Kenmore 43142 Front Load Washer Logo
Posted on Apr 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does not spin properly with a full load, have to wash teeny loads
Once I leave a couple of clothes items in the drum, it does everything it's supposed to! Normal load size does not operate properly. Unit is not even 2 years old.
Jim Goldsmith
Level 3:
  • Kenmore Master 2,005 Answers
  • Posted on Apr 22, 2009
Jim Goldsmith
Kenmore Master
Level 3:
Answers
2005
Questions
Helped
736274
Points
6152
Your clutch is slipping
Washing machine tub is banging into the side of the walls..what's the problem here
There are two possible causes for when a washing machine jumps and bangs on spin. Either the load is a bad one and unable to be balanced, or a fault is preventing the machine from balancing the load (or causing the motor to surge into spin when it shouldn't). This causes the laundry to be flung around inside. The occasional jumping around may not be anything to worry about, but regular or severe occurrences should be a cause for concern and can cause expensive damage to your washing machine if ignored.
Both these faults are less common these days because manufacturers have built in certain protections, but it's still something that can happen. To differentiate between the two, observe when the problem occurs, if it's during a wash cycle, maybe at random parts of the programme, it may have a fault which really needs an engineer to diagnose as these faults can be intermittent and tricky to diagnose. If it happens when it kicks into the fast spin the chances are it's related to the load inside.
Am I overloading my washing machine?
By out of balance I mean when the washer jumps or bangs quite violently. If the washer is just rocking about on most spins make sure it's on a level floor and that it is properly level.
If a load is out of balance you can often observe the inner drum swaying about or even thumping the sides of the casing a few times whilst it's trying to distribute the load prior to fast spin. Before a proper spin the drum should revolve slowly for a couple of minutes. This is called "distribute" and at this stage you may see large flashes of metal drum on each revolution where all the laundry has settled around the drum but there wasn't enough to cover all of it. If this happens the drum will be out of balance and either refuse to spin, or if allowed to spin may cause the drum to thump around and hit the sides of the casing.
The best way to avoid unbalanced loads in a washing machine
If you try to wash a bulky, heavy and absorbent item, the washing machine is unlikely to be able to get it to balance inside the drum. Or if you put just a few large towels or a heavy item in amongst some very light fabrics the heavy items could bunch to one side of the drum and the lighter ones won't be able to counter-balance their weight effectively. There should be enough items to fit all around the drum. If there's only enough to fill most of the drum, but a section is empty, then it can get out of balance on spin. If the items are all light, then this may not cause a problem. However, if some items are heavy, they may cause violent banging, or the washing machine out of balance detection may just refuse to allow a spin.
Make sure you fill the drum well. Counter to expectations, the worst violent spins are caused by under-loading - not overloading. Heavy bath mats are notoriously difficult to balance and should ideally be washed with other items or they may gather on one side of the drum. However, some people (understandably) don't want to mix the bath mats in with normal washing. If this is the case and you do get problems with the bath mats getting out of balance I suggest you use old towels or sheets to even the load up. With most modern machines though, a heavy bath mat is more likely to just not get spun rather than be allowed to spin out of control and wreck the machine.
Sometimes you can get an unbalanced load by sheer chance, with loads you have successfully washed many times before. The occasional bad load is inevitable but constant bad loads and violent banging on spin should be looked into. [ Related: loading the washing machine properly ].
Modern washers have built in out of balance protection
Most modern washing machines now electronically monitor the motor during the slow distribution section leading up to the spin. If the load is out of balance, the motor shouldn't be allowed to spin. Typically, a modern washing machine will attempt to balance the load a certain amount of times, or for a certain passage of time, but if it can't, it will either reach the end of the program without spinning, or it will abort spin and turn off. (both scenarios leaving the clothes wet through). Some washing machines may allow a slow spin if the clothes are reasonably balanced, but then unless they settle down, it will not allow a higher spin thus leaving the clothes spun, but much wetter than normal.
Some will indicate a failed spin due to being unable to balance the wash load so check your instruction book to see if your washing machine has this function and what happens if a spin is aborted. Unfortunately some washing machines do not adequately inform the user that it failed to balance the wash load and aborted spin. As an engineer, I have been called out many times because a load was washed but not spun, but there was no fault on the washing machine, just an aborted unbalanced load.
Extra large drums make balancing loads harder
These days you can buy washing machines with much bigger drums. The average drum size was at one time a mere 4.5Kg but is now 6Kg. You can buy washing machines with 7Kg, 8Kg and even 10Kg drums.
