Question about Toshiba Satellite® A205-S5841 PC Notebook
Installing XP over vista
I have a lap top, which obviously doesnt have a floppy drive. my problem is setup is not able to recognize hard disk drives (error code in setup) since sata is not compatible with XP.
ive been suggested to use nlite, but when attempting to create installation cd, i can not find appropriate DRIVERS.
ANY SUGGESTIONS HOW TO GET XP UP AND RUNNING ???
  • 2 more comments
  • madxblunts Apr 26, 2009
    Jeryflores, i thought i would be able to change hard drive settings in bios but so such option is available.. and i had also looked for sata drivers for my particular model but was also unsuccessful. the only thing i could think of was to use nLite and add the sata drive..but you and i know that is not possible
  • Jerry May 11, 2010
    Unfortunately, you are correct Madxblunts. Not all systems were designed for the previous generation OS. Some of the HP systems were not designed to run Windows XP either. They came preloaded with Vista and I'm afraid the same is true for your particular brand/model. I'm sorry, I looked for any possible method, but if the manufacturer does not make the drivers available, short of being a programmer, we just can't pull out drivers out of thin air. Best of luck...as a previous FixYa person stated, "its awesome." Well, it's alright. ;-)
  • Thomas F. Schneider May 11, 2010
    Have you by any chance looked in the BIOS of your notebook to see if it has a mode called "IDE Emulation"? I don't see any SATA drivers for Windows XP for you particular model, which leads me to believe that they should have an IDE emulation mode in the BIOS. Give it a try and let me know what happens...
  • 3 Answers
If your asking to install XP on top of vista.. if you do not like vista, then ur listening to your friends who have no idea what their talking about because its awesome and when windows 7 comes out youll be stunned...this is verry easy if you have XP disc ready, restart your computer you need to wipe ur hard drive to get rid of the old operating system, first save any thing you want thus wiping hard drive saves nothing.... techniquly its still there but ya....put in disc of XP and run the disc to install XP,. ACTIVATE IT AND WALA
Posted on Apr 22, 2009
Dfi-64 tc problems. i just to install xp (before was windows millenium )now each time when xp load appears a message saying that bus ide drivers does not installed but when i run the drivers disc...
when a person goes install windows xp they encounter the problem of not being able to find any hard disk drives installed as if they weren't connected. The hard drive is detected with no problem in the BIOS and also on start up POST, able to boot up Linux Live CDs but the hard drive is just not being detected in Windows setup. Here is the exact error message.
Setup did not find any hard disk drives installed in your computer.
Make sure any hard disk drives are powered on and properly connected to your computer, and that any disk-related hardware configuration is correct. This may involve running a manufacturer-supplied diagnostic or setup program.
Setup cannot continue. To quit Setup, press F3.This problem is quite a common one and is simply due to the fact that when Windows XP was created, the SATA chipset itself and SATA hard drives weren't available to the masses, so support for it wasn't included in the XP setup process. As most computers within the last decade or so have some form of SATA controller, if you try to install Windows onto a SATA drive, XP won't recognize it because the drivers aren't present on the installation disc, so they need to be loaded manually for the drive to be picked up.
Thankfully there are a few ways to get around this problem and enable Windows XP to be installed onto a SATA hard drive so you can enjoy the extra performance and other functions like hotplug/AHCI etc. Setting the BIOS Correctly
The first and mos obvious method is to change the SATA Mode to IDE in the system BIOS. Most BIOS's for several years have included a fallback mode to enable a SATA drive to behave like an IDE drive, and therefore makes it visible to XP during setup. The problem with this setting is it comes under several different names and can be found in different sections within the BIOS. It depends entirely on the computer or motherboard's make, model and manufacturer to know which setting you have and where it is. If you have a manual, it's certainly worth reading.
