Question about Motorola Mobility RAZR V3
Keypad goes to voice recorder
Anytime i try to use keypad, it buzzes then goes straight to voice recorder, which is now full. I have checked top and bottom connections and both are fully seated. When I turn it on holding down both # * keys, it goes to black screen for bootloading so I assume the keys are working somewhat. Any help greatly appreciated...ready to totally dismantle!!
  • 3 more comments
  • Anonymous Nov 08, 2007
    I have the same problem. I changed the keypad, loaned it to my sister. Then she pushed too hard on the keypad. I now have to replace the whole keypad again.
    rg
  • brokenphone Nov 30, 2007
    I have the same problem! Each button i press goes to the voice recorder, even when i hold down both # * keys.
  • GowerMeower Jan 05, 2008
    Has anyone had sucess with this problem yet? My phone is in a deep freeze. In the past it's worked it's own way out within an hour but now it's stuck and it's been 12 hours! All of my data is on that phone. I can't do a thing except turn the phone on and off.
  • Anonymous May 02, 2008
    NO MATTER WHAT BUTTON OTHER THAN THE POWER ON/OFF BUTTON MY RAZR V3 GOES TO VOICE RECORD. IT'S NOW FULL AND I STILL CAN'T GO TO ANYTHING IN MY PHONE
  • Anonymous Jul 24, 2008
    my phone is stuck on voice record i cant do anything other than turning it on and off.. and i tried everything.. someone help me
    New Friend:
    Problem Solver:
  • 7 Answers
Hey all...after i messed with phone for couple hours...and took apart, per the instructions i found online...still no workie, so i took sim card out and we had a spare old phone i used for couple weeks. when i tried the phone again...it worked. somehow it reset itself. i then made sure i transferred all numbers to sim card instead of storing on the phone. good luck to all with this problem....the phone store people told me same thing..new phone needed because of keypad...they just wanted a new sale i believe!! i also called cingular/at&t and asked them to resend whatever it is they send out that makes noise on the tv/computer if your phone is near it...i believe that is what screwed it up the first time, altho they wouldnt admit it. i am still using this phone with no futher problems as of yet!!
Posted on Mar 06, 2008
Try and shock the phone take battery out while phone is on then preform a master reset def code is 000000 that wil set phone back to defalt settings
Posted on Mar 05, 2008
  • 3 Answers
Doesn't help. Brought phone in for repair and was told "yeah, we've seen this alot" and the 'solution' was 'you need to buy a new phone'. Big help.... It is a fatal error in the phone mechanism, so be sure if you have this phone to back up what ya got somewhere.
Posted on Feb 16, 2008
  • 47 Answers
SOURCE:
Totally unresponsive to key imputs; display shows ERR
With any type of digital device such as this, there is a motherboard involved. When the buttons arent working, in your case, the solution is that the motherboard is shot. You could try to open the device and attempt to fix it or find repair service.
Apr 12, 2008 | Olympus VN-3100PC Digital Voice Recorder
I AM NOT CELLPHONE SAVVY ! I have an LG CG225. If someone is calling me and I do not answer and they want to leave a message, what do I need to do? create a voicemail box so they can leave a message? ...
Issues of accessing/setting up VM on your mobile or Inquiries on accessing your VM using your mobile phone?
I can help you w/that.there are 3 ways on accessing your VM via your mobile phone:
1st:
Long press the number 1 key on your phone's keypad then it'll dial your VM number and would ask for a PIN if PIN is setup.
Follow recording instructions or voice prompts and key presses until you get to hear your voice messages.
2nd:
For some mobile phone service providers,dialing your own mobile number automatically transfers you to your VM.again,if PIN is set up?it'll ask you to enter it,if not it'll automatically proceed to your VM.
Follow recording instructions or voice prompts as well as correct key presses until you hear your voice messages.
3rd:
Almost all mobile phone service providers has a so called "Voice mail Access Number"
This number can be dialled and goes straight to VM.
Voice prompts might ask you to enter your mobile number following the star key or pound sign on your mobilephone keypad.
Voice prompts might also ask you to enter your VM PIN(if seup).
Just follow Voice prompts and you're good to go.
Hope this helps.
Thanks,
FixerDelta
Sep 15, 2011 | LG CG225 Cellular Phone
My bass buzzes when im trying to record. I plug it straight into the back of my 8 track and it buzzes. When I touch the metal conection were the jack goes or touch the jack the buzzing stops. This is also...
The cause is a lack of proper earth grounding in the 8 track so your jack-lead is acting like a radio aerial. The solution is simple - buy a Direct Injection (DI) box to place between the guitar and recorder.
Feb 09, 2011 | Epiphone Thunderbird IV Electric Bass...
My motorola tracfone goes straight to a recorded messege when you call it...can i only use it to call out?
The reason your phone goes straight to the recorded message is because the voice mail of your phone is active.
To solve this is simple, all you have to do is to deactivate the voice mail.
To deactivate this, what you have to do is dial ##002# and send it.
Then try to dial your number again to see what happens.
Take care.
Jun 18, 2010 | Motorola Mobility TracFone w175 PayAsYouGo...
My LG VX6100 won't accept voice messages
Problem solved! Turns out that my son didn't realize that you have to call your voicemail box and delete voice messages by pressing "7" on the keypad. He thought that when you pressed "erase all" on the text message menu it erased voice mail, too. So the mailbox was full, as it only holds twenty messages. Sometimes the most obvious solution is the solution!
Jan 12, 2009 | LG VX6100 Cell Phone
Voice Mail recording
the voice mail key is the #1 key on the keypad as well it should have an envelope icon on the keypad as well, just press and hold the #1 key and follow the step by step instructions to setup you voice mail.
Sep 28, 2008 | Sony Ericsson W850i Cellular Phone
"full" message
I had the same problem; see earlier post about record times. The "format" solution worked for me.
Dec 19, 2007 | Olympus WS-100 Digital Voice Recorder
VOICE RECORD
Sounds like the phone may have gotten wet.
Check behind the battery, there is a white sticker that turns RED if its gotten wet.
Otherwise, there may be a short in the keyboard.
It may need to be replaced.
Best of Luck.
Oct 11, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
183 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
