Question about Korg Pa800 Synthesizer
I would like to change the pitch bend range in style edit mode- for example i would like to have it bend 12 notes rather than just 2. please help and thanks!
Hello :) I can help you :) First of all,press menu button.Then,on the screen touch MIXER TUNING.Then at the bottom of the screen press TUNING,and you'll find PB sensitivity.And then touch the number one the screen,which appears under PB sensitivity.At the end,just scroll tempo/value dial from 2 to 12 :) That's simple :)
Posted on May 19, 2009
My synth wont load when I power it on. can anyone help?
I suggest a hard reboot / initialize. Istructions are in your manual or on the Korg website
Jun 09, 2015 | Korg Pa800 Synthesizer
Pitch bend issues
Hi, try to find how to reset it or go to default mode,find out in the users manual.Hope it will solve your problem,
Oct 17, 2017 | Akai Ewi4000s Electronic Wind Instrument
Notes out of tune
No, but the pitch bend control can do that.
Apr 01, 2012 | Yamaha Mm6 Synthesizer Keyboard...
The pitch bend of my Korg pa500 Ort just stopped operating properly yesterday, the problem is that "up & down" is functioning normally but "left & right" is not working (no...
The first thing is to verify that it is supposed to work with a particular performance. NOT ALL voices support modulation as well as pitch bend and with an arranger you can turn this feature on and off, usually in the utility functions and then save the setting for each performance/song. Read you user manual about modulation. On page 271 of your manual they show that the joystick is assignable. You have to assign the functions to the effect you want.
Jul 30, 2011 | Korg PA500 61KEy PROFESSIONAL ARRANGER...
Pitch bender failure.
That is NOT a very descriptive problem statement... If all notes are off pitch but the bender still varies the tone, read about "transpose" in your user manual. Often the transpose or even the A440 setting gets changed and synth will be off pitch. If the pitch bender causes NO change then the control may have a failure.
May 13, 2011 | Korg Pa2X Pro Synthesizer
The profile panel I can't get it into the sound activation mode .
First select the A-08 to A-23 by pressing the MODE button. Then press the up/down button to select something in the A-08 to A-23 range. Now press the MODE button again until P-xx shows where xx are digits. Use the UP/DOWN button to select the speed. When the display shows P-So then it is in sound mode. Note the comments that high pitched or relatively quiet sounds will not be recognized.
Mar 10, 2011 | American DJ Profile Panel Rgb Led Effect...
Sometimes I face problem with my bendar. If I move it, it changes the pitch. To bring back to normal pitch,I have to move it couple of times. When I try to bend a sound which I used to bend always before,...
It sounds like the knob on the pitch bend control MAY be loose on the shaft or on the mechanism. Since this is a higher value unit, if you are NOT electronically adept, best to take this in for repair... It is probably a simple problem, but opening one of these can damage cables if you are not familiar with the unit.
Jan 03, 2011 | Roland FANTOMG8
I have 2 digital pianos and an xk3 Hammond but i find the xk3 is out of tune to the pianos. is this possible can you help me please Gordon
Ooften there is a setting for the pitch. Set it to A at 440 Hz which is usual standard. HOWEVER make sure it is really a pitch difference as the ear can be fooled by the "hammond" type sounds.
Dec 29, 2010 | Hammond XK-3 Lower Manual - Pro Style...
My tyros 2 has fallen down very bad.now the left bass octave is off pitch(half note Higher) when i play the keybord with the accompaniaments.It works right ONLY when the ACMP is disambled what can i do....
Likely you have damaged the pitch bending wheel and offset it.
Try to pull it on pitch with the wheel... IF YOU CAN, then the alignment of the detent of the wheel has been disturbed and unit will need servicing... There are a lot of screws to open this and several very tender cables that can be damaged... I would recommend you take it to a shop experienced on this keyboard.
May 16, 2010 | Yamaha Full-Size Keyboard
How could I set up quarter tone in a precise way, that I could control with bend control of EWI?
Here is a good forum to join:http://www.patchmanmusic.com/forum/ Depending on what you are using for a sound module, I would recommend setting the pitch bend limit or range on the sound module to what you want and controlling that setting with whatever setting you have on the EWI. Read your manuals carefully and you should be able to do it.
Mar 02, 2010 | Akai Ewi4000s Electronic Wind Instrument
Korg Pa800 Synthesizer Logo
251 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Korg Music Expert? Answer questions, earn points and help others
