Question about Lexmark X7170 All-In-One InkJet Printer
Trying to copy something and this error 2200 pops up and states refer to user guide
I was trying to copy something and this error 2200 pops up and states to refer to user guide
  • 14 Answers
Hi
This is a scanner lock issue. You may try the following:
Power off the All-In-One (AIO) off and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Try a test scan now. If the error reoccurs, then try the below:
Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover and check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover of the AIO and using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
If the error still occurs, you may insert the cartridges one at a time and re-check..
hope the above info is of use to you.. try out..!!
Posted on Apr 22, 2009
Show error 2200
The 2200 error code indicates that the scanner has stalled. That's why you're not able to make a copy. Please refer to this article on the Lexmark website to fix the problem:
2200 Error on the Lexmark X7100 Series All-In-One
Should the error continue to display, please don't hesitate to contact Lexmark Technical Support Center for additional assistance.
Dec 11, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I tried using store function but a pop-up states: "Variable or flash application is locked, protected, or archived." what do i need to do to fix it?
You may be trying to store the function in a folder that already contains that function or name. Its called Error Folder, and you will get the errors you mentioned. Try copying the function under the same name to another folder. Go to the other folder, the one you just copied your function too and, rename the function something you don't think will conflict with the original folder. Simply store your function with the new name in the original folder. That should work, and hopefully you won't get any errors.
Dec 21, 2010 | Texas Instruments TI-89 Calculator
Trying to connect my wii to the hotel wifi but, error code 52231 keeps popping up. What do I need to do?
if you refer to the rapair guide you will get the meaning for this error code 52231 .
click here to download repair guide,,,,,,,,,,,,,,,,,,, you can also use this repair guide for your future use.
Dec 10, 2010 | Nintendo Wii Console
Error msg: Unable to print It states to refer to
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Aug 22, 2010 | Brother MFC 210C All-In-One InkJet Printer
Won't copy, error message 2200 pops up and says to check manual. Manual doesn't reference that error message.
Try this - turn off the printer.
Remove the power supply.
Press the power button for 15 seconds.
Then plug it back in.
That should've cleared the printer!
Apr 17, 2009 | Dell 962 Photo All-In-One InkJet Printer
MESSAGE: SYSTEM ERROR (H4-00) REFER TU USER GUIDE
We had this problem when the power was fluctuating in our building. I called Sharp and they told me to clear this condition with the following code: #*C* and when the screen shows 00-00 enter 14 and press the green copy buton. This worked on the AL-1655CS. On the AL-1631 we had to do a similar thing: C<auto>C<auto> 14 <copy>
Jun 06, 2008 | Sharp AL-1655CS Laser Printer
Error message; no printing of text
What application were you trying to print from at the time. Does the printer give this error message all the time or only from this program? I need this info to assist you bzoe...lilacgerry
Aug 30, 2007 | Xerox WorkCentre M940 InkJet Printer
Print problem
Have you tried replacing the ink cartridge?
May 01, 2007 | Minolta magicolor 2200 DeskLaser Printer
Lexmark X7170 All-In-One InkJet Printer Logo
111 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
