Question about Toshiba Satellite A135-S4467 Notebook
CD drawer won't open or close or recognize blank disc
My drive D: suddenly stopped working after an intensive session of ripping and burning audio CD's.
could the problem be overheating?
Driver update needed?
Hard drive too full?
  • Shira Mar 19, 2015
    I destroyed a CD drawer/drive by verheating - too many burns too quickly!
    If it's still alive, stick a bent paper clip into the tiny hole to open it - and never push it shut!
    Problem Solver:
  • 5 Answers
Not very likely to be overheating. CD's don't really have drivers & if it was working OK then a firmware upgrade isn't needed. Full drive won't cause the problem.
Pretty much the drive has just died. If the motor runs when you hit the door button but the tray doesn't move - try *gently* pushing the door closed. If it doesn't go - new drive.
If the motor doesn't run when you push the button, you can check to see if the power cable somehow came off but that's extremely unlikely. Most probably you'll just have to get a new drive.
If you've been in the habit of pushing the tray to start it closing, stop!! That's the most common cause of your kind of problem. ALWAYS open and close with the button.
Posted on Apr 22, 2009
I have a technics SL-CH505 compact disc but it will not play burnt CD;s any suggestions my other technics SL PG 400A plays them noproblem
The Optical Pickup(laser) may be weak. It takes much more power to record than play, which I guess it works.
Oct 13, 2014 | Technics Audio Players & Recorders
Sharp CD-BA2100 cd drawer won't turn or close.
Take the 4 screws out of the top, lift the CD drawer out, disconnect the two wire harnesses, take the top off, lift the 3 disc tray out, then force the drawer open and closed a few times until it slides freely. Put it back together and it may or may not work. Worked for me.
Mar 28, 2013 | Sharp CD-BA2100 CD Shelf System
When I try to burn data files to a CD-R disc on my toshiba satellite M1115, it repeatedly tells me to insert a disc, when I have put a brand new disc in. I have used the drive to burn music discs &...
It sounds like you are trying to burn too much data onto the disk. If you want to test this theory, you can burn a small amount of data to a blank CD-R to see if it works. If it does then you do not have a hardware problem. This will be good news.
There are different sizes of CD-R media, 650MB, 700MB and larger sometimes. If you select 700MB and try to burn to a 650MB media disk, the drive will just spit out the blank disk so as not to ruin it for a future burn. Also, if you are going to make a multi-session disk (or you have accidentally selected multi session, then you will automatically waste 22 MB leaving you 650-22 /628 MB, or 700-22 or 668 MB of space to burn your data. Each additional session will also take up 22 MB of space.
There is also a chance that the media you are trying to burn to is not compatible. Some lower end brands do not use enough reflective material for some burners. You can test this theory by trying an alternate brand of media.
Aug 30, 2011 | Toshiba Satellite M115-S3094 Notebook
Toc error 14
On questions like this it would help if we knew the manual was or was not consulted.
And if it was NOT, why.
C14 / TOC Error The unit did not read the TOC information. Insert other discs.
http://www.cdrfaq.org/faq02.html#S2-19
[Extract]
"If you write data to a disc and leave the session open, the TOC -- which tells the CD player or CD-ROM drive where the tracks are -- is written into a separate area called the Program Memory Area, or PMA. CD recorders are the only devices that know to look at the PMA, which is why you can't see data in an open session on a standard playback device. CD players won't find any audio tracks, and CD-ROM drives won't see a data track. When the session is finalized, the TOC is written in the lead-in area, enabling other devices to recognize the disc.
(Something to try: write an audio track to a blank CD, and leave the session open. Put the disc in a CD player. Some players will deny the existence of the disc, some will spin the disc up to an incredible speed and won't even brake the spindle when you eject the disc, others will perform equally random acts. The TOC is important!)"
Mar 02, 2011 | Sony RCD-W500C 5-Disc CD Recorder
I am trying to burn an audio CD with Roxio. I can get it to burn but my stereo will not recognize the disk as Having anything on it. I have tried several different things and it isn't working. What can I...
Try a different type of CD. If you're using CD+R discs, change to a CD-R and see if it works better for you. Also, make sure you finalize your session to verify that olde CD-ROM readers will read the disc. If you're burning MP3 files, make sure you're converting them to audio files on the way to the disc, as older stereos will not read MP3 files.
Feb 14, 2011 | Mad Dog Multimedia USB 2.0 External Drive...
Cd burner makes blank cds
try isolating the problem by plugging an external cd/dvd drive via the USB. use this to burn CD/DVD if the process works, replace your laptop dvd drive.
Jul 07, 2009 | Dell Dimension 4600 PC Desktop
I have an old e machine Tower Mod.667IR S/N QA309-108-O2995 no manual on hand. Please advise correct drawer ID. Top drawer C or D ? Mid drawer C or D ? Which drawer is the Burn drawer? Bottom...
