Question about Canon PIXMA MX310 All-In-One Printer
I need to know where all the paper goes if i need to print something.copy something or fax something
We can't figure out where to place the paper so we can make a print off our lap top or a copy or a fax since our printer did not come with an owners manual. Please help me before I end up in divorce court
    President:
  • 2,692 Answers
HP OfficeJet 8500 ADF detects load, but does not detect feed. I have a brand new HP OfficeJet 8500. The ADF detects a document is loaded when I stick a piece of paper in it to be copied/scanned/faxed, but...
Remember that if you start to fiddle you void your guarantee, I know its a pain, but if I were you repack and either contact customer services and obtain a return invoice number if purchased over the internet and return to sellers. If purchased from a shop, return with your prove of purchase.
Mar 19, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
THE TEXT ON THE PAGE IS ON THE SLANT. LIKE PLACING A SHEET TO COPY ON THE GLASS BUT OFF SKEW. THE SAME HAPPENS IF ITS A PRINT JOB FROM MY PC A COPY OR A FAX
I have the same problem. This is what I discovered. Open the front cover where the toner goes in. Pull out the toner cartridge. If you look inside the opening on the left and right side walls about 2 inches in you will see a bronze colored spring. This spring is held in place by a little plastic arm. The little plastic arm that holds the spring in place broke on the left side. This spring puts pressure on the metal roller on the front bottom of the toner cartridge. Lack of spring pressure on one side of the roller causes the paper to be fed skewed. I tried taking out the other spring but all i get is paper jams. Know I need to figure out to the replace the inside left panel or make a make-shift retainer for the spring.
Oct 06, 2010 | Brother MFC-7820N Printer
No print on copies or faxes
This is a clogged print head. This happens if the printer has been off for a long time or if the cartridge was removed and the unit left empty for any time.
Take out the cartridge and press the print part on a piece of paper. Any black lines? If not, you will need a new cartridge. Wiping the print head gently with a Q-tip moistened with PURE alcohol (99%) may restore printing.
Mar 31, 2010 | HP 1040 Plain Paper Inkjet Fax
In faxing how do i place the printed side into the fax slot?
Should be a drawing on the paper tray, most go face down. Try a copy first to see which side copies and which side gives blanks.
Jan 05, 2010 | HP Officejet 4215v All-in-One Printer
All of a sudden, faxes stop coming out and the window says something to the effect...''Place US Paper in Upper Tray''. If I turn the machine on and off, the display clears and faxes that are in memory...
The fax machine is trying to print fax recieved copies on the bypass feeder.
Check up the setup menu on the control console.
Fine fax recieve.
You should find a selection for fax recieved in which paper tray.
Check this area, any that have the bypass feeder, de-select it.
Make selections for 8 1/2 x 11 paper in tray one.
May 01, 2009 | Xerox FaxCentre F116 Plain Paper Laser
How do i copy something?
PLACE THE PAGE TO BE COPY DOWN THE SHOOT ON THE MACHINE AND PRESS COPY. THEN YOU WILL BE DONE GOOD LUCK
Feb 02, 2009 | Brother IntelliFAX 2800 Laser Fax
I Lost my memory...
Make a copy of something, then you'll know for sure.
Dec 18, 2008 | Brother MFC-1970MC Plain Paper Inkjet Fax
I have the stupidest question. i have a brother fax 560 plain paper fax. Do i load paper face up or down to send a fax? THank you!
just check there wilkl bi mention face up or down .if not mention no problem just make a copy by putting face up and one copy by putting it face down.one time u will receive white copy and one time u will receive print on paper .when u will receive print check this is face up or down .after confirm just send fax
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Incoming fax problem
DON'T KNOW IF THIS WILL HELP-BUT MY PROBLEM WAS SIMILAR--MINE WAS SAYING PAPER TOO NARROW WHEN I WAS TRYING TO PRINT AND COPY. I JUST KEPT MOVING THE FRONT SLIDER AND THE LEFT HAND SIDE SLIDERS BACK AND FORTH AND TOOK THE PAPER IN AND OUT --TRIED AGAIN AFTER EACH TIME--IT EVENTUALLY FIGURED OUT I DID HAVE THE RIGHT SIZE PAPER--
ALSO TRY---MENU--THEN--COPY SET-UP--THEN PAPER SIZE--SEE IF PAPER SIZE IS SET RIGHT.
Mar 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Canon PIXMA MX310 All-In-One Printer Logo
52 people viewed this question
old marine
old marine
