Question about Refrigerators
Frige not getting cold on side by side unit but freezer works fine
    President:
  • 1,489 Answers
Check the lever somewhere around the inside top of the refrigerator. This lever slides back and forth to control the temperature in the non-frozen compartment.
Posted on Apr 22, 2009
The freezer works fine, but the frige side is not cold at all. the unit is still under warranty, and the service guy replaced the "control board". but that worked for about a week. Everything is...
Hello Patrickbono,
I understand that your are having a problem with your fridge it is not getting cold. However, the freezer is cooling just fine this is a common occurrence when the evaporator fan goes out in the unit. Here is a tip you can follow to help you diagnosis the problem
Fridge not getting cold?
I would suggest you call the service tech as the unit is still under warranty and have them to replace the fan and check the rest of the unit.
Thank you for choosing FixYa.com
justinbur167
May 11, 2011 | Samsung RS265LBBP Side by Side...
Frige freezer works fine but frige does not. 6 yr old kenmore 596.75509400 model
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 25, 2011 | Refrigerators
Freezer works fine but frige side not getting cold enough-side by side unit
Check rear wall of freezer to see if you can feel frost about halfway down. If so you likely have a defrost system problem. Three components involved in defrost system, Heater, defrost thermostat and defrost timer or Defrost control (circuit board).
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Model and brand is always helpful when requesting information.
Aug 22, 2009 | Kenmore Refrigerators
Freezer is working good but the frige is 52
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 17, 2009 | Refrigerators
Frige not cooling, freezer is fine
its the problem of defrost timer.due to this the cold air from freezer section is not getting in to refrigerator section and its getting warm.check out the defrost timer.located beside the compressor at the back lower side of the unit.the cost of new defrost timer is near to $40.and you can get it from
www.repairclinic.com
thanks.
Jul 14, 2009 | Jenn-Air JFC2089HE French Door...
Side by side whirlpool frige, freezer works fine refrigerator section not cold enough?
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
Thanks
Jul 02, 2009 | Refrigerators
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Bottom Freezer working but not side!
Typically the freezer air is circulated into the frige area to provide cooling. If the circ. fan is not working or the air ducts/channels/dampers are blocked with ice, food, etc. then no cool air will get from the freezer to the frige area. Check all the air channels and to see if the dampers are open along with the circulation fan running. The diagrams at the following link should help you see inside better. If your lower circulation fan is running then you likely have an air return/supply channel blocked with ice and will require an old style defrost (unplug unit and leave doors open for 24 hours to melt ice, etc.). If the fan isn't running then that needs to be replaced. Air channels can freeze up if a door is left open slightly overnight or other moisture enters the freezer/frige. http://www.partselect.com/MultiModels.aspx?ModelNum=ER6AHKXPQ&searchTerm=&RefineSearch=0
Nov 20, 2006 | Whirlpool ER6AHKXPQ Top Freezer...
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