Your master hard drive will be C, slave hard drive or top media drive will be D, and so on unless you have reconfigured them from the factory setup. Floppy disks only have 1.44 megabytes on them, so easiest way to copy data from them is just to drag and drop all the files into a folder on your desktop. Insert a blank CD-R into your writeable drive...win 2000 will open a blank cd window. drag and drop the files you wish to copy into the blank cd window and click "burn these files to disc". A CD-R has 700 megabytes on it, so roughly 675 floppy discs can be copied to a single CD-R.
Jun 20, 2009 | E-Machines etower 667ir PC Desktop
Won't recognize an MP3 format CD
Usually a disc with audio files is not encoded with MP3's, but, rather, audio files. You can check this by manually opening the disc (right click on the player when the disc is in it), and looking at the files. If you only see marker (files of a few kilobits) in "MP3" format, then the disc needs to be "ripped" into MP3 format.
The ratio for audio to MP3 is 10 :1--this means a CD of 700 MB size with 10 tracks will become an MP3 collection of 10 tracks approximately 70 MB in size (this is a standard 128kbps audio quality CD) If the encoding is less (64 or 32kbps), the size of the resulting MP3 is smaller.
The hands down best ripping software to convert your audio CD to MP3's is called Goldwave. Although Nero and Winamp have functionality on a limited basis for this task, Goldwave is a far superior software package to not only rip, but also edit your creations. Once you have installed Goldwave, you use the OPEN CD button to read your files---then save them to your hard drive (in what CODEC or quality you want---MP3, Apple AIF, OggVorbis, etc.etc
Mar 27, 2009 | Pioneer DVR-107D DVD±RW Burner
CD Burning gets stuck
Try this: : Decreasing the burn speed If the drive is not recognizing the disc at all, skip to Step 4. Decrease the CD writer's burn speed by half to increase the likelihood of a successful burn. Decreasing the burn speed is a quick, easy way of increasing successful disc burning sessions, at the expense of taking more time to create a disc. The following steps are for Windows XP only. For Windows 98 and Me, decrease the write speed from within the software that you are using to write discs (RecordNow, Easy CD Creator)
  1. Click Start , and then My Computer .
  2. Right-click the drive icon, and select Properties .
  3. Select the Recording tab and reduce the Current Write Speed by half (for example, from 16x to 8x).
  4. Click OK and close the My Computer window. Try burning a CD. If the drive fails to create the CD, go to the next step.
Step 4: Setting up disc recording in Windows XP If the computer does not have Windows XP, skip to Step 6. If you are using Windows XP, use the following steps to ensure that native burning is enabled:
  1. Place a blank disc into the drive. NOTE: If the error <drive letter> is not accessible. Incorrect function. " opens, close it and continue using these steps to correct this problem.
  2. Click Start , and then My Computer .
  3. Right-click the writable drive icon, and select Properties .
  4. If a Recording tab is shown, select the Recording tab, select Enable CD recording on this drive , and then click OK . Try burning a disc again. Continue to the next Step if you are unable to burn a disc. If a recording tab is not shown, continue using these steps. Figure 2: Enable CD recording on this drive c00368150.gif
  5. Look for a Recording tab: If the Recording tab is not shown, Windows XP has not detected the drive as a recordable device. Use the following sub steps to enable the Recording tab:
    1. Click Start , Run , and type regedit in the Open field.
    2. Backup the registry: Select My Computer from the list, click File , Export , type a name that you will remember, and click Save .
    3. Click OK , and browse to the following registry key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\Drives
    4. Click the Volume key that matches the CD/DVD drive that is capable of writing discs. If only one drive is installed, one volume key is listed. If you have more than one drive, examine the data values (by double-clicking them in the right pane) to find the correct drive.
    5. With the volume key selected in the left pane, double-click the Drive Type value in the right-pane. Figure 3: Drive Type registry value (CDRW) c01367502.jpg
    6. Type the number 1 in the Value Data field if the drive is capable of recording to CDRW discs (including CD-R discs). Type a 2 if the drive cannot write to CDRW discs but can burn CD-R discs. NOTE: A value of 3 indicates that the drive is only capable of reading discs. Changing this value to a 1 or 2 enables Windows to view the drive as a recordable drive.
    7. Click OK , and close Registry Editor.
Jun 20, 2008 | Dell Dimension 4700 PC Desktop
Not recognizing disc in D drive
Hi, well the short answer is NO. You cannot use DVD's in a CD Writer at all. So the simple answer is to get some CD-R and copy the files to them. OR get a Combo DVD/CD writer and install that as well.. and then you can use both..
Aug 06, 2007 | HP (178373133) (Refurbished) (178373133)...
Toshiba Satellite A135-S4467 Notebook Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
