Question about Microsoft Xbox 360™ Premium White Console
I am using an external harddrive through my xbox, the problem is it is partitioned into two part (both the correct format 'fat32'). its not an option to merge both partitions so how do i get both partitions to appear on the xbox??
  • tomasglynn Apr 23, 2009
    as i already said it is formatted correctly!
    its partitioned into two parts and i want to know how i can get both to show up?
    Problem Solver:
  • 15 Answers
You have to connect it to your pc via the usb and reformat the hard drive.
Posted on Apr 22, 2009
I brought a 250gb hdd for the xbox 360. The xbox 360 says that it is a unformatted storage device, the only thing i can do is formatted the hdd. but nothing happend I have formatted the thing 5 times....
Trying to format a large external USB or Firewire hard drive to the FAT32 file system? Can't do it? Only see an option for formatting the drive using the NTFS file format? Well if you answered yes any of those questions, then you're at the right place.
I was recently trying to format my 1 TB MyBook external hard drive in Windows XP to FAT32 instead of the overly forced-upon NTFS format. Why? Well because I needed to connect it to a NAS device and the NTFS permissions were causing the NAS not to be able to access the drive. Simple solution is to use FAT32, no security, no problems. Though it's sometimes useful to format a USB drive in NTFS format.
Also, formatting a drive in FAT or FAT32 will allow it to be read by other operating systems, such as Mac, Linux, and older versions of Windows such as Windows 98.
Unfortunately, Windows XP and Windows Server 2003 will only format a removable drive in FAT32 if it's less than 32GB! Hmmm...that pretty much cuts out ALL modern external hard drives!
However, Windows can format a drive that is larger than 32GB in FAT32, but you have to use the DOS command prompt. However, if you have a drive that is 1TB or larger, you may still get an error saying "The volume is too big for FAT32".
In that case, you can use a free program called SwissKnife that will allow you to format an external hard drive that is up to 2TB in size. Let's go through both methods. In case you are having problems getting your external hard drive to show up in Windows, read my article on how to change the drive letter for an external drive in Windows.
Format external drive in FAT32 using DOSOpen a command window by going to Start, then Run and typing in CMD.
Now type in the following command at the prompt:
format /FS:FAT32 X:
Replace the letter X with the letter of your external hard drive in Windows. Windows will go ahead and begin formatting the drive in FAT32!
Format external hard drive in FAT32 using SwissKnifeSwissKnife is a nifty little program that is completely free and that you can use to format many types of external drives such as USB, Firewire, PCMIA, SATA and SCSI. You can also use it to create partitions on an external hard drive and it formats faster than Windows.
So next time you want to format a hard drive in FAT32 and Windows only gives you an option for NTFS, make sure to follow one of the two method mentioned above. Enjoy!
Mar 02, 2011 | Microsoft 20GB Hard Drive for Xbox 360
Tip
How to Convert NTFS External Hard Drive to FAT32?
My friend Michael bought an external hard drive last month, yesterday he ran to me and ask how to convert external hard drive from NTFS to FAT32 safely and easily? I was so curious about why does he want to convert NTFS to FAT32; he said NTFS partition can't be read by DOS system. Since protecting data and files, I recommend him to convert external hard drive from NTFS to FAT32 with a third-party software-AOMEI Partition Assistant, which can convert hard drive from NTFS to FAT32 without data loss.
To computer users, NTFS and FAT32 are not strange. But seldom of them can tell what the difference between them. NTFS and FAT32 to partition are what DOC and TXT to text. In text, the file with DOC format can't be read by TXT application. Similarly, in some condition, not all files in different formatted partition can be read by same application. First, you'd better know some knowledge about NTFS and FAT32.
A Brief introduction of NTFS and FAT32
About FAT32
FAT 32 is one of partition format in windows system. It has 32bit file table, which strengthen FAT32's management to partition, and break through the limitation of 2GB space in every partition. Since the production cost of hard drive decreasing, the volume capacity is increasing. After applying FAT32 partition format, a big volume hard drive can be definite as a partition but not be divided into multiple partitions. It is good for management to hard drive. Now, FAT32 is replaced by NTFS.
About NTFS
NTFS is standard file system after Windows NT, 2000, XP, server 2003, server 2008, Vista, and 7. It replaces FAT to offer file system for Microsoft. NTFS make advanced on FAT and HPFS, such as to support metadata.
