Question about Bush 5693D 24" TV
Tv has got stuck on standby mode
My bush tv is stuck on standby...I push the programme button but nothing happens
  • Anonymous Mar 22, 2014
    WON'T TURN ON, STUCK IN STANDBY MODE
  • Bush Master
  • 19,396 Answers
If the TV goes off completely, then is usually a faulty power board.
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on Apr 29, 2009
Bush a642f tv stuck in standby mode suspect power supply capacitors but all seem ok
Hi
Press and hold the menu button on the t.v (not on the remote) for about a min, this should reset the processor to unlock it.
Aug 17, 2015 | Bush Televison & Video
TV stuck in standby
have you looked at power supply as you might have to change the caps on the power supply
Jan 25, 2014 | Bush Industries IDLCD26TV16HD LCD TV
Bush 32 inch Tv is stuck on standby and 2 year old has broken the remote control. The tv is set up for child lock so pressing the buttons manually is not helping. Have just purchased a universal remote...
If you unplug the power cord, let it sit for a minute and plug it back in, it should let you turn the tv on by the button at least once. Then you can at least get the remote linked up. Please reply back to your post if this resolved the issue. I would rather you try this first before going further.
Jun 30, 2010 | Televison & Video
Problem with a bush BTV185DVD
The screen off light is stuck on on my Bush TV/Video/DVD combi BTV185DVD. I have tried to turn it to standby but then it just goes back to "Screen off" and nothing happens to the screen. Please help.
Feb 24, 2010 | Televison & Video
Hi, i have 2 televisions different makes both turn on to standby but wont turn on fully, the bush tv when i push programme button to turn on the red standby button flashes but nothing else.
I have the same problem, my Bush LCD worked fine last night but won't turn on today. The main power button on the TV puts it onto standby but the remote or the buttons on the side won't turn it on!....HELP!
Sep 06, 2009 | Televison & Video
TV/DVD unit locked in Standby mode
Did you check the casing for a reset button (sometime it an itty ***** hole)
Hope this helps
Trap
Jan 25, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Tv lost picture and sound
TRY UNPLUGING SET FROM THE WALL FOR 1 MINUTE. PLUG SET BACK IN AND CHECK. IF PROBLEM PERSISTS TAKE IT TO A QUALFIED SERVICER. UNIT PROBABLY HAS A DEFECTIVE MAIN TOTAL ASSY.
Jan 12, 2009 | Bush 5693D 24" TV
Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
Oct 24, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Bush rf6683vpl
yes ,your tv need for repair, but if you know how to solder , try to solder your tv but be careful o short circuit coz it may damage your system.
Sep 06, 2008 | Bush 5693D 24" TV
Bush 5693D 24" TV Logo
2,607 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
