Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice crystal build up
Getting ice crystals on items, sometimes real bad, temp reading holding at 39, some food went soft, Vegetables freezing in crisper in refrigerator section
    President:
  • 1,489 Answers
Sounds like the cold air regulator needs adjusting or is blocked. There should be a lever somewhere near the inside top of the refrigerator whcih slides back and forth -- it should be labeled which direction to move it to make the non-frozen compartment colder or warmer.
Also check for frost buildup in the freezer -- if there is buildup, totally defrost -- there may be ice on the regulator which opens and closes based on temperature.
Posted on Apr 22, 2009
Icy crystals forming on food in freezer
Ice crystals forming on Frozen items in the freezer is an indication of an air leak caused by either a bad seal leaking seal or an open door to the ice maker Ice chute door
Appliance 911 Sea Breeze
May 17, 2016 | Frigidaire Refrigerators
Freezer won't freeze and fridge side freezing vegetables
In the back there is a radiator and it is frozen solid, you have to deice it, unplug the fridge and take the cover off and remove the ice build up, hair dryer should do the trick, or leave it unplugged for few hours.
Tony
Dec 08, 2017 | Samsung RS2630WW Side by Side Refrigerator
Ice crystals on food in fridge
What is your temp in the fridge? Check that your door is closing all the way. You have several air vents along the middle of the back way, are you getting the ice crystals of food right in front of the air vents? If that's the case then that is also the problem. Right in front of the air vents is where air from you freezer enters the fridge. I would start with checking the temp in your fridge though.
Mar 14, 2013 | Amana Refrigerators
Why do my vegetables freeze
Do you have frost buildup on the rear wall of your freezer? What is the model number for your Whirlpool? It is important that you provide the model number so I can see what may be causing the freezing temps in the fresh food section/crisper. Thanks JT
Feb 06, 2013 | Whirlpool Refrigerators
My refrigerator and freezer temps are set on 3. I have slowly reduced the temp due to both compartments due to being too cold. Vegetables in the bins are not lasting because of cold temps and the...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Mar 21, 2011 | Refrigerators
In the freezer food is getting ice crystals on it
Do you mean in the freezer or fridge?
Either way, it looks like you have a fault defrost sensor of a bad thermostat.
Nov 07, 2009 | Refrigerators
Freezer temp
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} hi!! we have read your problem..every problem has a solution.the temp depends upon your need.if you are using stronly freezers for storing food items like meat, then you can set the temperature to (0-10) degree celsius. else you can set it to (5-15) degrees.always keep the liquid items closed in the refrigerator failing to which it causes crystals.it also costs dearer since you have to defrost then. so always keep your food items covered.hope your problem is tackled..have a nice day
May 22, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
Charlie
May 07, 2009 | Refrigerators
Ice builds up inside packages in freezer.
This is the moisture coming out of the food. It is what causes freezer burn.
The problem is made worse in frost free models by the defrost cylce. Best way to slow it down is to use vacuum bags or freezer bags. Also above 0 F food deterioates faster and below it gets freezer burn and the moisture problem faster.
Mar 22, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Oct 22, 2007 | Frigidaire GLRS234ZA Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
241 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
