Question about Fujitsu Siemens AMILO D-7830 Notebook
Will not load up
When i load the laptop up, windows set up starts to load, and then it say's, no hard drive
  • Dean Robb May 11, 2010
    "No hard drive" or "Boot device not found"? Two different things.
    Problem Solver:
  • 5 Answers
Do a check of all the devices that are connected to the the system. It could be that the Disk is out of place and need to be set back.
Posted on Apr 22, 2009
My toshiba wont load up windows
There are any number of reasons why this is the case, hard drive issues, or corrupted window files. Remove hardware and reseat back into position, hard drive may start, if not! use your recovery disc if available to reload windows to factory settings, if no change the hard drive needs to be checked by a professional.
Mar 07, 2012 | Computers & Internet
Windows can't find any hard drives...when installing xp
It sounds possible that your Windows XP install CD does not contain the necessary hard disk device drivers for the drive used in your Dell Vostro laptop and you would need to load these drivers separately during the XP install when the option is given to use third-party device drivers.
Some laptops may provide options in their BIOS settings to use a compatibility mode of operation for newer SATA hard drives that will make them visible to bootable utilities such as disk imaging software and older OS install CD's.
Jan 01, 2012 | Dell Vostro 1510 Laptop
Need factory settings aspire 5920
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operating, registry problems, virus problems, spyware issues and more. And a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
1.Back up all necessary data to an external device such as a disk, flash drive or hard drive
2.Make sure all programs are closed and shut down your Acer laptop by opening your Start menu and selecting "Shut Down" from the options for shutting down and restarting windows.
3.Detach any external hardware such as an external hard drive or printer.
4.Press the Power button to boot your Acer laptop.
5.Press "Alt + F10" on your keyboard when the Acer screen appears at the start of the boot up process. Wait a moment while Windows loads the reset files.
6.Select "Restore System from factory default" in the Acer eRecovery Management window.
7.Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration.
8.Click "OK" in the notice window to proceed with resetting your Acer laptop.
9.Wait while your Acer laptop is reset to factory settings.
Sep 06, 2011 | Acer Aspire 5920-6727 Notebook
I was looking for step-by-step install guide to putting new hard drive and loading Windows XP on my Dell Inspiron E1505?? I purchased a WD 320GB SATA hard drive to replace my dead 80gb hard drive....Dell...
All you've got to do is:
1) Insert the new hard drive.
2) Press the F8 key as the laptop boots. This will take you into the BIOS.
3) Locate the disk drive priority setting in the bios.
4) Set Priority 1 to your CD/DVD drive and priority 2 to the 320GB hard drive.
5) Save settings and exit the BIOS. This should reboot your laptop.
6) Insert the Windows XP CD.
7) It should not start the setup as it recognises the CD.
8) I will recommend that you format the drive before you install, go along with the format (make sure it does a full format).
9) After the format it will reboot your system.
10) You will be prompted with a message like "Press any key to boot form CD", DON'T press anything otherwise it will start all over again.
11) Now it should start the install. Follow the on-screen instructions.
Mar 15, 2011 | Dell Inspiron E1505 Notebook
My dell latitude e5400 will start up but will not load windows xp. After the dell screen comes up and the bar across the bottom of the screen becomes full it goes to a blank screen and the icon for the...
You did not post exat error ,I think Windows OS can not detect the sata hard disk.You can set up the bios for set drive sata to IDE ,or you can make the Windows cd, along with the ACHI driver for detect the sata Hard disk.
Please follow the bellow link .
http://www.raymond.cc/blog/archives/2008/01/21/install-xp-setup-did-not-find-any-hard-disk-drives-installed-in-your-computer/
OR can do another way.
http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Jan 17, 2011 | Dell Latitude E5400 Laptop
Sony vio vgn b3vp when loading windows wont see hard drive
Hi, your hard drive is partitioned for XP, go back to this stage of setting up the hard drive, delete patition and start again.
Jul 29, 2010 | Sony Computers & Internet
Xp won't load to hard Disk
Your RAM modules could be faulty or needs reseating. If reseating doesn't work, try swapping them around from the other laptop to see if that works.
Apr 22, 2009 | HP Pavilion dv8235nr Notebook
Problem with laptop
what i did with my toshiba was i took the harddrive out of the laptop and i had a computer store in town and they just plugged it into a backup device and transfered all of the info on to a set of disks for me only charged me $30 well worth it i didnt lose any of my information good luck !!!!!
Aug 05, 2008 | Computers & Internet
Can't install windows
IN THE BIOS SETTINGS LOOK AT THE HARDDRIVE SETTINGS THIS SHOULD BE WHERE THE PROBLOM NEWER LAPTOPS HAVE THIS BIOS SETTING THAT PREVENT XP INSTALATIONS. I REMENBER FIXING A SIMILAR PROBLEM. GOOD LUCK !
May 27, 2008 | Computers & Internet
Fujitsu Siemens AMILO D-7830 Notebook Logo
166 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
