Question about Logitech Wingman Extreme 3D Pro Twist Handle Joystick (GAMELOXT3DPRO)
Too senitive can't control fx9 or fsx
I have adjusted the fs settings from one end to the other nothing seems to help .
Had a
ms force joy stick worked fine but wont work with vista...
    Problem Solver:
  • 5 Answers
First try the usual suspects. Uninstall *all* game controller software, reboot and install the latest Logitech drivers for your stick. Make sure you've got the latest Vista SP1 + updates. Make sure you're running the latest update of DirectX. Check for patches for your game. Plug the stick into a different port.
Check the physical movement of the stick - any springs feel broken/missing? Tension settings too high or too low? If all those are done, go in to the game controller calibration in Windows and calibrate. Test it - does the stick control the cursor properly? If so, but in-game you have problems, the problem is most likely related to the game code and unless they've released a fix, there's not much you can do.
If the stick has problems with calibration and you've installed any/all updates - likely a defective stick, contact your seller.
Luck!
Posted on Apr 22, 2009
All views move to different positions when connecting the yoke, cannot pan up or down only left or right when the FSX Options-Settings-Controls-Enable contollers is not ticked. When I "enable" Contollers I...
Hello
In the control options of fsx you need to delete the default keybind for the view you want assigend to your joystick.Then replace it with your controler axis.Or you can use the software and do your own program for fsx.The views in fsx have always been an issue or a problem with the game.
Also panning down in fsx and reverting back up has always been an issue or a clitch in the simulator.it does however work in fs version 9.
Using Fsuipc with a weather program or a virtual airline should not make a difference in control settings.
Jun 06, 2011 | Saitek Pro Flight Yoke System Flight...
Cyborg evo force joystick seem to chatter with or without force effects on or off in fsx and il2-46, i have remove all drivers and re-installed several time with no improvement,even disarmerd stick in...
You might clean out the registry of any left over values. Try it on another machine if it still does it, its something mechanical inside maybe stuck. I suppose its out of warranty? You cant fly with those stickers anyways if that's what you do. Scourer the junk shops for an old MS Sidewinder, they are still the best stickes ever made.
Jun 18, 2017 | Saitek CYBORG EVO FORCE Joystick
I own a Ch Products Combatstick 586 usb joystick. I also own FSX which is installed on a HP Pavilion Elite HPE 150t PC. How do I get the required control codes in FSX to link up with the buttons available...
Set all the buttons and controls up in FSX. Go to settings, controls and you will see your stick shown in there. Pick one of the tasks you want, press the button and it will assign that action to that button. Make sure you do this from the opening menu, not from within the game as this does not save it for next time.
When you have them all set, save the configuration file and give it a name you will remember. Forget the manager software. as long as you have the sticks driver installed the above will work
Mar 07, 2010 | CH Products CH Combatstick 568...
Same problem, different controller!
This is an assignment conflict. Check in your stick settings that the assigned key for droppable objects isn't the same as Close or shutdown FSX in the assigment menu. Good luck!
Sep 29, 2009 | Logitech Attack 3 Joystick
No force feedback only with Flight Sim. 2004
O-the sweet feel of a Microsoft Sidewinder Force Feedback lets see if I can be of some help. there could be any number of things going on but I'm going to give this a try. have you checked the settings in Flight Simulator 2004 seems to me that I remember a check box that said disable force feedback make sure that is unchecked. also in the settings for your controller there is a box that says enable force feedback make sure that is checked. then make sure if you are using a firewall like zone alarm you are in gaming mode because this used to give me major headaches with my system to the point I had to detach from the internet and shut down my firewall to play my games. if this doesn't work you may have to reinstall the drivers for the sidewinder this is the last easy option and it should repair any broke links and reset itself into your system. Please let me know how this helped if you need more Ideas just contact me.
Jul 24, 2009 | Microsoft SideWinder Force Feedback 2...
Sidewinder Percision pro joy stick is missing it's AC adapter
Standard 230V~ in and 50Hz out
0.15A
12V out 1.3A
Part No. 96749 Standard AC.
No special plug required, if you mean for the mains.
Jun 10, 2009 | Microsoft SideWinder Force Feedback Pro...
Thrust in FSX won't reach higher than 55% even with lever at full
This is either a calibration error, or a faulty stick. Nothing else can cause this. make sure you have the latest drivers installed or one's that it came with. Some operating systems will see the stick and load generic drivers which sort of work, but not fully. Always use the manufacturers drivers and install it using the correct route as in the installation as there are ways to install drivers that do not register them properly and you think they are installed but are not. Good luck with it.
Apr 05, 2009 | Saitek X45 Mouse, Joystick
MS FSX -view keeps switching from cockpit to spot view
The most likely problem here is that you have multiple assignments for the view change command set to multiple controllers hooked up to the system. They are conflicting with each other causing random view changes.
Firstly, go into Windows Control Panel and to Game Controllers. Remove any controllers listed in that box that are not currently connected or being used in your flight simulator.
Next, go into FSX, into the control assignments section...
Go through each controller in the drop down box (in the button/keys tab) and ensure only one controller has the assignment for view changes assigned.
Nov 23, 2008 | Saitek Pro Flight Yoke System Flight...
Right joystick
I don't personally know of anywhere that will replace the stick. If it truly is broken as you say, you will need to purchase another one. After all, it is broken.
Nov 11, 2008 | Microsoft MS Xbox 360 Common Controller...
Xbox 360 controller for pc
well, go to the settings of the game and then look about for controls.when you find it you should be able to change the controls.so you can make a fire button and so on
Dec 15, 2007 | Microsoft Xbox 360 Console
Logitech Wingman Extreme 3D Pro Twist Handle Joystick (GAMELOXT3DPRO) Logo
537 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
