Question about Palm TX Handheld
I get an (Sys 0505)(0,841) Error when I try to Hot Sync or go to
I am trying to Hotsync to my new Laptop. But I keep getting the Error
(Sys 0505)(0,841).
  • 23 Answers
Try Uninstalling and reinstalling DocsToGO
Posted on Oct 06, 2009
Hotsync Problem with Sony Clie PEG-T615C using XP SP3
Maybe you could also try updating Palm Desktop or maybe downgrading Palm Desktop because I have that exact same PDA and I know it's old. If neither of those work, just pull a system restore or whatever you had planned.
Dec 23, 2009 | Sony CLIE PEG-T615C Handheld
Hot sync
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,t=ooccase,case=obj(2630)
With your Palm Zire 21 connected to your pc, go to the link above and run through the Palm HotSync troubleshooting dialog to see if any results come up that will solve your issue.
HotSync issues are unfortunately difficult to pinpoint and often will require a software update or patch to resolve issues.
Good luck with it!
OpenSource13
Apr 08, 2009 | Palm Zire 21 Handheld
HotSync error ((sys 0505) (0,841)
I also had this problem. Searched for a solution and found that the error message refers to older programs incompatible with newer models of the palm. If you do a Hot Sync on a different and/or newer model palm device there may be these incompatibilities. The usual problem programs are mypalm and mytreo. You need to delete them by
first doing a Hot Sync
going to Applications on the palm
tap on the menu icon (or the left upper corner of the display)
tap on Delete
go down the list to delete each of these programs.
Hot Sync problems should stop
If not, you need to do a hard reset and then slowly add third-party software one by one and look for problems.
Jun 23, 2008 | Palm TX Handheld
Z22 when downloading games and I hotsync I get a message of error interrupted
Please post your hotsync log.
Whats the name of the game (and .prc filename)?
Jun 20, 2008 | Palm Z22 Handheld
Hotsync problem error code: 32
I'd suggest deleting the video and try sync again.
Jun 09, 2008 | Palm Treo 650 Handheld
Garmin ique 3600 hot sync issues
I had the same problem. Obtained no help from Garmin - $200 to repair.
I purchased a $7.00 IRDA (infra red) - USB device; set my Connection to IR - PC and have been able to sync without any problems. However even withupdates I have not been able to get the cradle - PC connection to work. This is not a problem however since I now use the IR connection all the time.
You must touch the screen hot sync logo not the cradle button to start the sync process.
Feb 22, 2008 | Garmin iQue 3600 GPS Receiver
Hot Sync with desktop and laptop computers
it is possible but if I well understood u wanna hot sync with ur laptop calendar and contact from ur Tungsten E, (that is having updated data from ur office computer). you can in fact synchronize verything there with ur laptop, and make ur hand held over write ur whatever is in ur laptop, for this u need to install the PDS and go to the hotsync manager on ur system try, go to custom and and on the list of conduits go to contact and change the action to hh overwrite desktop, (do the same for calendar) DON"T FORGET TO CHECK THE OPTION : MAKE AS DEFAULT. U can of course disable the rest except the system conduit. Never forget to set the conduits u change to set as defaults. Like this, u must have always updated data on ur hand-held, for this, u need to keep synchronizing with ur office computer. good luck,
Sep 12, 2005 | Palm Tungsten E Handheld
Asks for password after Hotsync button pressed
Try looking at (from the main applications menu) Preferences, then Security. I have a T5, so the operating system is likely different, but there are two passwords there that can be enabled...password and quick unlock. I know if I push the hotsync button on my cable to sync before I unlock the T5, it will prompt me for a password. You can also try making sure you are logged in and have access to your Treo "before" hitting the hotsync button. On the T5, if I'm already on the T5 and hotsync I don't get prompted for a password. If this is totally off-base due to the differences in the T5 and Treo, I apologize for the confusion.
Sep 12, 2005 | Palm Treo 600 Handheld
Error message using IrComm port
Hi, Right click on hotsync manager at the bottom right corner of the pc , make sure only local serial and ir is having a check mark , if anything else has check mark , just go to that and do a left click , it will get unchecked . On the handheld tap on home , on the main page u will see hotsync icon , tap on that , on the hotsync page make sure via ir , and not cradle or cable , then at the top u will see hotsync in words , tap on that , in the drop down u will see lan sync pref, tap on that and make sure lan sync is highlighted , and not local hot sync , since local hotsync is usefull only when u perform cradle or cable hot sync using usb , then click on ok , try a hotsync . If this doesnt help and again u get the same error , do a soft reset on the handheld and on the pc , go into hotsync manager , click on setup , choose local , change the com port to a different port and reduce the speed to 9600 , click on ok restart the pc and again perform a hotsync . The error u got was coz of this , on ur pc a ir port is not been assigned .. Try this it should work .. Regards
Sep 11, 2005 | Palm Tungsten T3 Handheld
Won't sync to clean Palm
It may be due to a permissions issue on the workstation running the hot sync program
Sep 11, 2005 | Palm m105 Handheld
Palm TX Handheld Logo
233 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Raj Patel
Andrew Taylor
Andrew Taylor
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
