Question about Medion M3 Composer 5200 PC Desktop
Having trouble gettin online
Ping address wont release to update
Printer not responding is error message I have tried all fix ideas I can find any suggestions
It is hard to reply without knowing what your actual attempted fixes were. I have the online Manual and the main solutions, if the error message was on the LCD, were focused on the Fine cartridges..making sure they were installed properly and if you might possibly be running out of ink.
May 04, 2014 | Canon PIXMA MX340 Wireless Office...
I have a Aspire 5100, I think it is out dated. The Aspire has a not genuine icon at bottom right screen. It will not let me get online to do any updates, or get the net in general, this includes Foxfi
Get into Command Prompt mode - Programs~Accessories~CMD - and type IPCONFIG. If you have an IP address - type ping bb.com (short domain name). If you have an IP address and can ping through name resolution (DNS) - then it's a browser problem. If you aren't getting an IP address - then check your network drivers or your router...
Apr 15, 2014 | Acer Aspire One Netbook 8.9" Notebook
I can't connect through network can't connect by pinging
Can you ping your router?
If you can, log into it and see if you have any problems with it. If you have ADSL, you will see the status of the line as well as whether you are connected or not. You may have a diagnostic feature that will test the connection to your provider.
If you have lost DNS with your provider, you will not be able to ping using names, only by IP addresses.
Jul 24, 2011 | Computers & Internet
I updated my ps3 to version 3.50 and now it wont let me play online and it is saying my email address and password is wrong and when i try to go to forgot my password it says there is an error help!!!!!
im gettin this today as well, been looking around and apparently its the store thats down for maintenance and i'll be able to shoot some people on cod later. just wait it out chief! i hope! :)
Sep 21, 2010 | Sony Playstation 3 (PS3) Console
Can connect desktop to internet but having trouble connecting laptop to internet
First of all get your connection to teh laptop from the router wired. Then, please ping the routers IP ( Start --> Run -- > cmd --> ping 192.168.x.x.)
Look at the manual for routers IP address.
If you are getting four replies, you have a valid connection, else, try changing cables or ports in the router.
Once this is done remove the cable, try wireless. To do that, ensure, to start off, there is no security on the router. Repeat the ping procedure keeping the router closer to the laptop ( for a good signal strength )
If you are not going online yet, let me know what happens.
hope this helps
Thanks
Ranjit
Jan 05, 2010 | Belkin (F5D7230-4) Router (587009)
It says it is connected but my laptop wont work i have a dlink dir-300 router
It says connected. Check the Ip address on the computer.
Is there any other computer online ?
If not then check the settings of the router .
If other computer is online then try to ping the DNS server
Click Here for more info about networking
Nov 29, 2009 | D-Link Computers & Internet
There are websites that are blocked and I want to know how I can unblock them without getting in trouble.
in the school right!?
use online services like http://anonym.to/
or try to access the website by it's ip address, not the name.
Some firewalls just block the url, not the ip ;)
to get the ip, simply ping the website like:
C:\>ping www.facebook.com
A fazer ping para www.facebook.com [69.63.181.12] com 32 bytes de dados:
Resposta de 69.63.181.12: bytes=32 tempo=205ms TTL=244
Resposta de 69.63.181.12: bytes=32 tempo=207ms TTL=244
And then enter http://69.63.181.12
in you browser
Sep 14, 2009 | Computers & Internet
Internet does not connect - can not get ip address have good connection -
First thing you want to do, is to make sure all the network cables are plugged into the correct devices such as your router, modem and the computer. if all is running well (everything is blinking with lights) go to your computer, open the control panel, select network connections and open it.
Right click on the Local Area Connection and right click on it and select repair. Wait for about 2 mins. After that restart your PC. Try to get on the internet. If you are still not able too, you will need to go to the command prompt, you can do this by selecting start then run, type in 'cmd' and enter.
(The screen above is in German Sorry, but you will get the point)
You will see a windows that pops open, it should see something like c:\Documents and settings\keith> or something like this. type in 'ipconfig /all' you will hopefully you will see a ip address and a lot of other information. the ones you will need to look at is to see if your dhcp is enabled if it is then this will give you a auto ip address if it is not, you will need to get a static address from your isp. You will try to see if you can communicate with the IP address by typing in 'ping ' then the ip address. for example 'ping 192.168.1.1' if you have not packets lost, then that is a good thing. then try to ping your gateway, this will be your router ip address. you can find this ip 'Default Gateway' if you are able to ping this, you should be able to go online fine.
If you are still not able to fix this
after the c:windows> type in 'ipconfig /release' so it will look like this
c:windows>ipconfig /release
wait untill it shows 0.0.0.0
Then type in ipconfig /renew
Keep this in mind this is usful if you have DHCP enabled. unless your in a workplace, you should have DHCP selected.
If you are still stuck, Please let me know and I will be more then happy to help.
Please don't forget to vote!
Sep 08, 2009 | Fujitsu Tablets & eReaders
Can connect to 2wire, but can't browse
What is the ip address you got from the 2wire router. ??
Try release and renew for new ip. Clear the cache and temporary internet files, and then try pinging the router's gateway ip and check . If pinging. then ping any website's ip address. if successful then try going online. Else you need to power off and power on your router and then try again.
Sep 06, 2009 | 2wire (1000-400108-001) Router
I have a Arris Modem and can not get on to the internet. The IT people at Bresnan took a look and found nothing wrong with the Arris. The modem is able to ping and says its online and ready to work, but...
Do you have a cable connection kyle? i think you're using a vista operating system. Click on START, in start search bar type CMD then you'll see the command prompt as a search result. Right click and run as administrator. When you have command prompt, try to ping any website, for example www.yahoo.com. if you're able to ping yahoo that means your connected. If not do IPCONFIG, check your IP address and call your ISP, ask them if its a valid IP that they're giving out.
Aug 29, 2009 | Arris Touchstone 450a (CM450) Modem
Medion M3 Composer 5200 PC Desktop Logo
59 people viewed this question
Top Medion Computers & Internet Experts
Hollyecho Montgomery
Robert Karst
Robert Karst
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
