Won't power up
Unlugged from back-up power, unplugged back-up for 30 seconds, made sure green light on bak of CPU, plugged all back in, held power button on for 45 seconds. HElP
  • lorenab Apr 23, 2009
    Thank-you for your prompt assistance. Took the cover off last night and found the button had become unseated. Will save your suggestion for future assistance, lb
  • mrninja
    mrninja May 11, 2010
    check the MASTER power cutoff switch in the back..its usually red right above or below where your power cable plugs in
  • 433 Answers
Did any light come on...we are talking about a PC correct? Don't hold the power button. To turn it off you have a 5-6 second delay but powering up just push the button. If your not getting power do the first things first..check all plugs, on the power supply (rear of the tower) the may be a power switch-check that.
If you see lights, next I would check out the video card, encase you drivers got corrupted...update and reinstall them.
Last reseat your ram memory...
if this didn't help provide more particulars- good luck, hope something here helped
Posted on Apr 23, 2009
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Jun 04, 2016 | Sharp Aquos Televison & Video
Why is my Sony VAIO VPCEB33FM green power light flashing?
It won't be the cpu. If it was, nothing would happen. I would look for a GPU issue, possible over heat.
Jan 01, 2015 | Sony Vaio Vpceb33fm
Toshiba satellite c655 won't power up
Take off the top keyboard and power lid. Check for damage to the power flex cable. Plug in AC adapter. The port where connected power flex cable should have two or three pins. With small screwdriver try two-pin jumper shortly. Does not turn on again? All you need to replace the motherboard
Oct 04, 2013 | Computers & Internet
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
The green start light is flashing and won't start again when pressed.
Cycle thru the wash settings. Do all the lights work for the different settings?
Nov 25, 2012 | Washing Machines
When I turn on my set, light turns green, then after 30 seconds turns red won't come on
Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
May 05, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
My cpu will not power up the blue light just flashes when pushed and held
Flashing power light is a sign of a hardware failure. First unplug the pc and give it about 30 seconds then turn it back on. If it goes back to a blinking power light you have a hardware issue and will have to get that checked out.
Jun 22, 2009 | Gateway 560GE PC Desktop
Hitachi model 55ux58b
how many times does the light blink?
Dec 10, 2007 | Hitachi 55UX58B 55" Rear Projection...
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