The difference between NTFS and FAT
As mentioned above, NTFS and FAT both are file system. However, NTFS is produced late than FAT32, but NTFS is more advanced in technology. In summary, the specific distinction are following below:
NTFS can support up to 64GB single file and 2048GB partition. FAT32 supports up to single file with 4GB and partition with 32G.
NTFS does not need Defragment your hard disk.
NTFS support to compress partition, folders and files.
NTFS takes a little cluster, which can help to manage space of hard drive effectively, and avoid wasting space of hard drive at the most extent.
In NTFS partition, you can share sources, folders and set access permissions on files. It is more secured than FAT32 partition.
How to know which partition format is suitable for you
As mentioned above, NTFS and FAT32 have its own advantages. When we choose which file system, you should consider the factors below:
Computer is installed with single system, or multiple systems.
The number and capacity of local installed hard disk.
Whether has consideration about security or not.
If computer is installed single system, and there is security to consider, you can select FAT32. Or NTFS is not bad choice absolutely.
Why need to convert NTFS External Hard Drive to FAT32?
NTFS and FAT32 are two different types of file systems, and both of them are commonly used and contain different characters. You may make conversions between the two types, and here we got several cases that you need to convert external hard drive to FAT32:
If your external hard drive is formatted in NTFS, you would not be able to access some files from DOS mode or Windows 9X, then you need to covert external hard drive to FAT or FAT32.
NTFS can't be recognized by many devices, such as Xbox 360, PS3, etc. in that case, you have to convert the external hard drive to FAT32 so that it can work with your devices.
There are more situations in which you need to convert external hard drive to FAT32, and there are different ways which you may realize the goal.
Methods to convert NTFS External hard drive to FAT32
At present, there are two main ways that you may convert external hard drive to FAT32, one is to convert to FAT32 with Windows built-in Disk Management, and another one is to convert to FAT32 with third-party software like AOMEI Partition Assistant. Let's see the details:
Method1: Convert an External Hard Drive by reformatting
1. Open the Disk Management in Windows.
2. Right click on the external hard drive and select "Format..." in the drop-down menu.
3. Select "FAT32" in the "File system" line and then choose "Quick format".
4. Finally click "Start" to format, and this process may cost you minutes.
Note: If the drive is larger than 32GB, the "FAT 32" option would be invalid and once format, the information or data in the external hard drive will disappear. So, backup the data or partition if necessary and you need to know how to convert hard drive larger than 32GB into FAT32.
Method2: Convert an External Hard Drive without formatting
You can download the third-party software to convert external hard drive from NTFS to FAT32, what is the most advantage is that convert NTFS to FAT32 without data loss. Comparing with disk management in computer, the third-party software will save your time and money. You don't need to buy other external hard drive to store data, just for converting partition format. Of the third-party software, AOMEI Partition Assistant is good choice. The specific introduction of how to convert NTFS external hard drive to FAT32.
As a kind of advanced partition software, AOMEI Partition Assistant can easily convert an external hard drive to FAT32, and you can also convert an external hard drive larger than 32GB into FAT32. This software is running well with Windows platform including Windows 2000, XP, Vista, Windows 7 and Windows 8. Both 32-bit and 64-bit Windows editions are supported. With its help, you need no to format your external hard drive and thus you can convert NFTS to FAT32 without data loss. Now, you may download AOMEI Partition Assistant Pro Edition and have a try.
source from
on Dec 29, 2017 | Computers & Internet
How do I format my new Seagate 500GB FreeAgent GoFlex Hard Drive to Fat32 for use with Xbox 360? I am using Windows 7 and when I open up the formatting options only NTFS and exFAT are available.
Windows Disk Management can only format a hard drive less than 32 GB to FAT32. If you want to format your 500GB drive to Fat 32, you need to use third party program like AOMEI Partition Assistant. http://www.disk-partition.com/free-partition-manager.html
Dec 25, 2010 | Seagate 500GB FreeAgent GoFlex Hard Drive
How to connect an extenal hard drive to my Xbox?
