Question about IBM Wheelwriter 30 Typewriter
Wheelwriter 6, seems stuck on print delay
I've seen several references to fixing this, but they all point to hitting Print Mode, or talk about the display. Either this is a different series within, or it was a option that whoever bought this typewriter didn't choose to get, because I have neither a display or a Print Mode button on there.
Symptoms: Nothing types out until you hit enter, then it's fine. It started a week or so ago, not the biggest deal, but some of the people I work with are bugged by it, so I was trying to help out and 'fix' it.
Any suggestions? Or more information required?
  • smileypie03 Apr 23, 2009
    Well, it says "IBM Wheelwriter 6" right on the case, but there is no digital display on it. It looks like the one shown here.
    It's used in our mortgage department, and I'm not sure it's worth losing the memory over, there's a lot of programmed things that would all have to be redone etc. I think they would rather deal with the problem than have to re-enter it all. I was just hoping it was some button combination I hadn't tried thus far.
  • smileypie03 Apr 29, 2009
    The problem seems to be unimpacted by whether I'm in centering mode or not. They're already pricing new type writers to replace it, we just have to find something reasonable that will have the necessary features.
  • IBM Master
  • 3,594 Answers
If this a WW6 it must have the display option. there is a slide switch on the display that is set in delayed print.
DickyO
Posted on Apr 23, 2009
  • 1 more comment
  • Dick O Reilly Apr 23, 2009
    Just another idea, if you are in auto centering you will get something similar to this. If all else fails remove the batteries unplug for about a min. (WARNING ALL MEMORY WILL BE LOST)
    DickyO
  • Dick O Reilly Apr 29, 2009
    If you are in the centering mode code C you will get a delayed print.
    DickyO
  • Dick O Reilly Apr 30, 2009
    Another thought, I have had the experence that the add on display came loose from the machine and is dangling behind the desk and in the DP mode.
    We can sell you a reconditioned WW6 for 325.00 plus shipping.
    DickyO
IBM Wheelwriter 6 typewriter. The print wheel does not move when typing and acts as if in stencil mode
From your posting it sounds like you have cracked plastic print solenoid cap. We sell them for 20.00 with instructions.
DickyO
216-269-3918
Apr 29, 2014 | IBM Wheelwriter 6 Typewriter
WHEN YOU HIT A KEY IT ADVANCES BUT DOES NOT PRINT
If it prints when you hit return you are in delay print mode, press the print mode key on the R. of the keyboard. If it dosen't print at all the plastic print solenoid cap is broken. We sell them with shipping and instructions for 20.00.
DickyO
Cleveland Business Machines
216-241-0027
Aug 01, 2011 | IBM Wheelwriter 30 Typewriter
I have a a Lexmark Wheelwriter 3500 and it has the delayed printing function, well this does not seem to be working correctly it is typing before it should. what can i do to correct this problem?
If it types as you press the kets delay print is turned off, press the print mode key on the r
R. side until Dl prt is on the display. If it just starts typing at a the same position every time you probably have the R. margin set there and auto return on (CODE R).
DickyO
Jul 27, 2011 | Lexmark Wheelwriter 3500 Typewriter
When typing the letter don't appear
If they don't print until you hit the return key you are in the delay print mode, use the print mode key on the R. side to get out of it. If it isn't printing at all the plastic print solenoid cap is broken. We sell them with shipping and instructions for 20.00.
DickyO
216-241-0027
Jun 13, 2011 | Lexmark Wheelwriter 5000 Typewriter
Wheelwriter 6 stopped printing. everything works
Tou most likely have a broken print solenoid cap. We sell them for 20.00 includes instructions and shipping.
DickyO
216-242-0027
Apr 23, 2010 | IBM Wheelwriter 30 Typewriter
How do you turn off the delay print on Wheelwriter 30 seriesII?
On the R. side of the keyboard is a key that says mode or print mode press it and the DL PRINT will go out on the display and it's done.
DickyO
Nov 03, 2009 | IBM Wheelwriter 30 Typewriter
Someone used the typewriter and hit some code in error.
If it is in the delay print mode it will print when you hit ret. If this is not the case you probably need a print solenoid cap, they are available but a little tricky to install.
DickyO
Feb 24, 2009 | IBM Wheelwriter 30 Typewriter
How do i turn off the delayed type on a ibm wheelwriter6
at the very top right of your keyboard there is a "print mode" key
press this key until the note in the left lower coner of the display says "char print"
however in delay print you can correct mistakes before you print - saves on correction tape
Nov 17, 2008 | IBM Wheelwriter 30 Typewriter
Typewriter not printing
There is a plastic cap on the end of the print solenoid plunger that nis probably broken the part is available about 10.00 but a little tricky to replace.
dickto
Nov 27, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
Delay print
I found the answer to this situation: To turn off delay print function, Push the print mode button on the upper right hand control keyboard.
Thanks for the help!
Kathy
Nov 26, 2007 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
121 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
