Question about iLO (2 GB) MP3 Player
Doesn't power up replaced batteries
I had the player plugged into the computer and was transferring files to the player. I unhooked the player and the screen went blank. I tried powering it up and the ilo screen would flash "ilo" and that goes blank. I changed the batteries twice.
  • 8,596 Answers
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
How can I transfer music files from Eclipse mp3 player to my computer
Plug in usb and choose to look at files then either copy or move the files from player file to computer
Aug 17, 2015 | Eclipse Audio Players & Recorders
No power plug. No Starts. Maybe this damaged.
Depends on the MP3 player you have. If it does not have a power plug then there may be a port for a usb to hook up to a computer where you would transfer your music files and that may power up the MP3 player or it may just run off batteries. Without knowing the specific model you have it is really hard to find a solution.
Aug 18, 2013 | Audio Players & Recorders
Hello trying to upgrade my HCT HBR-1000BP Blu-ray Player firmware and can not figure out how. No support on HCT website. Would be thankful for any help
Where are you having a problem? I found directions on: http://hcthk.com/mall/s02.php . There were two links, one with directions and one with an arrow for downloading the needed file.
The firmware is in a zip file. First extract the files from the compressed archived. (For a Windows OS, right click on the folder and select Extract All.) If needed, open the new uncompressed folder and put a blank CD-R or CD-RW in your optical burner drive. Burn the two files from the extracted folder to the CD (drag and drop will work for any version of Windows (XP-7).) Do not include the folder, just the files. Then finalize the disc (close the session). If you are asked to format the disc, choose a mastered burn (single-session). In Windows Explorer, you can do this by right-clicking on the optical drive in Computer (My Computer) or from the menu for the drive when you double-click on it. (Alternatively, if you have your system set to finalize on eject, then choose Eject. This setting is in the drive's Properties (the Recording tab).)
Eject the disc from your computer and turn on the HBR-1000BP. Place the CD that you burned in the player. When the disc is recognized, press Play. If that doesn't work, try entering the System Menu and choosing System Update with your remote. Do not power down the unit during the update; a power failure during the update might leave you with an unusable player.
If this doesn't work, check if the Blu-ray Player reads any CDs. If it doesn't, try cleaning the laser lens with a CD/DVD lens cleaner. Then try again. The Blu-ray uses a different laser. If no disc works and the lens cleaner doesn't help, the CD/DVD laser has a tracking (alignment) issue or another problem. You'll need to get the optical drive in the HBR-1000BP replaced or fixed.
If it does read a different CD, then check if your optical disc burned and was finalized correctly. Can another optical drive read it? Try burning the files to CD on another optical drive. (If you are using an external optical drive burner, make sure that the computer is not running on battery power. Plug the external drive into two USB ports if it isn't self-powered.)
I hope this helps.
Mar 31, 2012 | Televison & Video
I plugged my 1GB sylvania mp3 player into the computer wrong and now it won't cut on. what do i do?
Plugging in the player the wrong way on the computer may have fried it. If your computer can recognize and identify the files stored on the player when it is plugged in properly, copy the files to your hard drive for transferal on a new replacement mp3 player.
Sep 18, 2008 | Audio Players & Recorders
Mp3 file transfer
When you plug an mp3 into a Vista computer, it formats the player in a specific way - you will have to reformat the mp3 player on the new computer, which will end up erasing all of your songs - so, no, there is not exactly a way to do what you are trying to do - sorry
Jun 15, 2008 | Insignia NS-DV2G MP3 Player
I have Sanso m250 2.0gb mobel. Logo screen is appearing when i power on after that i am unable to play the mp3 songs or play FM Radio etc..
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second.
  2. Plug the Sansa into a computer4.gif, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC4.gif Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. I do not know if this will work on other Sansa m200 type .mp3 players. You can start over with your playlists. This has worked for me.
Dec 23, 2007 | SanDisk Sansa m250 MP3 Player
Sansa won't charge or load.
Plug it into the computer (the cord you would use to charge it and transfer files), and hold down the power button for at least 15 seconds. The Sansa should then begin to turn on and start charging. :)
Aug 07, 2007 | SanDisk Sansa e250 MP3 Player
Songs deleted
take out battery for a few seconds. replace it and turn on player. make sure battery has good charge in icon. transfer songs again. in realplayer make sure to hit the "eject device" button. DO NOT DO ANYTHING UNTIL PLAYER RETURNS TO NORMAL OPERATION it needs to place all in memory. goof luck
Nov 17, 2006 | SanDisk Sansa c140 MP3 Player
No response, no turn-on, dead player! help!
Same thing just happened to my M260, did you ever get an answer? Thanks, Jeff. Problem: No response, no turn-on, dead player! help!by mtx410 on Aug 28, 2006 I was loading files, when the transfer locked up, and the computer threw an error. i couldn't do anything but unplug the player! After I did this, i tried plugging it back in, and half of the world "initializing" popped up on the screen, the first half was missing! it did not do anything more. so i unplugged it again. Now when I plug it in, nothing happens. The computer recognizes that new hardware is plugged in, but cannot recognize what it is. Nothing comes on the mp3 player's screen. It will not power up when i hit the power button. It has no response, it acts like there is no battery in it. I have taken the battery out, and put it back in. Nothing happens when any of the buttons are pressed, or when it is plugged into the computer. Is there anything I can do to get this thing working again! It is the M260 if that matters.
Aug 28, 2006 | SanDisk Sansa m200 (2 GB) MP3 Player
Unable to clear non music files from mp3?
I'm a bit confused by your description, but you ARE talking about non music files... Is it possible at all that you deleted system files from your player? If so it really wouldn't respond. Try going into Recovery Mode; remove battery, hold power switch to ON, replace battery, release power switch when the Recovery Mode screen appears on the screen. Run Option 1 CleanUP, after it completes run Option 4 Restart. You will get a Rebuilding Library screen when it reboots, that's normal, then it should go back to your startup screen. Another thing to try is recovering you system files through a firware upgrade/install. I'm not sure it will work, but would you mind being a guinea pig? let us know how it turned out. Good luck
Jun 26, 2006 | Creative Labs Zen Neeon MP3 Player
iLO (2 GB) MP3 Player Logo
35 people viewed this question
Top iLO Audio Players & Recorders Experts
Inky Fingers
Inky Fingers
Damen Wong
Damen Wong
Rick
Rick
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
