Question about Samsung YP-K3 MP3 Player
Connection when i plug the usb hub in the computer and then i try to update driver wen its updating it after it says a problem has occured cannot watever u know wat i mean and i hav everything service pack 2, windows media player everything can u please help me email me at
  • 8,596 Answers
Re: Connection
Get a clean version of the software from Samsung website, or try a different usb port
Posted on Jul 05, 2008
0 characters
3 Points
Not recognised by pc but charges...
what does it come up as in device manager?
Right click my computer -> manage -> on the left side click device manager.
do you see the device there? whats the status?
Jun 25, 2008 | Creative Labs ZEN Vision:M Digital Media...
I purchased 2 Coby MP600. I thought I was downloading music the wrong way on one of them, so I did a format. Now when I plug the device in, the device media manager, I get this message" Device is not...
I will suggest you to try to connect it to your PC on different USB-port first. If all the USB hub gives you the same message, then try to connect it on another computer/laptop. This is to make sure if the USB-cable is working properly or not.
And if you get the same 'Device is not plugged currently' message when trying it on different USB hub and different PC, you'll have to update your MP3's driver.
Feb 24, 2010 | Coby MP3 & Digital Media Players
I can't get the drivers to install on the computer..
well i don't know if this was a solution but i did download some updates from microsoft and that seems to be working because i plugged it in and it started working instantly, it found the player and everything..
Mar 27, 2009 | Nextar MA933A MP3 Player
My pc accepts mp4 hardwear momentarily then rejects it
A connection is possibly loose, seems like a hardware problem that would require service. Check the usb connector and its pins.
You have tried it on two other pcs? what was the result there did it work? If it worked on both fine, then the issue is on your computer and not on the mp4 most likely.
Please clarify.
Jan 30, 2009 | MP3 & Digital Media Players
Zen not recognized by computer
it ll work only if u change your USB data cable
pls do reply if it worked
Gaurav Dang
Oct 27, 2008 | Creative Labs ZEN Vision:M Digital Media...
Ipod wont show up on itunes
Try the five r's:
These are for Nano, but they apply to all iPods:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
Jun 14, 2008 | Apple iPod MA446LL/A MP3 Player
Connection problem
its the usb connection you probably connected to hub with bad usb port or needed update usb parameter port
Apr 11, 2008 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Problem wen i pressed reset button
· Make sure you have media player 11
· If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
try downloading the MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
By the way, before updating the firmware, let the battery have a full charge, ok?
Sep 03, 2007 | Creative Labs ZEN V Plus MP3 Player
Connection issue with usb
USB can be finicky. First try switching ports. If you are on a USB hub, try connecting directly to the computer. If you are using front access ports, try switching to rear ones. Next try switching to a different USB contorller. IE if you have different controllers on your motherborad or some of your usb ports are on a PCI or PCMCIA card try switching between these. Finally update the drivers for your USB controller if none of the previous steps have worked. Usually these don't get updated very often, but have your computer search Windows update or go to the manufacturer site just in case. Try it on another computer just to be sure that nothing is corrupt with your Windows installation or set up. If you still have no luck you likely have a damaged cable or a dirty or damaged port on the player. Try cleaning the connection port on the player. If the cable is to blame, you can purchase a dock for the H10, though they are very hard to track down these days.
Jan 14, 2007 | iRiver H10 MP3 Player
Samsung YP-K3 MP3 Player Logo
62 people viewed this question
Top Samsung MP3 & Digital Media Players Experts
 Mike M
Mike M
Lawrence Oravetz
Are you a Samsung MP3 and Digital Media Player Expert? Answer questions, earn points and help others
