Question about Dishwashers
Drain is not taling the discharged water away
THe bosch diswaher is pumping out fine but the drain outlet is now not taking the water away fast enough and seems to be blocked. A few attempts at cleaning the drain pipe into which the outlet from the d.washer is hooked has not solved the problem. It used to work fine. Is the only reason for overflow a restriction in the drain outlet. A lot of dirt and grit has aleady been cleaned out. Thamks Dave
  • 1,889 Answers
Check your hose by running a coathanger through it and, don't forget to check the vacuum breaker hose also
if you just installed a new garbage disposal did you remove the plug in the outlet of the new GD before you conected the hose to the DW? look into the GD when the DW is draining and look for the discharge stream
Posted on Apr 22, 2009
Bosch SL1501B dishwasher doesn't drain water after the washing cycle. Also with new drain pump. What else could it be?
Check the following.
1. The drain hose has to be discharging at a high enough point to prevent water flowing back into the machine.
2. Make sure your drain hose is not twisted or kinked.
3 . Make sure your drain line is not blocked push a flexible hose down it to dislodge any fat/debris
4.If your drain line discharges into a shared drain with another appliance i.e. garbage disposal make sure it is not blocked.
5. You may have a blockage at the inlet to the pump which would slow down the pumping rate,
Since you mentioned the mushroom shaped float allowing the washer to empty this may be defective.
See the link attached.
Hope this helps.
Crofter
Bosch Dishwasher Does Not Drain
Apr 30, 2015 | Bosch Dishwashers
Replace discharge pump
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
May 31, 2012 | Bosch WFMC 3200 Front Load Washer
I have the bosch shv46c03 diswahsher. We had a tech out that said the overflow pump was running and or broken. It is running because it preventing water overflow damage. TEch says he needs to remove...
Hello, welcome to FixYa.
I agree with you, I cannot see how any repair to a Bosch diswaher would justify or require it to leave your site let alone going to a repair shop. These (as any other manufacturer) are designed to be serviced in the home. To address the problem I would need more detail and clarification. Is the issue that the drain pump runs constant ? Does the tub get drained of water ? Let me know as much as you can and I should be able to assist you...depending on your mechanical abilities/comprehension. Please verify the model is indeed a Bosch SHV46C03. Thank you.
Regards,
Macmarkus :)
Jul 19, 2011 | Bosch SHV46C03 Built-in Dishwasher
Water drains out as fast as it fills........but not all of the time top load Whirlpool
There is a chance the drain hose has buildup within it and needs to be cleared out. This will take about an hour.
Steps:
  • 1- Unplug the electrical cord on the washer from the wall outlet.
  • 2
  • Unfasten the hot and cold water hoses from the water lines after you shut off the water valves. Use a pair of slip-joint pliers to turn the hose fittings counterclockwise to remove them.
  • 3 Pull the washing machine far enough away from the wall so you can comfortably work on the rear of the machine.
  • 4 Locate the access panel toward the bottom left side of the back of the washer. Use a nut driver to remove the nuts that secure the access panel, and remove it.
  • 5 Find the water pump, which will have two hoses attached to it.
  • 6 Identify which hose is the drain hose by tracing it to the outside of the machine. The pump may also be labeled "Inlet" and "Outlet." The drain hose is attached to the outlet.
  • 7 Squeeze the clamp that secures the end of the drain hose to the water pump, using a pair of slip-joint pliers. Remove the end of the hose from the pump.
  • 8 Insert a plumbing snake into the end of the hose and twist the snake as you feed it through the hose. After approximately 10 feet of the snake is fed through the drain hose, you should see the snake and the clog come out the other end of the hose.
  • 9 Reattach the drain hose to the water pump and replace the access panel. Reconnect the water hoses and turn on the water valves. Push the washer back against the wall and plug in the electrical cord.
  • Hope this helps!
    May 29, 2011 | Whirlpool Washing Machines
    Bosch nexxt 500. E04 message, checked drain area (round circle at bottom, checked ball valve, checked drain hoses, checked and cleaned container at the top right back of machine-where exterior discharge...
    This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
    Please remember to subscribe to our YouTube channel for all appliance tutorials
    a 4 THUMBS rating is appreciated for answering your FREE question.
    And don't forget to like us on facebook
    Feb 01, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
    My Whirlpool Dishwasher Model # DU8000XX0 works perfectly until it is time to drain. When draining all the water comes gushing out the air gap on the counter. Pease help!
    The problem is that the dishwasher discharges the water very rapidly...
    Your drain pipe is either too small or partially plugged to the point that the water cannot get away fast enough...
    You probably need to have the drain pipe cleaned, or aget some drain cleaner to put down it.
    Heatman101
    Feb 26, 2010 | Dishwashers
    Whirlpool washer - tub drains while it fills.
    Your drain is to low. Make sure that the drain that your discharge hose is going into is at least as high as the washer. If not the water will drain out as fast as you can fill it.
    Aug 15, 2009 | Whirlpool Washing Machines
    During the final spin cycle, water is leaking inside the machine
    You have a problem with the pressure switch cutting in too early before all of the water has drained away from the outer drum
    There is either an obstruction in the outlet pipe or pump which is not allowing the water to discharge fast enough.
    The machine is then spinning with too much water left in the outer drum added to the water which is being expelled from the clothes equals leaking
    Take the hose off the back of the machine and put it in a sink , make sure it is secure and do a rinse cycle
    Watch the outlet and make sure it is a strong flow if it is weak then you have probably got an item of clothing stuck in the pipe from the drum to the pump and a strip down is required
    One more thing there is a small plastic bottle attached to the back of the outer drum this has tube which leads to the pressure switch
    Make sure there is no congealed soap in the Air Bell as it is called
    Jul 05, 2009 | Fisher and Paykel WA37T26G Top Load Washer
    My trusty Bosch s510 Dishwasher which has been going strong for about 17 years (at least) has just decided not to empty itself. I noticed the bottom was full of water after a wash. I emptied all the water...
    Same problem, so went out and bought a new bosch. Problem with the S510 was cured by lubricating the pump out motor bearings with a squirt of WD 40. If you don't know which pump, follow outlet hose to pump outlet.
    Les
    Aug 15, 2008 | Bosch Dishwashers
    Water in bottom of dish washer
    you probably have something stopping the drain pump operating (like a tooth-pick or piece of plastic that won't break down in water) its a take it to pieces job i'm afraid but if you are fairly mechanically adept you can do it yourself. the drain pump is quite small and nearby to the drain outlet- you need to remove the case and release the drain from inside the unit- remove the pump itself and you'll prbably find somthing stuck in it- remove and re-assemble. In the meantime DO NOT use the dishwasher as you will 'burn out' the motor as the pump rotors are jammed.
    Hope this helps
    Feb 18, 2008 | Bosch 18 in. SRS43E02 Slim-Line Built-in...
    Dishwashers Logo
    75 people viewed this question
    Top Dishwashers Experts
