Unit is dead ...
TV unit is dead ...
  • jim-bonnie Apr 22, 2009
    Product # FLM-323B Model # 3700
    Polaroid
    When I hook the unit up and hit the power button, nothing happens. I have checked the fuse. That seems ok.
  • Sonny Berry
    Sonny Berry May 11, 2010
    meed the make and model number in order to help, also need to know is the power indicator out also ?
  • 8,617 Answers
I have seen that model have bad capacitors on the power supply which will cause that symptom. Replacement parts are very hard to come by for Polaroid TVs, But I can post a link which may be able to locate or rebuild your power supply for you. Just leave them a email with your model number and symptom. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Apr 22, 2009
  • Sonny Berry
    Sonny Berry Apr 24, 2009
    Here is a link that will have the part you need and they will send instructions on how to install it yourself. Just click on the contact section on the lower left hand side of the page and leave them your model number and symptoms and they will respond quickly.
Why is TV flashing and not turning on. made a sizzle sound
dead tv
take it in for a diagnosis
plasma tv units are very costly to run so consider the quote and get an LED unit that is the cheapest unit to run
Nov 24, 2017 | Televison & Video
I HAVE MODEL LCT3201TD. I AM USING THE REMOTE THAT CAME WITH THE UNIT. THE REMOTE WILL TURN THE UNIT ON AND OFF,CHANGE VOLUME AND SLEEP TIMER. TO CHANGE CHANNELS I USE A SEPARATE REMOTE. I WOULD LIKE TO...
The tv remote that came with the tv unit.The tv remote might have channels buttons up/down buttons functions and numbers pads might be shorted and dead and no longer functions anymore.U have a Digital Camera turn it on take the tv rmote put in the front of the Digital Camera pushes each buttons one by one all the buttons that work u will able to see a flashing white light on the camera vewing screen,because the Digital Camera can read INFERED input signal to see a output u see on the the camera viewing screen.After u test it on the front of a Digital Camera any buttons don't have a white light flashes INFERED read out than those buttons functions are shorted and dead.Try website like Remotes.com to buy the tv original remote to replace and used.
Aug 29, 2011 | Akai LCT3201TD 32 in. LCD Television
Model: Hitachi P50a402 plasma TV blinking blue light upfront but no TV signal or boot screen. Openned the unit and tried to get readings on power supply board, it seems I do have 3 and 5V but not able...
Did your already check your H- out section. This happen when your TV at protection mode. Its mean it detect defective parts inside the unit. Isolate the H- out power and open the TV Then check voltage if there's power reading meaning that the H- out section have problem.
Aug 12, 2011 | Hitachi P50A402 50 in. Plasma TV
My Directv H21-200 will not power on. Even after leaving it unplugged for a while. I need to know if there is a fix or if it's fried.
Take the unit aparts,the power fuse at near the a/c power supply cord.Check for the power fuse.If the power fuse it is dead,replaced it,u have a 70%-80% the unit will work again.If the unit power fuse it is good.Than the unit it is fried,it could be anythings are dead on the unit PCB board,now u must have great electronic skills and troubleshooting skills to find out where it is and replaced it electronic parts on the unit PCB board.Require alot of skills at this points.Not worth the effort.It time to buy a new one.
Apr 26, 2011 | Directv H21 DTV Receiver
Hello, my 25" Magnovox (#mt2501c)
Tv fell off about 3 feets or more?Yes,turn on the tv see if u getting any power to the unit?Might have broken main PCB board too.If unit still have power,check see if tv get statics screen have colors shaded in red or mutiples colors,mean the tv CRT(tv tube) yoke is dead and damages scrambles radiation.Or the tv getting power but have high pitch sqeeling noises or rattles noises,tv have the CRT-(tv tube) is crack by the neck or broken totally.CRT have damages problems or dead tv is worthless,beacause of CRT(tv tube) is dead,not fixable even that antena connector input is replaced.
Feb 17, 2011 | Philips Magnavox MT2501C 25" TV
The reciver dont go on
check your connection, then on thr front of the unit on the lower right side is a small panel, flip it down and push the red button, this will reset it, if it does nothin the unit is dead, call Directv and they will send out a new unit
Jun 08, 2010 | Directv Plus DVR DTV Receiver / 100-Hours...
Toshiba 40RV525U green power light comes on but TV does not
toshiba often utilizes the green lamp for off, and the red lamp for on.
hope this helps!
Dec 07, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
