I have EMachine T6520 Model 16520 S/no XRX5610007649. I have been told that I have to replace the hard drive. Can you explain this process and also I understand that I will have to download Windows XP when the new hard drive is put in.
The first link is to download the step by step instructions on how to replace the hard drive on your model. The second is the contact link for e-machine ,as I found no restore disk as a download.
http://www.emachines.com/support/service.html#eurpp
No PC model told. desktop (vast there are)
same on all desktops made
one side of case.
remove 2 cable to drive
remove 4 side screws from side of drive to cage.
remove drive, slides out.
some PCs the drives have caddies.
no PC told
the manual is here
The hard drive must still be working to get the pictures off. The best thing to do is remove the hard drive from the machine and use either an external USB type case to mount the drive into so you can use another computer to explore the drive or there is a tool that just plugs on to the drive with a USB cable and power supply built in that will serve the same purpose. You must get the appropriate type to match the drive type which could be either IDE or SATA. SATA drives use the small cable and IDE use the wide ribbon. If the hard drive is not working, you would have to get specialized and expensive company to retrieve the data from the drive.
The eMachine T3995 hard drive was originally an IDE 250GB drive. These drives are obsolete and hard to find.
I suggest using the following Generic IDE to SATA device on Amazon for about 7 dollars and then replacing the IDE drive with the SATA drive of your choice such as the 320GB Western Digital Blue listed on Amazon at about 25 dollars. Both IDE and SATA drives mount the same way.
On a Asus motherboard its not designed for eMachines systems because they come with a proprietary setting on the case. So what you need to is take the emachines motherboard that you took out and take the new motherboard that you bought and match the two. If there is a difference then you need to return it or buy a new case and you shift all the hardware from the emachines to the new case. If not buy a similar replacement board from emachines or ebay and you can find one and buy it. The Power setting is on all motherboards but some are different then others.
Maybe you should try to do a "destructive" restore. when restoring from the recovery disc, you have the option to do a "destructive" or "none destructive" system recovery. if you choose to to non destructive recovery, then any virus that may be on your pc will not be removed and this may be the reason why your recovery always stops half way through. note that this will format the hard drive and you will loose all the files on the hard drive, including photos and documents. if this doesn't work then you should try to find out if you have a hardware problem. you can download one diagnostic software from seagate, that you burn to a cd. you use this as a boot disc, like the recovery disc, to test your hard drive, memory and motherboard to see if you need to replace any components. the most common problem is the hard drive. http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=SeaTools&vgnextoid=720bd20cacdec010VgnVCM100000dd04090aRCRD
Check your num lock key status press it on and off if hum lock led is on and off when u pressing then your cpu working fine. so check connectiopn of vga cable cpu to monitor. Also some times display screeen resolution issue so when u power up press F8 key then enter in enable vga mode then you can chang escreen resolution to 1024*768. but if num lock key is not on and offf then open the cabinet of cpu then find cmos cell on mother bord and pull it for 14 minutes then check .