The most obvious thing to look for is a setting which can change the SATA controller to IDE or PATA mode, with options such as AHCI -> IDE or SATA/RAID -> IDE etc. Basically any option you come across to reduce the SATA/RAID mode to IDE/PATA should be the correct one. Don't confuse this option with a similar one which will disable the SATA controller completely. Here's some names we found it could be under in a few motherboard manuals we looked at:
Integrated Peripherals > SATA Devices Configuration > SATA Mode > [IDE]
Integrated Peripherals > Serial ATA Function > Base
Storage Configuration > SATA Mode Selection > Emulated PATA Mode
SATA Configuration > SATA Configuration [Enhanced] > Configure SATA as > IDE
Integrated Peripherals > South OnChip PCI Device > SATA Controller > IDE Mode
Using a Floppy Disk
If you're unable to change RAID mode to IDE or disable SATA in the BIOS, then the next option would be to download SATA/RAID drivers from your motherboard manufacturer's website, extract the drivers to a floppy disk and then insert the floppy into your computer during Windows XP installation. This method obviously gets around the problem of XP not having the drivers on the install CD by you providing them manually.
Windows XP setup won't recognize USB flash drives, so you need to have an internal floppy drive available, many USB floppy drives will also work though. As you can see in the image below, it clearly states that the SATA RAID driver is for use on floppy drives. You need to make sure any drivers you download are explicitly designed for putting onto a floppy and not a generic driver, usually the file will be around 1MB or lower which is a good sign it's likely to be the correct driver.
Insert the Windows XP CD and boot it up. You should see a message that says "Press any key to boot from CD..." Simply hit any key and it'll start to boot from CD. Pay attention to the next blue colored windows setup screen. When you see a message that says "Press F6 if you need to install a third party SCSI or RAID driver..." at the bottom, immediately hit the F6 key.
After loading some files, you will come to a screen that says the following:
Setup could not determine the type of one or more mass storage devices installed in your system, or you have chosen to manually specify an adapter. Currently, Setup will load support for the following mass storage devices(s):
< none >
* To specify additional SCSI adapters, CD-ROM drives, or special disk controllers for use with Windows, including those for which you have a device support disk from a mass storage device manufacturer, press S.
* If you do not have any device support disks from a mass storage device manufacturer, or do not want to specify additional mass storage devices for use with Windows, press ENTER.Make sure the driver floppy is inserted and press S. It will present a list of drivers which it read from the disk earlier. Select the appropriate driver and continue the Windows XP installation. The setup will continue and this time it will recognize the SATA hard disk drive in your PC. This problem is quite common when trying to install Windows XP on newer computers because most if not all are using SATA hard drives. After installing Windows XP, you can easily and automatically install all required device drivers using the DriverPack Solution disc.
If you thought it wasn't possible to use a USB flash drive instead of a floppy drive to load the drivers during the F6 phase, we have a solution that could !!!
Oct 04, 2017 | DFI CA64-TC Via 694T/686B Mainboard...
I have a k8u-x motherboard.. my problem is i cant install winxp in it because it doesnt detect any hardisk during the setup. All my floppy drives are damage as well as my floppies. Is there any way to...
Your trying to install windows 3.1 or 98 ? I have never seen Windows XP or newer on floppy disk is why I ask. That will not resolve your problem though. If you are sure you have the hard drive installed and connected with at least one of them set to Master, if you are installing 2, You may need to enter Bios and have it auto detect the Hard Drives in the Bios. If the Bios doesn't recognize the Hard drive or you have 2 hard drives and one isn't set to Master it won't matter what media you use you won't be able to install anything on the hard drive.
Sep 08, 2010 | ASUS K8U-X Motherboard
My Dell 531S will not boot past the BIOS (Dell logo) screen. At first I thought it was the hard drive, since it wasn't recognizing anything connected to SATA port 1. Since then I have purchased a new...
It seems like you have multiple problems:
1. DVD-ROM drive not accessing the disk
2. unable to "disable" the "floppy" drive in BIOS SETUP
3. not recognizing anything connected to SATA1 port
It's time to take your computer to a qualified technician, for professional trouble-shooting.
Is your DELL computer still under warranty? If so, exercise the warranty.
Or, maybe you should just remove the "new" disk-drive, the RAM, the DVD-drive, and then responsibly "recycle" the old computer, and purchase a brand-new system, repurposing the disk/RAM/DVD components.
