Question about Kitchen Ranges
Installing Jenn-Air 88370
Wejust got this whole unit with the convection oven and regular oven, 2 burner glass top, and barbque bricks and wire grill. We would like to install it and need the books that go with it. We were told that it is from 1986 and the model number is 88370.
Any help for us?
Thanks,
Chuck and Penny
  • 1,869 Answers
Jenn-Air.com/ Support online can help you
Posted on Apr 22, 2009
  • Oliver Street Oct 03, 2010
    Be thorough before you do all the work, some parts for that model are no longer available.
Jenn air gas electric grill range with convection oven making beeping sound showing -FC- code
FC is a communication error caused by poor connections with the wiring between the logic and relay boards in the unit... Disconnecting and re-connecting the wires and looking for / reflowing the solder joints behind the header connectors will fix your issue
Jul 19, 2016 | Jenn Air Kitchen Ranges
F-3 signal on Jenn-Air SVE47600, grill-range, self-cleaning convection oven
The F3 means there is something wrong in the sensor circuit, sensor/wiring/clock. F3 Problem: Shorted or open oven temperature sensor (RTD): Solution: Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jan 06, 2008 | Ovens
Gas oven doesn't work. Broiler does.
Hello - Most likely failed lower burner ignitor. Tests good if above 4ohms. Part is 40$. Can give replacement instructions if needed. Let me know if this helps. Thanks. -ED
Mar 03, 2010 | Jenn-Air JGR8875QDS Gas Kitchen Range
Vent fan stays on
The fan was on because the griddle element was on. 1/2 of the element was on so 110 volts was on at all times. If I had not been close to the oven and heard the fan I might never have found this problem. I replaced the infinite switch and that solved the problem. I found the model # inside the drip jar door. Problem solved.
Mar 18, 2009 | Jenn-Air JGW8130A Electric Single Oven
Jenn air 88370
I have a similar Jenn Air oven approximate date 1982. It has a catalytic liner (colored a kind of dark charcoal  with paler flecks), so it is a continuous clean oven during normal cooking.  However, it also has the Accel Clean setting on the control knob. This increases the oven temperature to maximum and also runs the convection fan to burn off cooking residues. This allows the catalytic lining work at high efficiency, and burn off stubborn residues that are not removed at normal cooking temperature. The oven may emit smoke through the top door vents as the food residues burn off, so watch that you do not set off your smoke detector. I switch on the cooker hood fan and also put a fan in the kitchen window (blowing air out of the kitchen), to avoid setting off my kitchen smoke detector if I use Accel Clean.
Jul 28, 2008 | Kitchen Ranges
Jenn-Air grill half burner issue
Re: only one side lighting, it is a problem with the cross over **** that carries the flame from one side of the burner to the other. It is located at the rear bottom of the burner and is probably clogged. Wire brush them to clean; failing that, replace with new ones and keep the new ones cleaned with a wire brush regularly.
May 31, 2008 | Grilling
Jenn air range
1.black top nice and shiny, as far as streaks your gonna ahve to find a cleaner that works for you , i have a black cooktop and my wife uses clorox wiped to clean and then with paper towel wipes off and dries
2. as far as "saddle grill" calling the manufacture (number inside your manual) will be best source of info on that, of course unless you can find an aftermarket 3rd party maker
Mar 15, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air 88370 drop-in stove, want to convert!
your old jennair is 220 should be three or 4 wires in it red for 1 side of the 220 black for the other side of the 220 white for the bottom of the outlet and if green is there you can hook it with the white wire or just not use it let me know if your colors are different
Feb 14, 2008 | Ovens
Kitchen Ranges Logo
265 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
