Question about Acer Aspire 3680 Laptop
The CDRW driver cant be found
The computer CDRW is not working. The computer said that the CDRW32.bdb file could not be found. How and where can I download that driver from to make my computer cd drive work?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 40 Answers
CD R\W DRIVERS ARE DEFAULT PROVIDED BY WINDOWS WHICH YOU ARE HAVING IN YOUR SYSTEM.
THIS MIGHT BE DUE TO DEVICE DRIVER CORRUPTION.
JUST TRY SYSTEM RESTORE TO FIX YOUR PROBLEM.
AND DON'T FORGET TO RESTART YOUR SYSTEM AFTER DOING SO.
FOR SYSTEM RESTORE YOU CAN USE WINDOWS HELP AND SUPPORT.
Posted on Apr 22, 2009
  • 385 Answers
If you go to start, control panel, device manager, cd drive, right click it and click un-install.
Now reboot the system and test.
Hope this helps
Richard.
Need driver for Hitachi CDRW/DVD GCC4244
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
hope this helps
Jun 20, 2011 | Hitachi LG GCC4244N DVDROM CDRW Drive...
Device Driver for TDK CDRW 4800B. I uninstalled Itunes and then my TDK CDRW Drive no longer worked.
Have you tried another burning application? If not try CDburnerXP and see if it sees your cdrw.
http://cdburnerxp.se/
Good luck
May 03, 2011 | Computers & Internet
Data on a read only cdrw cannot be deleted from a Comaq pressario running widows xp
Dear sir,
your Comaq DVD drive is only a DVD R(Read) drive? or its RW(Read Write) drive.
If its simply DVD drive then it cant write or erase CD content. If its RW then you can. just use NERO software.
Mar 02, 2011 | Compaq Computers & Internet
Lettore cd-dvd DVD-16X-ROM BDV 316G non viene visto, ciò è accaduto quando ho installato MICROSOFT ESSENTIAL. L'ho disinstallato ma il problema persiste, ho provato MICROSOFT FIXIT, ma...
make sure that the cd-dvd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-dvd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
if this does not fix the problem might be a registry problem
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 07, 2011 | Microsoft BDV 316G 16x DVD-ROM IDE Drive...
My disk drive is stuck and will not read the disk. How do I fix this?
make sure that the cdrw/dvd combo is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cdrw/dvd combo then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device ?
control panel admistrive tools,computer management,device manager scroll down cdrw/dvd drives?right click you can? you can update driver,roll back driver,or select properties general troubleshoot, select driver? click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Dec 01, 2010 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
Just looking for a driver fro crwd 2400p cdplayer. The OS the driver is needed for is Windows XP. This peripheral is a PCMCIA cdrw dvd player and was bought from PSISM.com (they keep saying this item is...
Follow the steps given below
Connect the External CDRW to the PC and you should be able to find the green light glowing and CDRW should make some noise like spinning.
Press the Eject button the CDRW and It should open. Put in the Software disk that you have received from your PC manufacturer and it should display the contents on the PC Screen
If not, Click on START button - Click on My Computer - You should find the CDRW displayed in Drives Location.
Double click on it and it should display the CD Contents.
This indicated the CDRW is working.
Nov 09, 2010 | EXP Computer EXP CRWD 2400P (CRWD-2400P)...
The drive database cdrw32.bdb cannot be found i tied to replace file still didnt work now also says nti has stopped working
The following is installation instructions for CD-Maker Professional. For Backup Now, the instructions are the same, however, you will install it in the NTI Backup Now directory, rather than the NTI CD-Maker directory.
To install, please copy the "cdrw32.bdb" file use Windows Explorer or My Computer to copy the database file into the main folder for CD-Maker 2000 Professional. If you installed our software in a different directory then you will need to copy the file into your alternate location.
Example where database file is located:
C:\Program Files\NewTech Infosystems\NTI CD-Maker 2000 Professional
You can also use the find feature in Windows to find the exact location of the database file. Click "Start", the "Search", then "for Files and Folder", then type in cdrw32.bdb and click "Search Now". After it finds the file then you can read under the "In Folder" heading for the correct path where the database file is located. Use Windows Explorer or My computer to copy the database file into this location.
NOTE:
(1) It works only on full retail versions of NTI software
(2) For CD-Maker, it works for Version 5.1.1 or later.
(3) For NTI Backup Now, it works for Version 2.2.33 or later.
(4) For supported DVD burner models, CD-Maker V5.1.XX and Backup NOW! (and DriveBackup!) V2.X will support only the CD burning function of these models, not DVD burning. DVD burning is supported starting from Version 6.0 of CD&DVD-Maker, and Version 3.0 of Backup NOW! and DriveBackup!, respectively.
Thanks for using Fixya
Sep 13, 2009 | NTI Computers & Internet
FILE CDRW32.BDB
This is a driver issue. Try uninstalling the CD drive from the device manager, then reboot. It should find and reinstall the driver properly.
Jul 02, 2008 | Computers & Internet
CDRW32.BDB cannot be found
i think ur cd drive broken..
try to change it..
it will be can fix it..
thanks for using fixya..
good luck...
Apr 24, 2008 | E-Machines eMachines Desktop PC
Acer Aspire 3680 Laptop Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