These washing machines can be more prone to refusing to spin some small loads because they need even more items to fill the drum. For example, my 7Kg washing machine will not spin 3 large towels. Last week my wife was extremely frustrated with our 7Kg drum washing machine as she had just washed our son's hoody-top and wanted to spin it in the washer. It simply would not spin, so I advised her that it needed something to balance it out. She put in a couple of towels but still no spin. Eventually 5 towels were needed to balance out the absorbent top and allow a spin. This is a minor inconvenience compared to the benefit of being able to fit more washing in (even our king sized quilt) but it highlights how if you have a very large drum it could be more prone to not spinning small loads [ Washing machine won't spin just one item or very small loads ].
I'm loading the washing machine correctly but it still bangs and jumps on spin
This is unfortunately a difficult fault to diagnose. It could be various things including a faulty connection somewhere on the motor or pcb, especially if intermittent. It can be caused by a part overheating, cutting out and then cutting back in causing loss of control. If this fault isn't caused by the loading you really need to get an experienced engineer to look at it. Find a washing machine repairer on Washerhelp
If a brand new washing machine is jumping around on spin
Make sure you have removed all of the transit packaging before using a new washing machine. The transit packaging stops the suspension from working so without the tub being able to bounce up and down on the suspension all the movement created on spin will be translated to side to side movement and the washer will move about and shake.
Loading washing machine White Goods Help washing machine jumps and bangs on spin Washing machine won spin just one item Book washing machine repair
2helpful
3answers
Is it normal for the washing machine to start and stop the spinning while the machine is in each cycle? Should it take over an hour to run one wash cycle?
Yes...they use less water...so they start, tumble, then cycle again adding more water. I use the fastest setting on all my clothes which is 1/2 hour. It also does start and stop during spinning to tumble the clothes. It speeds up as it goes thru each stop till it spins real fast. All my clothes wash perfectly on fastest cycle.
Why does my washer do every thing but spin dry could a pressure swicth be bad on door?
Good Afternoon Dale,
I see that you are having trouble with your Frigidaire Affinity washer, model# ATF7000ES, not spinning your clothes dry. First, if the drum is not spinning at all, I suggest resetting your appliance by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. Once power is restored run a spin only cycle. If it starts spinning and the clothes are still coming out damp, try one of the following:
    1)Try changing the spin speed to a higher speed.
    2)Make sure that you have not overloaded your washer.
    3)Make sure that the wash load is not too small. If you are only washing a couple of items, try adding 1 or 2 similar items to balance the load.
    4)Try rearranging the load to allow proper spinning.
    5)Check the drain hose for any kinks. If it is kinked, straighten it.
    If you are still having trouble with your washer spin drying, I suggest contacting your local authorized technician. Hope this helps.
    -Best Regards-
    WP
2answers
Washer not spinning properly
This should be belt driven? I would imagine jut adjusting the tensionwould work.
2answers
Have a kenmore washer and I have to run everything thru 2 spins cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn clutch.
1helpful
Not spinning..although drum turning and draining as normal.. Thanks
Could be a imbalance with the load inside the machine if there is too much or too little clothes in. Had this the other week on a machine when owner had only put a couple of items in, when the items were wet the were heavy on one side of the drum and the load sensors stopped the machine from spinning up. Remove clothes from machine and try empty, if it works properly either throw some more stuff in to help even the weight or remove some stuff if overloaded.
1helpful
Maytag washer won't shift to rapid spin dry (only slow back & forth)
Hi Jim, you issue could be caused by a couple either one of a of the following,
1) Draining problem, cant empty the water from the machine within the prescribed time limit - preventing the spin programme to commence. check pump filter is clear and waste water is pumping from the end of the waste hose, the hose itself could be blocked with limescale and detergent residue.
2) Unbalanced load, most machines wont spin 1 item, its a safety thing, if a machine spins with one heavy item it puts the drum out of balance resulting in excessive drum movement possibly damaging the inside of the machine and put indue stress on the bearings. Try putting it on a spin cycle with no clothes in
Unbalanced load detection can also be caused by a faulty motor tacho, this usaually positioned at the rear of the motor, this sends an electrical signal to the programmer telling when it is 'Safe' to spin. There also the posibility that the programmer is not reading the tacho signal or misinterpriting it.
Washer Not Spinning All Of The Water Out
It's not supposed to. They all keep water in the drum after wash is finished. Was told by Maytag its to keep the balance of the spin cycle, like balancing a tire with lead weights.
Mildew/Stagnant water smell in washer
you know, this does happen.
run it on a full cycle, warm, with either of these in solution.
baking soda, at 1/10 concentration
non chlorine bleach, at 1/6 concentration
you most likely need to do this more than once, until your nose is happy.
Also, consider doing this at least once every 200 wash cycles.
essential oils have same effect, and do a nice anti microbial as well.
we did this in commercial laundries all the time, as part of standard health code compliance issues.
Don't properly spin out clothed leaves them soakng wet-Now it just keeps pausing and locking door and unlocking door without washing
sounds like there is a pumping/blockage problem. check the filter and all drain hoses/outlets. if all clear the pump may be faulty. is the drum turning at all?
Alexander
vince
