Question about Sangean ATS 808A AM/FM/SW Radio
No reception sometimes
My ATS-808A sometimes will not receive a station for a period of time, then all of a sudden it will start playing. Then sometimes while playing and receiving a station it will all of a sudden stop receiving and the only sound is a faint static. Then, suddenly, it will receive the station again at a good signal stength. It is like the signal is strong one second and then no signal strength at all. Anybody know what is going on? Is it worth sending in for repairs? Thanks
    New Friend:
  • 8 Answers
Also dirty electrical contacts will cause this problem if it is not an actual component failure. While the radio is playing Gently giggle all controls that may have been hit by a slight impact to see if the reception goes away, changes or returns. This gives you the location of your dirty contacts. With the power off , opening the cover and gently spraying some contact cleaner directly into this control will clean them. (follow directions on the spray can) And close the cover when done.This will also usually clear up any crackling noises heard as you adjust a volume control or other potentiometer control or tuner in older radios. Simple dirty contacts has been most of the problems I have encountered on older radio repairs.
Posted on Nov 23, 2014
  • 17 Answers
Either this is typical shortwave reception characteristics, or you intermittent antenna connection.
Posted on Sep 06, 2009
SOURCE:
My vizio is set on avor antenna I have a HD antenna but TV won't pick up my favorite network stations wtva om nbc or abc
re-orient your antenna , the more the higher the better signal reception you will receive. and check your neighbor tv reception if they are facing the same problem with your tv , the problem isnt with your tv, its the tv network sometimes failed.
Nov 29, 2016 | Vizio Televison & Video
Troubleshooting
My Sangean ATS800A wont come on, battery shows
Jun 17, 2013 | Sangean ATS 808A AM/FM/SW Radio
Why does my receiver start stop producing audio output half an hour after turning it on?
Most likely is an intermittent solder connection opening up as set warms up.
May 09, 2012 | B&K CT600
I want to add an external antenna, is this product available to be purchased, if so from what stores and approx. how much will it cost. My Radio is a Sangean ATS 808A. Also, is a 220 Volt power pack...
Hello eab.... I would begin by looking at Radio Shack. Take the radio in with you. The prices cover a wide price range depending on the range and quality. Joe
Thanks for choosing Fixya!
Feb 26, 2011 | Sangean ATS 808A AM/FM/SW Radio
My Sangean ATS 808 AM/FM/SW Radio reciever shows a flashing E on startup and won't operate. Any answers on resetting or other solution?
Hello, I assume that this only happens when you are using it on batteries and the unit works when plugged into the mains. If this is the case it most likely is a faulty or dirty connection in the main battery chamber. Clean all contacts reload new batteries and try again.
Oct 17, 2010 | Sangean ATS 808A AM/FM/SW Radio
Dual xhd6425 Reception Problems
My XHD6425 seems to be very inconsistent... Sometimes I get okay reception, other times I get terrible reception (much worse than my original stock Ford radio). The reception problems are more noticeable on stations that are more than 30 miles away or so.
Perhaps oddest of all, I've sometimes had it bounce back and forth between two stations (like if you are driving and in the middle of nowhere, half way between two stations), even in areas where I know should be getting good reception on one station and had never heard of the other other station before.
If you've figured anything out, please let me know.
Jan 16, 2010 | Dual Electronics XHD6425 Car CD/ MP3...
Sangean ATS-803A - no audio
If its not a micro-p glitch, sounds like the radio was subject to a spike or surge wile plugged into the AC adapter. If the "power" light stays on all the time, thats what happened. Believe me, I was Sangean America's tech from 1990-1995.
Rob
The fix is to replace a transistor, or fet in the main pwr supply. (Close to where the adaptor plugs in.)
I wish I could give more details, but its been 14 long, long years.
Jun 03, 2009 | Sangean ATS 808A AM/FM/SW Radio
Sangean ATS 808A-replacement aerial antenna
The antenna should be available from Sangean, or C.Crane.
To replace the entire antenna, about 6 screws from the back must be removed, and the back also removed.
Or you could replace it at the antenna's "elbow". However, this is almost impossible to do without loosing the 2 tiny washers. If you do loose the washers, the antenna will work, but will be loose, and not stand up and support itself.
May 10, 2008 | Sangean ATS 808A AM/FM/SW Radio
GES050 undercounter radio/cd player
..just read about your reception/interference problems and, having lived through similar situations for some time — particularly with different weather conditions. The following solution has settled it all : wrap power cable around storage brackets at back of radio with a short length then wound around support posts (between radio and cupboard from which radio hangs), then run short length to power supply outlet. In my case this result comes after much experimentation with the length of unwapped power cord (including fully unwrapped and stretched out) and different patterns of winding around the support posts. This final result takes care of everything (better sound, no interference/loss-of-reception when moving around in the room or in front of the radio, weather has no effect, stations received that could not be before due to overlap by nearby, more powerful ones). I have only about 2 1/2 feet of cable running from the brackets at back of radio, then wound once around center support and half around right support to then go to wall and down to receptacle close by (I tried all kinds of combinations of unwrapped lengths and winding patterns around 1 to 3 posts)...individual cases may be different. so GOOD LUCK, 'cause the radio is great...!
Oct 26, 2007 | GE 7-5295 Undercounter DC /Radio Combo -...
Onkyo receiver playing in mono only
sounds like a reception problem. Is there a visual meter for the reception? Check your antenna.
Feb 02, 2007 | Onkyo TX-8210 Receiver
Sangean ATS 808A AM/FM/SW Radio Logo
529 people viewed this question
Top Sangean Audio Players & Recorders Experts
Pete Vernall
Level 1 Expert
Sock Puppet
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
