Cars & Trucks Logo
Posted on Apr 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My van makes clicking noise when going uphill & and sometimes the speeds slows right down and makes noise (clicking under vehicle).
My dodge van makes clicking noise when speeding going uphill. Or when i go 80km & up
Anonymous
Level 3:
President:
  • Master 710 Answers
  • Posted on Apr 23, 2009
Anonymous
Master
Level 3:
President:
Answers
710
Questions
0
Helped
351480
Points
2627
Could be front CV axles making that noise. Check out the rubber cv boots going from the transmission to the center of the front wheels, If the boots are ripped or cracked, replace the cv axles on both sides.
Does vss affect cruise control on 95 dodge van 3500
yes
the VSS (vehicle speed sensor ) communicates the vehicle speed to the cruise control to allow it to energize or stop when the vehicle speed is too slow
it does that through the ECM unit
1helpful
2003 dodge caravan will not start. Makes a clicking noise, and dash shuts off, then makes a humming sound.
im going to say an almost dead battery .the hum you hear might be the fuel pump.you never heard it before because the van normaly starts .so boost your van if it starts you may have to replace the altenator the guages, no worries many cars do that .thats a code needing erased and if you disconnect the battery that may go away.
Driving van down the road and the RPM shot right up and the vehicle started to slow down. Stepped on gas, no movement but RPM still went up. Stopped van and it would stay in park but would not engage any...
I had a Ford Winstar van that had this problem. There is an acceleration switch near the firewall on the passenger side that needs replacing. Unless you're very good under the hood, see a mechanic as it's a totall B**ch to get to the darn thing!
2answers
Speednomitar started to go up and down and when i had cruise on it was going fast and slow and now the speednomitar is not working
well at least you could honestly say "officer I wasnt speeding, actually I wasn't moving" lol
but on a more serious note, the problem mostlikely stems from the vehicle speed sensor which should be located on a front wheel, usually the left front but sometimes the right front. and they can sometimes be a pain to get to since they like to hide under the rotor right next to the CV shaft. this advice is based on the understanding that with the cruse control on the vehicle can't remain at a constant speed on flat ground.
2002 dodge durango whinning noise will your
Thank you for getting back to me. I would like you to check your transmission fluid. start the engine and let it warm up at idle speed for about 15 min and check the fluid. It sounds like you do not have enough in it, there for the whining noise with increase of speed since your transmission is speeding up with the rate of your vehicle. If this does not help and the problem persist please let me know. If the noise you were hearing was coming from the u joints of the vehicle it would not make a whining noise with increase of speed. The u joints will only make a noise when they are going bad when the vehicle is shifted into any gear from the shifter( EX: park to drive, park to reverse ECT.)
2answers
Won't start
the battery can be dead enough that a jump wont help
Blower Motor Slowing and making noises
Well if the motor is making noise the wheel could be broken or possibly gotten something in the cage where the wheel is. If the speeds of the motor dont work on any setting but high the resistor is out
1helpful
2002 Grand Caravan rattling noise and then some
have they checked front c.v. joints, as far as knocking noise it could be several things.
2answers
Rear noise coming from the back of my minivan
well usually this called detonation, also known as pinging. In most cars, this is caused by advanced timing or incorrect fuel octane. In your case, timing cannot be changed so going to a higher octane fuel will help. If you can find some, get some combustion chamber cleaner and add it to your gas. Sometimes, carbon deposits can cause pre-ignition/detonation
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
