SOURCE: emmerson microwave oven and grill
mcdevito75 here, Follow the directions on the frozen pizza package, Or simply microwave at 2 minute intervals till the pizza is done or fully heated up.
SOURCE: I need to fin out
Without a manual your best bet is to remove the old fuse and look for the rating stamped on it. You can find a replacement at a Radio Shack or home improvement like Lowe's Home Depot or Value Home Center.
Question edited for clarity.
This is what it looks like. A standard SES Appliance bulb
https://www.ebay.com/itm/314808284288
Normally there is a door on the outside case. Some you have to remove all the case. Directions here. Make sure you keep away from the Capacitor and Step Up Transformer as it will make your hair curly.
https://www.wikihow.com/Replace-a-Microwave-Lightbulb
Hello - This may or may not be specifically for your model, however these are generics instructions that I found.
To replace the light bulb to the over the range microwave you will need to follow the steps below:
1. To replace light bulb, first disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
2. Remove the vent grill mounting screws.
3. Pull the vent grill away from the unit.
4. Remove the charcoal filter by pushing it inwards, then turn and pull it away from the unit.
5. Open light cover located behind filter mounting by carefully pulling up on the front edge.
6. Remove old light bulb and replace only with equivalent 30 watt bulb available from part distributor. Bulbs are also available at most hardware stores or lighting centers.
7. Replacing the microwave oven light cover by carefully pushing into place. Replace the charcoal filter. Push the vent grill back into place (engaging both the bottom and top tabs) and replace the vent grill mounting screws.
Note: DO NOT USE BULB LARGER THAN 30 WATTS.
Hello
& Welcome to FixYa
To
replace the light bulb first remove the screws located on the vent grill at the
top of the microwave, tilt the grill back and then pull away to remove. After
this open the light cover , you have to remove the screws so that you can
discard the old light bulb and then replace it with a new one. Please get back
to me if you have any other questions.
Kevin
