unrepairable) finisher removed, however i do not know what needs to be changed in the service mode to let it know that the finisher isn't there anymore, all i can get out of it is a c5 error code
The SP mode is 6-101. Set to "0" (no sorter), and press "#" to save setting.
please rate solution :)
Posted on Apr 23, 2009
Clean thermistors on Savin 8060
they are inside fusing unit and ride on the hot roller....what specifically do you want to know?
Apr 10, 2014 | Savin 8060 With Feed, Finisher, Print,...
Savin c2824 wont print pdf files
If its showing drivers for a different machine then the first step should always be to completely remove and reinstall the drivers for the correct unit.
Mar 02, 2012 | Savin Office Equipment & Supplies
I need to empty the waste toner bottle on my savin 2404wd. I need to know how to access it to empty it. Help!!!!
Remove the right side covers, loosen the leaf spring, disconnect the sensor and slide the bottle out to empty it. You may need to unscrew the sensor and clean it off as well. Reverse procedure to put everything back. Hope this helps.
Jun 30, 2011 | Ricoh Office Equipment & Supplies
We have a Savin 2545 copier. We received an error message SC 726. Can you give me some idea what we need to check?
That error is for the shift tray motor in your finisher where the copies come out. The tray should move from side to side when you switch the machine off and on. It sounds as if it is binding for some reason.
Mar 14, 2011 | Savin 2545DP Black and White Copier
Savin Copier 2020, IP 192.168.2.100 functional error SC672
yes a 672 is an address book error. do you have scanner feature on this machine?. it may be bad. you may need a tech to come remove the option. turn the machine on and use it as a copier. then reinstall the option and see if the error returns. it could be a static build up or the option is bad.
Dec 26, 2009 | Savin Office Equipment & Supplies
Error code E-4
You only have part of the error code. You need to hold down the "." key in order to get the rest of the code. Since there is only 3 error codes that begin with 4, I'll post them here so when you find out what the problem is, you can attempt to solve it.
E405 - Transfer belt/drum charge roller position abnormal
E440 - Main motor lock
E442 - Drum charge thermistor abnormal
It's most likely not the third, as this one doesn't normally cause the machine to stop operating. The first two can be reset by turning off the main power switch for a few seconds, then turning it back on. This will clear the error, provided it's not a hard error (one that reoccurs during the machines warm-up cycle).
Just so you know, due to the age, parts for this machine are getting hard to get...
Dec 16, 2009 | Savin Office Equipment & Supplies
Prep to ship Savin 4035 without damage
The main thing you need to do, is to remove the toner bottle assembly, drum unit and developer unit. There is a small black stopper you'll see once you pull out the toner bottle unit. Remove the stopper and the tray holding the bottle will slide out of the machine. The drum unit has a thumb latch on top of the unit and all you have to do is open the right side door, release the lever and remove the drum unit. DO NOT TOUCH THE DRUM! The developer unit is below the drum unit. There is one screw holding a silver piece of metal which secures the unit in place. Loose the screw and fold it down to the left and then remove the developer unit. These steps will keep toner and developer from spilling out into the machine. Good luck.
Jun 25, 2009 | Office Equipment & Supplies
Savin 3030
"user tools"
"System settings"
"interface settings"
Press the "ip address" button and set.
The model cross references to a Ricoh MP C3000 (Ricoh builds all Savin machines). You can get all the manuals here:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/mpc25/mpc25en.htm
Mar 12, 2009 | Ricoh Office Equipment & Supplies
Need to reset savin 3740 fax to factory defaults
Found documentation of Ricoh's website. They are the manufacturor of Savin products. The default access code is 2222. Entering this allowed me to get into the network settings and change the IP scheme.
Jul 25, 2008 | Office Equipment & Supplies
91 people viewed this question
jasbo
jasbo
