Question about Thomson Lyra PDP2860 Digital Media Player
RCA Lyra RD2780A Button
Do you have or know where I can purchase the button button on the front of this unit, it is missing? (RCA Lyra RD2780A Button) Thanks!!!
  • Anonymous Apr 17, 2008
    driver
    Novelist:
  • 164 Answers
You can buy a non-working RD2780 media player in Ebay and use the needed parts.
There is not place to buy such buttons alone.
Best regards,
Posted on Jul 22, 2009
SOURCE:
Bad or missing sys folder
Keegan, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://voxrightnow.custhelp.com/app/answers/detail/a_id/9678/~/troubleshooting-the-rca-rd1080-digital-mp3-player
lyra 1080 bad or missing sys folder RCA Lyra
http://www.ecoustics.com/electronics/forum/home-audio/92143.html
Mar 02, 2016 | RCA Lyra RD1080 MP3 Player
I have a mp3 rca lyra radio and mp3 player. It
Do you have the RCA LYRA PEARL, with the folding out usb plug? RCA has made bunch of different mp3 players and has reused the LYRA and the PEARL name. Mine has both names on it, and the firmware file below is for model numbers TC- or TH-1602 or 1604.
One time I replaced my battery and my unit would not go any further than the Pearl logo. So, I downloaded the firmware upgrade from http://voxrightnow.custhelp.com/app/answers/detail/a_id/2243/related/1, and followed all the troubleshooting instructions that popup when you start the program:
start the program,
remove the battery,
hold the play button while plugging into usb,
release the play button the the term "initalizing" replaces "searching",
check the box that says "format data" (you can try it first without this checked, it may work and will save your music),
click the start button to replace the firmware.
After I did this, my pearl started normally, and my computer recognized it again.
Nov 24, 2009 | Audio Players & Recorders
Cannot get files onto device from PC
This unit is actually produced by RCA. If you go to their website you can download Firmware, and Software to update the unit. You can also try to do a "reset". There is a very small button on the bottom, if you press this with a pen and hold it for about 3 seconds it may start working again.
Apr 05, 2009 | Thomson Lyra PDP2842U MP3 Player
Key lock shut down
On the back of the player there is a button to the right. Above the button it says Off and below it there is a picture of a key. Switch the button upwards to turn the lock thing off.
Jan 08, 2008 | RCA Lyra M2030 MP3 Player
Rca lyra rd2780
?½ ?¥½?¼?????¯rca?₪©?´??§rd2780A?š??¸­??½??¨??·?¼Œ?Ž°?œ¨????°?¾??£?????š???®?¢?????¼??œ??Ž??¾?₪?“?¯·????°?®¾?½®?Ž?¼Œ????¸?usb??µ?¼????”
Dec 26, 2007 | Audio Players & Recorders
Not turning on
This happens to me on my Lyra MP3 player when my battery is low. If you have a fresh AAA battery in it, and it is in the right way and your lock on the back of your Lyra is OFF, and you still only get a blink, then you have a defective unit. Return it to RCA and get another one.
-Potter4
Dec 01, 2007 | RCA RD1076 MP3 Player
RCA Lyra RD1080 wont turn on
no the plasic is just to hold the batterys in to trun it on press the play botton some times you have to hold it down for a little bit or just press it and let go it could stick and to turn it off the stop botten press it 4 to 5 times untial it turns off. change batterys this unite is bad on batterys last about 2 or 3 hrs. is all i get out of mine had mine about 5 to 6 years
Nov 06, 2007 | RCA Lyra RD1080 MP3 Player
RCA LYRA MP3 PLAYER
Try the reset button on the back of the unit. This requires a pin or pencil point to activate. Note that this player must be disconnected from your computer by following the disconnect instructions in the owner's manual only, you cannot just unplug it.
Jul 12, 2007 | RCA Lyra RD2217 MP3 Player
My rca lyra rd1080b
this is the best solution you have update your lyra rd 1080/rd 1090 for download the updating click her http://download.rca.com/download/RD1080_90FWUpgrade_v4.26.exe and after instaling this update follwo instructions provided below ? To update your Lyra RD1080/RD1090, make sure you have it connected to the computer via the included USB cable. You will need to make sure that no external memory has been inserted and the Lyra RD1080/RD1090 display reads: "USB Connected Int. Mem". (If it does not, please refer to the users guide for the section on how to switch between internal and external memory.) ? Once connected, locate and run the Lyra Systems File Update Utility if it didn't open automatically. Installshield Wizard will have automatically created this icon on your desktop as well as under "Programs", "Lyra Personal Audio Player", "RD1080/RD1090" in your START menu. ? Click the "Refresh" button until the RD1080/RD1090 player shows up under device. ? Once displayed, highlight the drive letter by clicking on it, and click the "Update SYstem Files" button. ? When successfully completed, you will see the message, "The Lyra Personal Audio Player Device system files were successfully updated." ? Click the "OK" button, and then "Done". This will close the Lyra Systems File Update Utility. ? Disconnect the Lyra RD1080/RD1090 from the USB cable, turn the unit off and back on.
Apr 22, 2007 | RCA Lyra RD1080 MP3 Player
Thomson Lyra PDP2860 Digital Media Player Logo
135 people viewed this question
Top Thomson Audio Players & Recorders Experts
Damen Wong
Damen Wong
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
