Question about Sharp R-820B Convection/Microwave Oven
Unit turns on but will not reset
Checked all microswitches ok. i am an electronics engineer with all equipment. can you send me circuit diagram and suggest what to check? thank you, shlomo
  • Sharp Master
  • 9,156 Answers
Not sure what you mean by "turns on but will not reset".
If you mean that it's not dead but won't respond to key presses, then it may have a defective or contaminated keypad.
But we'd need more info to be sure.
We actually have the full service manual available on our site, but if you'd like to give us more detail on what problem you're having, we'd be happy to help.
We also have critical safety and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 05, 2007
    Champion:
  • 225 Answers
PLESE CHECK THE CONTROL PANNEL, CHECKED TOUCH PAD ALSO CLEAN THE CIRUCIT,
Posted on Sep 24, 2007
GE cafe convection microwave 9CEB1590SS only heats up with convection heating element.
Can be part of the power supply or the controller board. Best to take the unit in for service. You would need the spare parts to try, the service manual, and the proper voltever to make the necessary verifications.
Jan 04, 2018 | GE Microwave Ovens
OVEN TURNS ON BUT DOES NOT HEAT
Most of the times the intermittent problem is due to the door safety microswitch. You will have to take the cover apart and check the two or three microswitches that are actuated in the close/open action of the door. They can be located very close to the locking levers on the right side of the window.
TO check these Microswitches I suggest to use a series circuit with an ordinary filament lamp and a suitable battery or Power supply.
These microswitches have three terminals, although, maybe not all 3 used, They are: a Common, a Normally Open and a Normally Closed.
Please take care not to missconnect or change the terminal positions. A good practice is to take a picture of the connections with your cellphone prior to disconnect. Good Luck.
Nov 11, 2013 | Frigidaire Microwave Ovens
On my emerson microwave model mw81195b, with the door closed on the unit cycled out a fan is still running. The only way to cycle the unit off is to open the door. The microwave functions fine except for...
I'm fairly sure the fan has a door switch and that may have failed. if you take the outer cover off the micro wave itself you hopefully will have a wiring diagram of the unit. Many times I have had to replace micro wave door switch's that have failed not letting it start or sometimes such as yours something like the light staying on. Being that you are a service man, I don't have to tell you be sure to disconnect the power to it and then you can use your ohm meter to check the switches. Hope this helps you
Sep 08, 2017 | Emerson Microwave Ovens
Bamix M122 circuit diagram required
Sorry, but Bamix M122 circuit diagram is not available right now. In that case if you have your manual, you can check that.
May 25, 2011 | Microwave Ovens
I have a Sharp Microwave R-520 KS. And it stopped working. I thought it was due to a latch problem. But now I am not sure. I took it apart -- and the latching and microswitches seemed to be working...
Did you disconnect and test the three latch assembly microswitches with a multimeter or continuity tester? The top and bottom switch are normally-open, and the middle switch normally-closed. The lower switch seems to be the one that takes a beating and most often fails. It should be an Omron D3V-16G-3C25 and can be found on eBay for $10, or via an electronic parts supplier.
Nov 22, 2010 | Sharp R-520KS Microwave Oven
Loss of power to Whirlpool over the stove AccuWave GH5184XPS-4. Checked circuit breaker and GFI -all OK. No other electrical problems known.
Remove unit and check trip/reset switch on unit. Double check GFCI receptacle with plug tester with GFCI test button.
Jan 12, 2010 | Whirlpool GH5184XPQ Microwave Oven
DACOR Microwave (DMT2420) Display erratic
Poor solder joints are a common source of trouble on printed circuit boards. You might want to remove the control board and check for poor soldering (grainy joints, cracked solder, occasionally even unsoldered) or cables that aren't seated properly. Also, electrolytic capacitors are a frequent problem in electronic circuits. These are supposed to help filter and smooth out voltage and if they don't do their job you can have unpredictable problems. Capacitors are cylindrical parts around 1/2 to 3/4 of an inch high and around 1/4 to 3/8 in diameter. Look for swollen parts, bulging or split tops (they should be flat). If there are no visible problems the board may have a flaky microcomputer, possibly (as you've mentioned) from power transients. But bad connections are such a frequent thing with current equipment that I'd look for those first.
May 28, 2009 | Dacor DMT2420 1200 Watts Microwave Oven
Unit not getting power
These machines seem prone to having a bad magnetron. Look for a circuit breaker near the power cord entry point. If tripped, reset and try to heat a cup of water. If it makes a loud buzz and then pops the breaker again, the consensus view is a bad magnetron. This is one repair that is recommended to send out. (~$150). You need to evaluate the probable cost vs a new machine.
Apr 13, 2009 | Whirlpool MH7155XM Microwave Oven
Kenmore model 911.4942993 microwave does not defrost or heat. All keyboard functions appear to be normal. Are there onboard diagnostics for this model? This unit is part of a built-in oven with microwave,...
This was my first microwave oven repair, and I feared the worst - big $$$'s, parts no longer available, etc. But after I pulled the unit forward and found the schematic diagram, it turned out to be a defective microswitch in the secondary door latch circuit.
Even in retirement, my degrees in electronics and computer science occasionally save me some $$$'s.
Aug 05, 2008 | Roper Microwave Ovens
The microwave does not work.
check control circuit and related control panel circuit
Jul 28, 2007 | Panasonic NN-T993SF Microwave Oven
Sharp R-820B Convection/Microwave Oven Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