Sep 01, 2010 | Dell Inspiron 531s Desktop Computer
Displays no hard drive found wen installing win xp
You have to go to BIOS setup, find HDD setup, and change the value to the other one (there are only two possibilities). That will fix your problem. The problem is caused by the fact that the lap top was designed for vista, not XP. and the lap top contains SATA HDD. when installing XP pre-installation doesn't have SATA drivers, so your OS can not see the HDD. Change it in BIOS, and you trouble is gone
Nov 14, 2009 | Toshiba Satellite A200-19501F Notebook
Installing XP SP3 pro on my presario C700
Most likely you have a SATA drive which windows is not detecting. Restart the setup and press F6. You will need to use another system to download the SATA drivers and save to a disk. Then when prompted you can insert the disk. You can also upgrade to XP professional which will almost always recognize the SATA drives. Good Luck.
Jul 30, 2009 | Compaq Presario 700 470024-192 Notebook
Dual boot problem
xp can not recognized the sata hard drive u have to install sata drivers before installing xp.
Nov 19, 2008 | Toshiba Satellite A205-S4617 Notebook
Sata hd, installing windows
Hi nveronika,
First things first. Find the name of you're SATA hard disk drive.
Please go to the manufacture's web site & download the floppy drive setup/utilities bootable software or creat a bootable CD from the manufactures site. Boot the system with their software & setup you're hard disk drive which will run in a DOS like window. (This should resovle the blue screen issue).
There are two different revision for the motherboard GA-M52l-S3
(Revisions, 2.0 uses the NVIDIA® GeForce 6100 / nForce 430 chipset): http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=2818
& (Revision 1.0 which uses the NVIDIA® nForce 520LE Chipset): http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=2634
Which is you're motherboard? Once you find the correct motherboard you can download the the needed software directly from the web site & create the correct floppy disk needed when pressing the F6 key during windows installation. If you still get an error message try another fresh floppy disk. (Corruption of files to a floppy usually mean the floppy drive is dirty or bad or the floppy disk is bad). It is also possible that the data cable to the floppy drive is loose or defective. Downloading directly from Gigabyte is suggested over using the CD.
Good luck nveronika!
Mike
Aug 30, 2008 | Intel Motherboard
I have an Accer Extensa 5220 laptop which came with vista Home Edition. I wanted to down grade the OS to windows XP Pro. After formating the Hard Drive, I ran windows XP setup disk but keeps on giving the...
The problem of your laptop is the hard disk type. because acer 5220 laptop is using a SATA hardisk that automatic detected or supported by Vista. But in the windows Xp you need to download the sata driver for windows xp and save it to the floppy drive. In the beginning of windows installation press F6 to install another device or scsi the windows setup search your floppy drive for the sata driver and install it automatically. If you have cannot fix it just contact me i'm willing to help you
Apr 15, 2008 | Computers & Internet
Problem
Your harddrive is probably S-ATA and xp doesnt have a build in driver for it. You need to download a S-ata driver from hps website, I'm not sure if xp can read the driver from anywhere else but a floppy. So i that case your going to need to buy a USB floppy drive.
http://www.hexus.net/content/item.php?item=1420
Theres a tutorial on how to make the floppy.
If the floppy doesnt work, you might need to copy all the xp files into the hard drive and add the Sata driver into the xp installer, that can be hard todo maybe il give you instructions on that later.
Mar 12, 2008 | HP Pavilion dv1000 Notebook
ACER 4720Z
seems that it's a SATA drive and the drivers are not included in XP.
There are some tools available to include these drivers into the XP CD.
Search the net for 'xp-iso-builder' or 'n-Lite'.
This is not necessary if your laptop's got a floppy drive (i don't think so). Then the SATA drivers can easily be loaded by pressing F6 when booting from the XP CD.
Mar 02, 2008 | Microsoft Windows Vista Ultimate Edition
Toshiba Satellite® A205-S5841  PC Notebook Logo
108 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
