I have a 99 Intrepid. all the turn signals work fine when the headlights are OFF. When the headlights are ON, 1. the little left turn green turn arrow on the dash stays lit, 2. all the signal lights stay lit except the passenger side rear. The passenger side front and rear will flash (including little green arrow and turn signal noise) when I turn right, the drivers side front and rear just stay lit when I turn left with no noise. I have checked he fuses and replaced any burnt out bulbs with no luck. Has anyone else encountered this problem. i did notice that when the headlights are on and the turn signals are constantly lit the driver side front turn signal bulb burns 2 elements and the pass side front only burns 1 element.?
What may have happened is either the headlights wiring or the parking lights wiring somewhere along the wiring fused to the left turn signals wiring. Depending on if the turn signals go on when you put the parking lights on or the headlights on.
If the signals come on when you turn on the headlights than you only need to locate the light green wire that comes off the left turn signal harness.
Next follow that wire the entire way back to the firewall looking for another wire fused to that wire as you go.
If there are no signs of this you need to continue looking on the other side of the firewall all the way back to the turn signal and hazard flasher unit which is a black box that connects to a black harness located next to a grey harness behind the knee bolster.
But if the signals come on when you turn on the parking lights than you will also need to check the wiring from the rear left signal and follow that light green wire all the way back to the turn signal and hazard flasher unit.
This should fix your problem, but if not than your problem may lay within the the wiring between the turn signal/hazard switches and the turn signal and hazard flasher unit.
Also you may have a burnt circuit in the junction block. This block is where the light green from the rear left signal and front left signal meet. Don't have a description but if you cannot find it let me know and I will go out to the yard and look myself and let you know.
2007 ford fusion passenger side rear turn signal
