Amana NAV3330E Top Load Washer Logo
Posted on Apr 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The drum wont hold water. it goes right out the draim
My Amana Distinctions top load washer was working fine about an hour ago, and now it wont hold water. the water drains into the tank and right out the drain hose. it's a non stop retarded cycle. any suggestions?
  • 1 more comment
  • sufferforaca Apr 22, 2009
    The PVC pipe for the drain is about 4 inches from the ground. The hose coming out of the washer is about 4 inches as well. the hose right now comes up a few feet and back down to the drain which runs to the basement. the washer is in my kitchen which is the first floor. all the pipes below slope down where they patch into the main drain for the house.
    thank you so much!
  • Anonymous May 11, 2010
    How high is disharge hose from the floor? if the drain hose is below water level it will drain out due to gravity.if it is in lower part of house and line is air tight to drain pipe it can vacume the water from unit when running water above level of washer. if this is case I can offer some ideas.
Anonymous
Level 2:
Scholar:
  • Expert 126 Answers
  • Posted on Apr 22, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
126
Questions
0
Helped
40291
Points
429
The drain needs to be above the actual water level or it will run out, the pvc should be above this point in order for the hose to get air and not act like trap and run out all that comes in,< woud suggest going to hardware store and getting piece to add on to 4 inch section with a coupler and washer drain cap>. they will cut to length, < take measurement of pipe size and length needed to get just bellow height of washer top, pvc goes together by cleaning and glueing, if the 4 inch piece has angle cut then it will have to be cut to strait line for good seal.
  • Anonymous Apr 23, 2009
    you are most welcome anytime
Amana top load washer overfills with hot water and wont stop unless you shut supply off. NTW5400TQ1
Okay you say only hot water if you unplug does water still come in if so bad inlet valve if it does it on both then the pressure switch is bad or there is a hole in the tube that goes from tub to pressure switch
Amana NTW4700YQ Top Load Washer will not drain
Hopefully you have it under warranty. You will probably need another wire harness. Double check your outlet to make sure it is grounded properly because they will 'nit pick' and tell you it is your fault for not having a properly grounded outlet.
Washer wont stop filling
Your washer ahs a float stop switch that controls the water level in your washing machine located behind the drum please replace it
Amana washer machine will not hold water. The drain hose is fine. What esle could be wrong?
The drain hose could be stuck too far down the drain pipe allowing it to siphon the water out.Also if it seals too tight into the drain pipe it will siphon the water out.
2answers
Amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
Hi, I have a 5yr old Amana Distinctions Super Capacity Plus top load washer, 2spd motor, 3.3 cu ft. I have taken off the front cover to expose the wash tub, because recently when the washer is in a spin...
sounds like a drain pump issue, not able to remove water quick enough before the centrifical force of tub spinning throws it over the top, remove the pump hoses and look for blockages
Stall in rinse cycle
loks as if its been amonth since this post, but i would chek your cold water supply, common problem
Amana Distinction leaks
this is a very common probelm with AM washer you have a bad upper sping bearing and at this point you need to cut your loses and send this one to the washer graveyard because this repair in labor intense
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
2answers
AMANA DISTINCTIONS FABRIC CONDITIONER RELEASE
Hello Daddy 2,
Welcome to fixya
I'm Huuum and happy to assist you,
What is the model number and the year of the washer?
Front load or top?
A waiting your response!
Huuum
Top Amana Washing Machines Experts
Virgil Watts
ZJ Limited
ZJ Limited
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