Get an external hard drive with a USB 2.0 connection. You need this connection to connect the drive to the console. Most recently manufactured hard drives
should have this type of USB adapter included. Format the hard drive to read FAT32 files. Using a Windows PC, create an FAT32 partition on the drive and format the volume. You'll need a program like
Partition Magic to do this. Load all the content you want from your PC onto the external drive. This should consist of photo files, MP3s and any other files that can be read on the Xbox
hard drive. Remove the external hard drive from your PC. Plug it into your Xbox 360 console through the USB port. go to the Media menu on your Xbox screen. Select "Portable Device" from the menu. All the readable files saved on the external drive should be available to
read on your Xbox 360 I am also adding a video//check it out if doubt persists.. vote for me...
  1. .utube.png You-Tube video "W-HVy5lMgtE" placeholder (do not delete) utube.png
Dec 25, 2010 | Microsoft Xbox 360 Console
How do i format to fat32 using windows 7
Windows 7 will format an external partition to FAT32, as long as it's 32GB or less. "Control Panel -> System and Security -> Administrative Options". Right click on "Computer Management", select "Run as an Administrator", double-click on "Storage" then "Disk Management", the right click on your external drive. Select "Shrink Volume", shrink it by 32GB or less, then right click on unallocated space, select format, and "FAT32" will show up as an option during the format wizard.
This is a way to create a small bit of space on an external hard drive for copying some files from Mac OS's to Windows.
Dec 04, 2010 | Prestige Portable 320gb Usb 20 IOMEGA ...
I want to plug my WD 1tb harddrive to my xbox360 and steam music and video files from it. It is my understanding that my drive (which comes with the smartware) is pre-formatted to NTFS , and my xbox needs...
Ryan,
You'll need to connect the drive to a computer to format the disk. Once connected, click "My Computer" to view the drive. Depending on version of Windows, you may not have the option to choose the FAT32 file system. If you do have it, be aware that there are some limitations imposed by the FAT32 file system - most oppressive are the 32 GB partition size limits and the 4GB maximum file size (so those HD movies larger than 4GB won't transfer) . If you still want the drive to be a FAT32 drive, copy all the contents from the drive as this is a destructive procedure.
A full discussion from Xbox Forums can be found here (cancel the print prompt when displayed) and this link has download links and explanation of how to do it.
Nov 22, 2010 | Western Digital Passport® WDXMS3200TN...
Formatting hard drive to fat32
Xbox was not created to use external hard drives otherwise the software for it would be even bigger considering it is a gaming console. It might work if you use FAT but I can't say it for sure.
Dec 20, 2009 | Computers & Internet
Wd passport will not load to my xbox 360
Re: My passport Elite 500 will not show up my Xbox360 Options 12-30-2009 11:19 AM
if it's the drive that comes with the smartware, then it comes pre-formatted NTFS , and your xbox needs FAT32 format to work.
So, you need to connected this drive on a mac computer to format to ms dos FAT32, or use a formatting utility like "partition magic" to format the drive to fat32, then if there's password assigned remove it, and it should work
Aug 15, 2009 | Western Digital Passport® WDXMS3200TN...
3 problems writting on hd, drop connection n download master
Use a FAT32 Formatted partition (32GB) on your external USB Harddrive as the main Master Download Area. To do this, connect the drive to the PC by USB and re-partition the drive in sections with the disk manager. 32GB for the FAT32 and the rest in NTFS. Re-connect the drive to the WL500W USB and the FAT32 partition will be recognised automatically by the Router. Linux users can use the full HD drive if they format the drive in Ext2/Ext3. Correctly formatted USB memory sticks with a capacity of 32GB are better suited for this un-attended (low power) dowloading. You can use a (FAT32) 8 Gbyte stick also !
Warning !
Using only NTFS partitions will make the drive read-only and useless for un-attended downloads by the WL500W. Unfortunatly this is the case with 100% of all new availbale drives (>500GB) - So RE-PARTITION it wisely !!!
What about Queing (Waiting) ?
It waits for the connection and if bandwidth is available it starts the download. If files are missing on a server or the address is invalid an error is risen and the link is aborted or deleted. Many BitTorrent files are invalid or have nobody seeding. Waiting is therefore the best option.
May 22, 2008 | ASUS WL-500W Router (WL500W)
FAT32 format, how to do it in Windows XP?
Try using a third party program, like Norton Partition Magic, Acronis Disk Director Suite, or Paragon Partition Manager.
Nov 20, 2007 | Western Digital WDG1C2500N MyBook Premium...
Microsoft Xbox 360™ Premium White Console Logo
254 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
