Question about Dewalt DC925B Heavy Duty Xrp 18V Cordless Hammerdrill/Drill/Driver Bare Tool
When in drill mode the tork still kicks in on my dewalt
When i use my dewalt dc925 drill on drill mode the tork kicks in meaning when i hit a bit of resistance the chuck stops moving. it works fine for screws and drilling but it wont drill through knots and hardwood
  • 3 more comments
  • bri68 Apr 23, 2009
    yeh it works fine and on hammer can still drill bricks except when i hid something tough. for example when i hold the chuck to loosen it if i keep a hold of it, the tork will kick in eventually. what do you mean by stripped?
  • bri68 Apr 24, 2009
    its really not that old got it from a mate who doesn't know what to do with it he was going to throw it out. i always make sure i use sharp bits. i have had it open and the cogs inside look fine. i am probably not explaining it well it doesn't stop the clutch kicks in even on drill and hammer mode and you get the rachet noise. do you think if i take it apart again and turn the torque setting bit around a couple of times (if it will go) to tighten it up or do you think it needs a new clutch or gear?
  • bri68 Apr 25, 2009
    yeh i've taken it apart i'am used to this have got quite a few tools that i have to take apart and clean to keep them in good working order e.g nail guns and battery drills. the only thing that i coud see is that the transmission part internally has a few cogs to it and their is a hole throw it. when i manually turn these cogs the move aside not only around i was wondering ifv their was a nut and bolt missing from the centre? any help would be appreciated.
  • josh1111 May 11, 2010
    sounds like it may be stripped does it work on any other settings?
  • Craig Becker Oct 30, 2013
    The clutch is activated by the transmission and when that happens you replace the transmision. With the cost it's not worth trying to repair the transmission.
  • 398 Answers
There is a gear and a clutch as agier said in the head. if its old it looses its catch, youll need to take it apart and look at it. the torque setting just tightens on the head the more you tighten it the less it will give( the ratcheting you hear when you set it low) .expensive drill so its worth trying to fix. how old is it? as for drilling thru knots and hard wood make sure your bits are sharp, you can spend alot of time trying to drill with a dull bit. do you sharpen your bits? i do alot of drilling with battery drill thruout the year and believe me a sharp bit is waaaay easier. though ive never had to sharpen concrete bit because they always break when they get old and i buy new.
so your saying it stops completley when you hit something hard, right. does it ratchet?
Posted on Apr 23, 2009
  • josh1111 Apr 24, 2009
    yea you never said you took it apart some of the hardest problems to fix are ones created when someone tries to fix something. i think you should take it apart like you said again and tighten it if it lets you. if it doesnt work let me know and i have an 18v that i could take apart now and see if i can explain something better to you. give me a few days thanks.
    Problem Solver:
  • 9 Answers
Clutch is bad. can be repaired but ive always had a pro do it. bit spendy
Posted on Apr 22, 2009
I have a DeWalt DC925 type 1 hammer drill,took it apart to repair switch and clean. Four pin bearings fell out,I don't see them on a parts diagram,where do they go ?
You will find them in the transmission, remove the metal cover and they will be located just under it - sounds like it is either the gear posts or the clutch cams on the nose side of the transmission DeWALT DC925 Type 1 Hammer Drill Parts
Mar 23, 2015 | Dewalt DC925 Cordless Drill
What year was dc925 made serial no 336841 dewalt
Check on the bottom of the handle where the battery attaches. Dewalt stamps the 'made-on-date' in the plastic there. This is the date repair centers use for warranty repairs if you don't have a receipt.
Jan 30, 2012 | Dewalt DC925 Cordless Drill
How does a drive guide work
You attach it on the machine after you have attached the drill bit. If the drill bit is 100 mm for example (4 inches) and you want to drill 50mm (2 inces) only then you make the drive guide to be 50mm (2 inches) ahead of the drill machine.
Aug 27, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Dewalt dc925 drill, the chuck jaws appear to be jammed tight shut and will not open. any ideas?
Hi, soak the chuck in crc overnight then put the drill in low speed and reverse. Hold the chuck by hand or with multi grips and pull the trigger. Hope this helps, regards Phil.
Jul 23, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
I can run drill, but it doesnt; have much tork before it goes into clutch mode
there should be different settings for the clutch. there is a wheel behind the chuck which you can turn for the settings. If it is set at the high setting the clutch is worn and has to be replaced.
Mar 27, 2011 | Dewalt DC925 Cordless Drill
DeWalt DC925XE Keyless chuck keeps undoing when reversing screws releasing driver bits.
You must never oil the chuck so if this has been done then it can be the cause of your problem
Sep 28, 2010 | Dewalt DC925 Cordless Drill
DeWalt DC925 electronic brake repair?
first make sure brushes are not worn out and if not then replace the switch. the brake is contained in it to throw a short thru the motor when trigger released to stop drill. You can find a breakdown for this tool at Dewaltservicenet.com
Apr 04, 2010 | Dewalt 2 Dc925 18v ½ Hammer Drill /...
Hi, I have a dewalt dc925 drill. When running the
They all do that a bit. The sparks when starting up and stopping are normal. If it has been used alot brushes may be a good idea but before they need to be changed it will spark quite a bit.
It will not hurt to inspect the amount of brush material remaining.
Jan 04, 2010 | Dewalt DC925 Cordless Drill
We have several dc925 desalt drills at work and
You are set on LOCK? or are you set to let go at some lesser level? My DeWalt is much older than yours and in the same service with no problem.?
Oct 26, 2009 | Dewalt DC925 Cordless Drill
I have an 18v dewalt hammer drill dc925 and cant get it on the hammer setting?
It's one of the settings on the clutch ring. Or do you mean it won't turn there?
Mar 07, 2009 | Dewalt 18 Volt Compact Drill Kit
Dewalt DC925B Heavy Duty Xrp 18V Cordless Hammerdrill/Drill/Driver Bare Tool Logo
480 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
