Question about Bosch Dishwashers
Bosch dishwasher has standing water doesnt drain out, repair man pushed 2 buttons cancel drain and it drained last month, but happened again today and it wont work for me
Fixed mine very easily... After checking and cleaning the filters by the tub's drain, I checked the air vent atop the sink -- it had a small bit of gunk trapped in the outlet. Cleaned it out, ran a "rinse & hold" cycle and it drained the tub beautifully!
Posted on Jun 09, 2012
  • 641 Answers
SOURCE: dishwasher not draining - Kenmore dishwasher model 15754
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Let me know if you will need for further assistance. Good luck!
Posted on Sep 16, 2007
  • 833 Answers
SOURCE: Dishwasher draining - Bosch SGV4313GB/17
This is generally because of a stuck diverter solenoid. The water goes to the pump and then is either sent to the wash arms or the drain. Also, check the drain.
Posted on Feb 11, 2008
  • 1019 Answers
the first things to look for, are the simplist faults.
1:) Check that the Outlet Hose-Pipe Isn,t Blocked-Kinked Or Bent.
2:) Check that the Pump, is not clogged/Blocked or not-functioning.
Hope this helps you start, your fault-finding successfully.
Mike @ Compurepair.
Posted on Aug 02, 2008
huuum
  • 750 Answers
SOURCE: my bosch dishwasher will not
Hello michloyal68,
You said,
my bosch dishwasher will not reset after holding cancel and drain. It seems to want to run a cycle but will not...help please!!!
Try turning off the power from the breaker for 3 minutes and then restarting it!
This should reboot the system!
I hope that this is all you need to get moving again.
Let me know how it works!!
Bless You,
Huuum
Please give me a rating before you sign off.
Posted on Sep 18, 2008
Macmarkus
  • 2605 Answers
SOURCE: Hello, I've got a Bosch dishwasher that is acting
Welcome to FixYa.
Based on your description I'd say the issue is with the control...unfortunately.
The number"1" being displayed ( on models with the display ) is actually an error code indicating a fault in the heating process.
Bosch has had a history of this exact problem I'm about to lay out for you and this is the first thing I'd be looking for if called out to service the unit with the symptoms you've described.
As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
My first suggestion would be calling in an authorized bosch service tech. if that is an option for you and your budget however, If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
This ones new, but it's where to look...
...hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed, other-times it will eventually stop or display "1".
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
As you alluded to though, sometimes one needs to call a tech. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Hope this answer`s your question, let me know if I can assist you further.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Sep 07, 2010
My Bosch dishwasher is driving me crazy! When it finishes a wash cycle it beeps twice every 10 minutes until the door is opened. We can't run the dishwasher at night after dinner unless we're SURE we...
Hello there,
It would help to know the model number of the dishwasher, but on many Bosch dishwashers, you can switch the cycle cycle completion signal off as follows:
1. While holding the right-hand CANCEL/DRAIN button, also press and hold the ON/OFF button
2. When the LED above the CANCEL/DRAIN button illuminates and the beeping starts, release both buttons
3. Press the right CANCEL/DRAIN button repeatedly until the beeping tone is at the desired volume, i.e. silent!
4. Press the "ON/OFF" button again to set the volume.
On models with the wash cycle buttons on the top edge of the door, the CANCEL/DRAIN buttons aren't always explicitly labelled CANCEL/DRAIN. These buttons are also labelled RESET on some models.
On models with 3 and 4 wash cycle buttons, the right CANCEL/DRAIN button is the third button when reading from left to right. On models with 5 wash cycle buttons, the right CANCEL/DRAIN button is the fourth button when reading from left to right.
Please try the above then let me know if you need further assistance. Please state the model number or series (i.e. Integra) of your washer if/when replying.
Hope this helps.
Regards,
BElectric
Mar 16, 2011 | Bosch Dishwashers
Bosch Dishwasher won't fill with water
Certainly *sounds* like the float is stuck in the over filled position
or possible a bad float switch, if the float is stuck in the up or full position, the d/w will not fill with water and the drain motor will often run all the time
Jan 23, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher not draining
The problem is a clog in the hose or the check valve from the drain pump. I will post back shortly with directions to unclog it.
Thanks/Mike
Jan 13, 2008 | Whirlpool 24 in. DU930PWP Built-in...
Won't drain
I found a video that explains how to fix this issue, here is is.
Bosch Repair video
Feb 06, 2011 | Dishwashers
After the last wash I noticed the bottom of my dishwasher (Whirlpool quiet partner 2) was filled with water. After unloading the dishes I closed the dishwasher and pushed the Cancel/Drain button but the...
1.Check the drain filter for clogging.
2. Check the drain hose. Remove carefully to avoid water spill.
3. Check whether flows freely from the hose.
4. Check the drain valve if possible for you.
Sep 15, 2010 | Dishwashers
Bosch dishwasher model shx33a can't figure out how to just drain without running the whole cycle...HELP
usually on the consol in small print it will say press these 2 keys to drain. Read all the lettering on the consol and let me know
May 28, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Standing water in bottom of dishwasher...didn't drain.
hit the cancel drain cycle. Often times the dishwasher drain hose is not installed properly. It must be routed up as high as the dishwasher as soon as it comes out of the unit. May be also that there was a little regular soap or something that made it sudds up. vegetable oil poured into the dw tub will remove the sudds. Try to wash again after cleaning out the sudds and run it again. Thanks
Apr 03, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Water not draining from the machine
If it IS the pump, it’s often because some relatively minor item (piece of cocktail stick/bit of nutshell/etc) has found its way past the filters and is blocking the blades of the pump. It is relatively simple to remove the inlet hose to the pump and clear the blockage (a pair of grips to pinch and remove the retaining clip, then the hose will slide off the fitting on the pump). I did this several times on my previous (Hotpoint) machine – and suspect it is no harder on the Bosch (which I now have). If that doesn’t work, you are half-way to replacing the pump, which is not a difficult DIY job and I’m surprised any competent professional repair man wanted to write off a machine where the pump had failed. A new pump should cost around £40-£50 – less than a quarter of the cost of a new machine. DIY fitting would maybe take a couple of hours; a pro ought to do it in less than an hour.
Mar 08, 2009 | Bosch 24 in. SGS43C12 Classixx...
I have a 24" Bosch diswasher - water does not drain
I have the same problem with my she58 water does not drain. only 4 months old and repair man replace 3 diff parts ...same thing happen. Bosch send another company to repair..replace parts by parts. not working....almost 5 months now I don't have dishwasher...i have to call almost everyday to Bosch..to fight for it....couple of days ago customer support told me with in 10 days somebody would call me for the replacement....i have to wait and be back if i don't have heart attack..to tell if they really would replace...gemtx
Jul 26, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch classixx check water light
ok sounds like a drain promblem love your do it your selfness but one thing you must keep in mind its under warrenty and if you mess with it you could void your warrenty if you have a cancel drain option try that if it still doesnt drain call for service
Mar 18, 2008 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
1,337 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
