Question about Air Cool AC436-GB Fan
I cannot reverse the fan blades
We do not have an instruction book for fan #792145350989 and we cannot find a way to reverse the blades. Can anyone help?
  • kwiatnc Apr 25, 2009
    We have the same problem and cannot locate the switch. Any advice?
  • 38 Answers
Look for a small slide switch around the body of the fan. most fans have a small switch to reverse direction.
good luck....jay
Posted on Apr 24, 2009
How do i change the direction of the rotation of the blades on a model 52-DA? I understand it's done through the remote control but I don't have the instructions for the remote.
There may be a switch on the side of the wiring housing to effect reverse rotation. If the remote does not have a fan reversal button, it can't reverse rotation.
Jul 05, 2016 | Hampton Bay Dryers
Need a download for the Instruction manual or wiring diagram
Kinda hard to do without knowing make/model of fan!
May 05, 2015 | Dryers
Original thermo fan blew the blade off. bought after market thermo fan but doesnt work with the original plug. does the have to have the polarity reversed or am I missing something?
fan blades are profiled (as in a aircraft wing) so that the air is drawn through the radiator . IF the fan blades are incorrect then reversing the polarity will bot be as effective as it needs to be.. So check that the fan blades will work in the right direction and replace the plug or cut and splice the wires to reverse polarity .
Mar 02, 2014 | Suzuki Cars & Trucks
Minka Aire Fan will not reverse.
My fan is a concept II and it had the same behavior. I called Minka Aire support about this - they said it was either the reverse module or the receiver. They sent me both no charge! I replaced them and now my fan reverses. i am not an electrician, but the replacement was fairly easy. Just made sure to disconnect 1 wire at a time, connect it to the new wire, etc until I was done. Minka Aire support said they would walk me through it on the phone but I didn't need them to.
Sep 30, 2009 | Minka -Aire Brushed Nickel Remote Control...
What do symbols mean i lost my remote and instruction book.triangle,snowflake,pan with drop above,3 blade fan
Triangle = automatic
Snowflake= cooing only
Pan with drops = dehumidifying mode
3 blade fan = fan only (no heat/cool)
Aug 18, 2009 | Heating & Cooling
I also have a fan Regency Spirit model # SP-NP
With the fan off and stopped, you'll need to get up close and personal with the fan (some of those pesky forward/reverse switches are tricky to spot). Look for a black "slider" switch between where the blades are attached and just above the light fixture (if your model has one). The switch is usually square, measuring approximately 5mm x 5mm. I hope this helps!
Aug 14, 2009 | Hampton Bay 24002 Ceiling Fan
My fan reversed, but my controller does not have a reverse button
There is a switch on the housing of the fan. It is under the blades and above the lites if you have lights. Also same area as the chains. That is the reverse switch you might have hit it when cleaning the fan. just flip the switch iy goes left to right or reverse.
Good Luck and please rate
Jan 23, 2009 | Minka -Aire Brushed Nickel Remote Control...
Dayton Attic fan running backwards
First see if the switch has a reverse position. Sometimes you turn the fan assembly in the frame, sometimes you turn the whole frame around. Take the cover off the wiring compartment to see if there are instructions there. Also check on the name plate on the motor, there may be instructions there. Attic fans are usually engineered to blow out.
Aug 02, 2008 | Dayton (2C373) Fan
Reverse
you can make the blades to run in reverse direction by just interchanging the terminals where the supply is connected
Jul 28, 2008 | Hampton Bay 52 In. 5-Blade Fan, Iron...
Air Cool AC436-GB Fan Logo
220 people viewed this question
Top Air Cool Dryers Experts
Dan Webster
Dan Webster
Are you an Air Cool Dryer Expert? Answer questions, earn points and help others
