Question about HP LaserJet 3300mfp All-In-One Printer
Hp 3310 black ink will not print. All new cartridges. Never used refilled cartridges
    Champion:
  • 214 Answers
Try copying many pages of black only text then head clean worked for me Even 200 or so copies clean head after 50 or so and check print worked for me
Posted on Apr 23, 2009
What is problem when a ink jet printer (hp psc 2410xi photosmart) has a red stripe in the black print?
Using HP56, 56 cartridge for your printer?
Well, when you are out of black ink, that's what it happens.
Pls refill your cartridge or replace with new one.
How you refill? very easy.
f you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 12, 2011 | HP Office Equipment & Supplies
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
My black ink has quit printing however the gage shows it to be half full. Thanks for your help :-)
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 19, 2010 | HP Photosmart 3310 Printer
Installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Jan 20, 2010 | HP PSC 1315 All-In-One InkJet Printer
HP Photosmart 3310 printer shows all ink cartridges need replaced
If you ran the ink cartridge refill routine, from your desktop using the utility supplied by HP, this should not occur, so try running the head cleaning and alignment routines and see if this clears up the problems.
I am assuming that all your cartridges are relatively full and trouble free and that the printer has been successfully and recently used, prior to your replacement of the one new cartridge.
Sometimes, if the printer has been idle for some time without use, the ink will dry on the heads of perfectly good cartridges, causing the problem you cite.
Use alchohol based cleaner with the kind pads supplied with a new cartridge to regularly clean the heads of your ink cartridges, according to instructions in your manual and CAREFULLY, so as to not damage the heads.
Apr 07, 2009 | HP Photosmart 3310 Printer
How to reset the ink level for a HP 60 ink cartridge? I have just refilled a HP 60 black ink cartridge but can not find anything on how to reset the ink level. I would do the "3 ink cartridge" trick but I...
You cannot reset the ink level indicator for the HP 60 ink cartridge. It shouldn't matter anyway because the level is only estimated for "management purposes only" (see user manual) meaning to let you know when it's near time to order a new cartidge. I have tried cycling through 3 different cartridges to reset the ink level for the one I refilled but it didn't work. Refill and just ignore the ink level indicator. Also, it's a good idea to clean the print heads with the solvent in the refill kit before refilling to remove old ink and imrpove print quality.
Apr 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
HP 3310 - problem with black ink supply
I heard you can get the 3310 to do a pump up the tubes cycle but i don't know how to make it do it. Pressing the ok and cancel buttons when you power up didn't work for my machine. Which has too died a inkless black death!
Jan 31, 2008 | HP Photosmart 3310 Printer
HP Photosmart C6100 All-In-One Printer stopped printing black ink
Please clean the print heads :
Press Setup up - Tools - Clean Print heads on the All-in-One.
If this does not resolve the issue , Reset the All-in-One.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
If issue stil persists. Contact HP.
Dec 19, 2007 | HP Photosmart C6180 All-In-One InkJet...
HP 3310 ink cartridge not recognised
My HP 3310 wil not print black. The color prints fine. Spent 2 hours on the phone with HP support only to be told to buy a new printer. The machine is less than 2 years old. There must be a way to repair this. Any ideas? Barbara
Nov 08, 2007 | HP Photosmart 3310 Printer
Black ink does not print
i had the same problem. black stopped printing. i always used OFFICIAL HP cardridges, so this problem is not exclusive for refilled cardridges.
This solution (offered here) worked for me:
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and the turn it back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartiges in the printer so that it can reset.
I wanted to stress that you should make sure that:
1) you keep the the buttons down untill it shuts off;
2) on restart you get a notification of service;
3) to turn it off again after service before you turn it on for actual use.
Aug 27, 2007 | HP Photosmart 3310 Printer
HP LaserJet 3300mfp All-In-One Printer Logo
59 people viewed this question
Seeker5211
Seeker5211
