Question about Compaq fs740 17" CRT Monitor
Monitor is tilted forward and wont tip back
My cat sat on top of a compaq fs740 monitor and now it is tilted forward too much, I can't get it to tilt back. Please give me any suggestion to get it to tilt backwards again. Thanks.
    President:
  • 2,961 Answers
It will tilt back, just make sure the stand is in the forward most position and not turned and hold the screen at top and push while at the same time pull at the bottom, it will be quite stiff.
Posted on Sep 23, 2007
Tilt steering stuck in down position.wont tilt forward.
I am sure you have tried this but put it all the way down and let it lock. Then try and pull it back up. The problem will be if it stays stuck. I would wiggle the wheel at the same time. May need a third hand to help.
Feb 23, 2015 | Golden Technologies Golden CompanioN II -...
How do I tilt my Samsung 190s monitor?
If you mean tilt back/forward, grab the screen with your hands from both sides and tilt the top towards you are away from you.
If you mean rotate to get vertical instead of horizontal orientation, you should look at the back of your monitor to see if it even allows that movement.
Try downloading the User Manual if you don't have one:
http%3A%2F%2Fmypdfmanuals.com%2Fuser-manual%2CSAMSUNG%2CSYNCMASTER%2B190S%2C771044.pdf&ei=fwdgUvSCBoPiyAG_u4HgCg&usg=AFQjCNFYTlCuYjoHd4j7epiG7VRCpSalsw&sig2=iplcvOt8JdNoQqHqbG1g5A
Oct 17, 2013 | Samsung 190S (Silver) 19 in. Flat Panel...
How do you tilt screen back
just get hold of the top and bottom of the monitor and push it back or forward.
If it wont tilt with minimum effort, it may not have a tilt function, or it is broken, i have never had any problems with any monitor
Aug 26, 2010 | LG 22" FLATRON LCD Monitor
How do I tilt my screen?
just hold the bottom of the support in your left hand and apply force on the top of the monitor or lcd and the force should be in the downward direction. now you are through.
Dec 29, 2009 | Acer AL1916W 19" LCD Monitor
I cannot tilt the X191W display also
This monitor will tilt 20 degrees back and 5 degrees forward. It does not rotate.
Jul 23, 2009 | Acer X191WSD Monitor
Our viewsonic monitor tilts forward. how do we tilt it back?
Hello again.
The ViewSonic VG1930wm has a height adjustment range of 3.2", TILT capabilities, and a swivel range of 360 degrees.
So yes your monitor should be able to tilt back and forth.  Most likely if you hold the base of the monitor, and press somewhere on the front at the top or bottom (do not press on the screen itself) then it should easily tilt back and forth.  Occassionally there is a switch you may have to hold while you push on the front-top/bottom of the monitor which acts as a lock for the tilt angle.
Hope that helps, and don't forget to vote/rate!
Height adjustment range 3.2", tilt, swivel range 360º
Mar 12, 2009 | ViewSonic VG1930WM LCD Monitor
Tilt new monitor???
mcdevito75 here, I also have an Acer and it Doesn't tilt, that doesn't mean yours won"t, try to hold the monitor by the top and simply try to tilit it while makeing sure the base stays flat on the desk, (table) don"t force anything. Also look for any kind of screw, or handle connected to the base (bottom) or near bottom of back of monitor. Hope this helps. Oh! also check the manual that came with the monitor, mine has no mention of tilt. Sorry.
Jan 18, 2009 | Acer X191WSD Monitor
Screen tiled and i can't move it back
Try reseting the settings to factory defauts in the monitors user menu. You can get more details from the manual on this.
If reseting the settings doesnt work. Could you take a photo so we would have a better understanding of the problem :-)
Or do you mean the screen is fysically tilted? If parts are broken and you are unable to move the screen, then I cant offer much help, you could contact acer for support or to take it to a local pc shop for analysis.
Feb 08, 2008 | Acer AL2032WD 20" Flat Panel LCD Monitor
Urgent
goto desktop and right click their then click display then arrange 1024
Nov 15, 2007 | Compaq fs740 17" CRT Monitor
Compaq fs740 17" CRT Monitor Logo
211 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
