Question about Dishwashers
Bosch Dishwasher SHU 995 - the on/off button has popped off of it's connector. How do I put it back on?
You need to remove the inner door to gain access to the switch, and replace the switch cap.
There are two parts to the switch, a black rectangular "cap" with the on / off logo on it, and the actual switch that lies beneath the cap.
In out case, you could move the cap to the side, and depress the switch with a tool.
Posted on Jul 14, 2009
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?
Welcome to FixYa.
I think can answer your question..."How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?"
Follow these steps...
**How to Operate the Cycle Completion Signal**
1. Open door, hold down program button (see
Beeper Table below) and simultaneously turn the unit "ON".
MODEL Program BUTTON
SHU 9950 Delay Start Hours
**SHU 9910-9920 Delicate/Econo** should be yours
SHU 8800/8810 Quick Wash
SHV 6800 Delay Start Hours
SHV 4800 Delicate/Econo
SHV 4300 Delicate/Econo
2. Release program button.
a. For SHV 6803 and SHU9950 models:
The display will blink with a code of "0", "1" or
"2". You are in program mode.
• If the display blinks with a "0", you will hear
no signal (indicates OFF).
• If the display blinks with a "1", you will hear a
LOW volume signal.
• If the display blinks with a "2", you will hear a
HIGHER volume signal.
b. For all other models with the beeper
function:
• If the machine beeps, then the Cycle
Completion Signal has been enabled.
• When you push the button again and it does
not beep, it means that the Cycle Completion
Signal has been disabled.
3. To change the program, press the program
button until the desired setting is selected.
4. Turn the Dishwasher off to take it out of
program mode.
* At the end of a wash cycle, the beeper will sound
off two times, and again every 15 minutes until the
dishwasher is turned off.
Hope this answers your question and provides you with what you needed.
Thank you for choosing FixYa and good luck.
Please take a moment to rate the solution provided and a short testimony if you feel it's warranted, but also let me know if you require further assistance.
Regards,
Macmarkus :)
Oct 07, 2010 | Bosch SHU9915UC Dishwasher
Bosch has discontinued making the front flip tine insert for the bottom rack. I have two broken in my Bosch dishwasher. Can I substitute another manufacturer's part?
A solution to this problem would be to sell me your dishwasher. The law firm for which I work is looking to acquire an old unrepaired Bosch SHU 33 dishwasher for some ongoing litigation. If you (or anyone else with this model Bosch) could send me some details regarding your dishwasher, you may be able simply to buy a whole new dishwasher. My email is JFraser -at- jshlawmi.com.
Thanks!
Sep 07, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
Bosch SHU 8805 upper arm is getting no water.
replace the upper water arm conduit and wash arm hub as they leak under years of pressure and the o-rings leak water and then it can't hold pressure and supply the upper arm with full pressure water,also replace the center arm conduit if it has one as this will wear out too
Mar 23, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Bosch SHU 43C06 UC17 dishwasher the dishwasher is just draining with no water in the tub, and is not filling, it does not seem to begoing out of drain mode
water in the bottomof the base remove side panel and dry out the bottom base . the float is up . thats why its in drain mode. bosch old tech speaking.
Oct 10, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
On/off control button on top panel of door is
a service call is necessary.usually that button support from one side breaks and needs to be replaced.it is not a expensive fix.
Aug 20, 2009 | Dishwashers
Burning plastic smell, big flash & now its dead - Bosch SHU8805UC
remove the water and, the burnt plastic that probanly melted on the dish drying heater coil
close and, lock the door turn the dishwasher back on and, reset the circuit breaker to see if the motor will run or, is damaged
Jul 01, 2009 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Our Bosch SHU 4300 dishwasher does not drain fully
There is a recall on the control board of many of these models, butyour problem is likely not related. A sticking impeller indicates that the pump may be failing, but you are welcome to try my guide to help. It is here. Thanks!
Jun 15, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
103 people viewed this question
Top Dishwashers Experts
