Question about Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung 214t syncmaster flickering
When the monitor is first turned on there is a blacked out screen. After a few minutes it then has a constant flicker and a dimmed screen. After about 20 minutes it will then perform properly,
  • Anonymous May 05, 2009
    I have exactly the same problem. At first it would take a few minutes of turning it on and off quickly until the flickering stabilized, but now it it is a ten minute process and begins with a completely black screen.
  • Samsung Master
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of the monitor. If you aregood at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should workfine.We just posted a repair guide showing how to remove the case ansreplace the parts. The capacitors do need to be installed with thecorrect + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 25, 2009
Hi, my samsung syncmaster 214T starts up and flickers hard permanently. I can do everything, change resolution,refresh rate and the monitor responds but it does not stop flickering. Is it a power supply...
Flashing or flickering is a common indication of failing capacitors in the power supply board. The fix is very simple and just requires replacing 5 capacitors on the board. They will need to be soldered. Here is a link to a repair guide for the Samsung 214T units. http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
I hope this helps, if so please rate our solution.
BuddyMc
Jul 03, 2011 | Samsung SyncMaster 214T 21.3" LCD Monitor
Our samsung 214t will not display a decent image until it has been turned on and off a few times. Any thoughts?
You have a power supply in the monitor that is failing. This is a known issue with these great monitors. It is a simple 20 minute repair. We have a step by step repair guide for ts model posted on our site at: http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ The repair involves replacing 5 small parts called capacitors. If you don't want to do the repair yourself we do offer a repair service for this model, the repair service runs $32 plus shipping.
I hope this helps if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Oct 07, 2010 | Samsung SyncMaster 214T 21.3" LCD Monitor
My samsung 214t becomes very blurry after startup and flickers hard than falls out.after a while (first it was after 10 minutes and then it started to take longer than a half an hour the screen became...
The flickering is caused by a power supply board that can't stabilize the output voltages. This type problem is caused by failing capacitors. If you can solder then you should be able to do the repair yourself. Check out our step by step repair guide at: http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ If you don't want to do the repair yourself we do offer a repair service for this model. The repair runs $30 plus shipping. You can setup the repair service at: http://www.ccl-la.com/blog/index.php/service-request-form/
CCL_Tech
Corporate Computer
www.ccl-la.com
Jun 22, 2010 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung 214t monitor would flicker
http://s807.photobucket.com/albums/yy352/budm/Samsung%20Syncmaster%20214T/
Replaced all those caps (not hte big on in the primary circuts) with PANSONIC FM or FC series from DIGKEY.COM
Aug 29, 2009 | Samsung SyncMaster 214T 21.3" LCD Monitor
Flickers then goes black
Check cable plug, conent it properly
Jul 06, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Samsung 215TW Monitor Flicker
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
Jan 30, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Samsung SyncMaster 214T flickers
Hi There,
I managed to fix my Samsung SyncMaster 214T from that flickering. Just changed 3 capacitors and it worked fine!!
Jun 01, 2008 | Samsung SyncMaster 214T (Silver) Monitor
214T - flickers radidly
Yes,
A flickering screen indicates the power supply is not properly filtering the output power. This happens when the capacitors on the power board start failing. Here is a link to a repair guide that shows how to dis-assemble the unit and what to look for and replace on the power supply board. The repair guide also has videos showing the process.
BuddyMc
May 02, 2007 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung SyncMaster 214T 21.3" LCD Monitor Logo
1,526 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
